Acoustical Treatments Master Thread - Page 398 - AVS Forum | Home Theater Discussions And Reviews
 267Likes
post #11911 of 11929 Old 07-08-2017, 10:02 AM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
Originally Posted by Augmont View Post
I would like to get started on my materials list for DIY room treatments for a new HT room that is currently in the beginning stages of the build. Lots of good stuff on this thread but not sure what i need and materials to go with it.
My plan is to line the front wall behind the false wall with _________ (help me fill in the blank) and build a false wall to hide the speakers. The false wall will be covered AT fabric of course. The room is square so I know I will need some bass traps in the corners and I know I will need to treat the first reflection point. on the back wall, how do you determine location and size of treatment. Same question for the ceiling.
I still haven't determined if I plan to cover in fabric the first 6ft of the room with velvet for the screen reflection.
I like building things so it's why I prefer to go the DIY route.....plus to lower my cost and customize to my desire.
Anyhow, I appreciate the opinions for all you experts cause I know my limitations and smart enough to ask more knowledge people than me. Help me learn in the process.
The area behind your screen can use some OC703 board, wrapped in cheap burlap just to contain the dust, or what ever material fabric is cheap.
Prioritize all your flat surfaces and corners, each will require the right treatment to achieve the result you are looking for.
Example, i have two flat surface area's that have a slap echo/flutter echo. Its not i high priority, like a first reflecton point, its well out of the way, so some wood diffusers will break up the parallel surfaces and reduce any colour produced by erant sounds.
You will hear opinions also that first reflection absorbers create a blackhole effect that is very unatural. 100% true.......if you fail to complete proper treatment of the rest of the room. If you continue to address all these surfaces that ADD reflections, and their own signature sound, you have removed the room and now hear the music/movies.
But, dont be a follower, dont listen to me or anyone else and just DO. Get involved, add and subtract as you see fit, listen listen and listen some more. The worst advice is to do it cause i said so.
kgveteran is offline
post #11912 of 11929 Old 07-08-2017, 08:45 PM
subacabra's Avatar
Quoted: 373 Post(s)
Liked: 588
So I got a chance yesterday to really crank the system and test out these panels. Played scenes from Need for Speed, Oblivion, MMFR, World War Z, Pulse, Life, Incredible Hulk and couple others.
It sounds awesome but.. I think I may have over treated the left wall. Maybe I'm just not used to it without all the reflections but it just seemed a little off to me.
I may try removing the circled panel which was for the secondary reflection of front right and center and see if it sounds a little better.
I also may try a smaller panel there.
Guess we'll see!
subacabra is offline
post #11913 of 11929 Old 07-08-2017, 09:03 PM
Roger Dressler's Avatar
Quoted: 1647 Post(s)
Liked: 827
Maybe not. But that can be decided later, after some measurements are done in the actual space.
I'd suggest planning for 4 subwoofers, in the 4 corners if possible, but not required. Just getting a second pair in the rear will work wonders for taming bass issues. Being able to slide the row of seats fore/aft a bit will also allow some fine tuning (dodging of the room modes). No need to install 4 subs on day 1, but after you start using the room, you can decide on that step. It will be easier if you have power and audio lines run already.
Deadwood II Theater
Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #11914 of 11929 Old 07-09-2017, 04:55 AM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
Guess we'll see!
Only an ETC graph could show you if the panels are absorbing the whole reflection, broadband absorbers are what you are looking for, two inch thick absorbers are good for the highs, but to absorb lower frequecies of the reflection it needs to be thicker.
What do you measure with ? The object is to reduce your reflections below 10ms..... It does take some time to get use to RFZ's
ereed likes this.
post #11915 of 11929 Old 07-09-2017, 05:35 AM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
I run (4) 15" subs, i use to just spread them across the front of my room below the screen. Evenly spaced across the 13' width of the room. I was rearanging my room and slid the two in the center to either side, so two to the left and two to the right. Then pulled them away from the front wall a bit, and my nulls were gone !!!!!! I had two subs in the middle of the room which was disasterous, now with two to one side, two to the left, i no longer use my MiniDSP to EQ!!!!!
post #11916 of 11929 Old 07-10-2017, 07:15 AM
Augmont's Avatar
Quoted: 112 Post(s)
Thanks.....
Augmont is offline
post #11917 of 11929 Old 07-10-2017, 07:25 AM
Augmont's Avatar
Quoted: 112 Post(s)
I plan to start with 2 15" subs up front as a starting point, 5 ft from each corner. Preference is to keep the room at 2 subs. I may consider one towards the back. I will plan and cable the corners however so I don't have fish wire later.
