Wiring some receptacles 220V for equipment, good idea or not? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-26-2016, 06:52 AM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
New HT wiring is beginning and I am having a sub panel installed Monday with 4 20 amp circuits to power equipment. I remembered that 220V supply is balanced so the noise is significantly reduced vs a 120V circuit. My amplifiers can run either 120V or 220V so I am considering powering each on its own 220V circuit.
My 120V equipment runs trough an Exactpower unit that is plugged into an Olympus Mh-787 medical grade isolation transformer. http://hometheaterhifi.com/volume_11...r-11-2004.html
Is 220V a good idea or not? Where would I find new 220V power cords for my amps?
DaveN is offline
post #2 of 6 Old 11-26-2016, 07:47 AM
69glamboy's Avatar
Quoted: 160 Post(s)
Liked: 56
Seek out an electrical wholesaler in your area. Go in person. They will have multiple choices online for power cords/ cord caps for your amplifiers. Home Depot etc. might be overwhelmed with your request. Hope this helps.
69glamboy is offline
post #3 of 6 Old 11-26-2016, 09:16 AM
Jonas2's Avatar
Quoted: 853 Post(s)
Liked: 280
Have a look here for power cords:
http://www.quail.com/
You can also have them custom built to your desired configuration.
Jonas2 is offline
post #4 of 6 Old 11-26-2016, 09:19 AM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
Thanks guys. Any thoughts on 220V vs 120V?
DaveN is offline
post #5 of 6 Old 11-26-2016, 09:39 AM
Jonas2's Avatar
Quoted: 853 Post(s)
Liked: 280
Well, I'm no expert, but I don't see the disadvantages of using the 220V, you'll get a boost in power efficiency which may or may not matter to you?
Jonas2 is offline
post #6 of 6 Old 11-26-2016, 10:20 AM
SierraMikeBravo's Avatar
Quoted: 336 Post(s)
Liked: 214
Wire for a single 240 volt 30A. Use a step down transformer wired then to UPS. Won't necessarily reduce all hums, but it helps.
SierraMikeBravo is offline
