Acoustical Treatments Master Thread - Page 399 - AVS Forum | Home Theater Discussions And Reviews
 270Likes
post #11941 of 11943 Old Yesterday, 08:40 PM
dnoonie's Avatar
Quoted: 303 Post(s)
Liked: 247
Originally Posted by grendelrt View Post
More of an aesthetic thing, I might be able to do a 2" panel or something, but I don't want anything really large hanging down if possible. With the ceiling speakers and projector could get complicated. Looking for other possibilities before I go down that road =) Didn't know if diffusion was one, I only have absorption right now and I know there is supposed to be a balance.
2" absorbers with 703/705/Roxul works pretty well, I've switched to 4" for my front ceiling first reflection points but the 2" seemed to do a good job too. I have Roxul 4lb in the front and a mix of 4lb and 8lb in the back. I have 2" on the front sides with a 1" gap (first and second reflection points), because of space considerations I'm not going with 4".
The rule of thumb for diffusion positioning is a foot of distance for every inch of thickness for the diffusion otherwise you get image smearing (at least that's been my experience, someone with more knowledge might be able to fill in) so if you have the distance from the ceiling 1st reflection point to your seating position diffusion might work for you. Diffusion would tend to be thicker than absorption so I'm not sure it would be better for you or not.
Cheers,
dnoonie is online now
post #11942 of 11943 Old Today, 07:39 AM
grendelrt's Avatar
Quoted: 197 Post(s)
Liked: 90
Cheers,
Yeah etc graph says 4.65ft to the point on the ceiling, so that's 4.65inches at the hight point of the diffusion material? For a 2" roxul panel I wonder if I could get away without framing it, maybe use a back board and fabric, 2" seems doable at least.
grendelrt is online now
post #11943 of 11943 Old Today, 07:22 PM
dnoonie's Avatar
Quoted: 303 Post(s)
Liked: 247
The GIK 2" panels are 3.625" thick since they have a built in plenum. The Acoustimac 2" panel is 2.25" thick with backing (I have the Acoustimac and I measured it). If you can spare slightly less than a 1/4" I'd go with a backing, it just seems like it would be easier to mount.
For flush mount to a ceiling I would choose the Acoustimac z-bar, http://www.acoustimac.com/acoustic-i...ation-hardware, I've used these and like them, they give you a little wiggle room as apposed to the ATS z-bar, https://www.atsacoustics.com/acoustic-panel-zbars.html, which I have also used, they give you a supper snug fit, no wiggle room so it would scar any surface you use them on when you mount a panel, the advantage being that you're not going to have any rattles to deal with (I've cleaned up mounting hardware rattles by putting cloth around z-clips and z-bars). If you have a panel without a backing you could possibly use Rotofast anchors, https://www.atsacoustics.com/cat--Accessories--103.html, I've not tried them so I don't know how well they work. I'm just not sure how to do a supper clean look flush mount without a backing.
Cheers,
Fv15hp Subwoofer , Denon , Audyssey