Augmont is offline
post #11918 of 11929 Old 07-11-2017, 11:15 AM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
What do you use to measure with, i've been using OmniMic for a few years now, pretty handy tool.
post #11919 of 11929 Old 07-11-2017, 11:34 AM
Augmont's Avatar
Quoted: 112 Post(s)
I have both OmniMic and REW with UMIK-1. Sadly, the REW was too complicated for my use and learning curve. I have played with OmniMic years ago but need refresher. I bought these toys years ago in anticipation for a HT room which will be a reality in the next few months. YEA FOR ME!!!!!!
Augmont is offline
post #11920 of 11929 Old 07-13-2017, 12:37 PM
Quoted: 113 Post(s)
Liked: 47
Just spent $1,300 today on treatments, seems insane, hope its worth it...
HTMatrix is offline
post #11921 of 11929 Old 07-13-2017, 06:30 PM
dnoonie's Avatar
Quoted: 294 Post(s)
Liked: 242
I ordered some dent and ding 2' x 4' by 4" bass traps from Acoustimac. I picked them up yesterday and the boxes seemed particularly heavy...so I weighed another same sized bass trap I got from them a few years back, non dent and ding...12 lbs, and the most recent is 21 lbs. I would guess the most recent must be filled with 8lb Rorxul. So I weighted another set of dent and ding bass traps I got from them last year at 17.5 lbs, I guessing it must be filled with 6 lb Rorxul. I'll be putting these in the back of the room which has the most bass build up right now. Some day I might get 2 more subs for the rear which should help the room response but for now this is great.
Cheers,
dnoonie is offline
post #11922 of 11929 Old 07-14-2017, 08:13 AM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
DIY is a huge savings for the future, most all acoustic treatments can be duplicated ur self if you wanted to. Good luck
post #11923 of 11929 Old 07-14-2017, 08:33 AM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
Yup REW is way over my head too, OmniMic works perfect for what i need.
I've used the ETC feature too, pretty comprehensive
post #11924 of 11929 Old 07-14-2017, 09:43 AM
Quoted: 113 Post(s)
Liked: 47
Thanks, I'll take that into consideration next time. The costs for the panels added up quicker than I thought and I just went for it. I dont think I even want to know how much it would have been if I had done it myself.
HTMatrix is offline
post #11925 of 11929 Old 07-14-2017, 11:18 AM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
I understand completely. If at a later date you need a hand doing some panels send out a PM
HTMatrix likes this.
post #11926 of 11929 Old 07-17-2017, 11:54 PM
VideoGrabber's Avatar
Quoted: 183 Post(s)
Liked: 114
Sorry for catching up a week late, but:
I run (4) 15" subs, i use to just spread them across the front of my room below the screen. Evenly spaced across the 13' width of the room. I was rearanging my room and slid the two in the center to either side, so two to the left and two to the right. Then pulled them away from the front wall a bit, and my nulls were gone !!!!!! I had two subs in the middle of the room which was disasterous [sic], now with two to one side, two to the left, i no longer use my MiniDSP to EQ!!!!!
By this, I have to assume you really meant in the middle of the front wall. Correct? Unless you had been sitting on them.
VideoGrabber is online now
post #11927 of 11929 Old 07-19-2017, 08:12 PM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
Correct, the two 15's were front center, two were against the side walls. I had read that bad things happen out in the middle of the room.... It got me thinking to measure them to the sides. It was amazing what that did to the response. My room is a rectangle, very simple setup, now even better, no EQ. When i do a final tweak of the bottom end i may add a little boost, but only if it really needs it. audyssey adds a nice curve with dynamic eq, probably no eq needed.
post #11928 of 11929 Old 07-24-2017, 04:32 PM
rawhit's Avatar
Quoted: 23 Post(s)
Liked: 46
Corner Bass Trap Build - Add FSK paper for high freq reflection?
My first post in this thread. Have a very specific question about bass traps.
I've taken care of the 1st, 2nd reflection points in my HT room with knauf ecose panels and now trying to correct the bass.
Built frames for corner mounted bass traps and plan to fill them up with Roxul Safe and Sound.
To avoid too much high frequency absorption, thinking of adding FSK tape to front facing side of the bass traps.
Wondering if I should I cover completely with FSK or only apply selectively in some pattern to get the best results?
Pics below
Any input appreciated!
rawhit is offline
post #11929 of 11929 Old Yesterday, 05:57 PM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
Pics below
Its cheap enough to cover them with a craft paper, see how that sounds, mite liven things up a bit.....
Fv15hp Subwoofer , Denon , Audyssey
