Gaps between two door jambs - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By drunkpenguin
  • 1 Post By schmidtwi
post #1 of 5 Old 01-18-2017, 09:05 PM - Thread Starter
Liked: 0
Guys, how do you deal with the gap between 2 door jambs in a double wall situation?
james27587 is offline
post #2 of 5 Old 01-19-2017, 02:53 PM
Quoted: 152 Post(s)
Liked: 74
A picture would be helpful as there can be many ,"gaps".........
Link to budget Home Theater build
http://www.avsforum.com/forum/19-ded...i-version.html
unretarded is online now
post #3 of 5 Old 01-19-2017, 03:24 PM
drunkpenguin's Avatar
Quoted: 1090 Post(s)
Liked: 1034
Do you mean you built a double thick wall as in 2x4 framing twice? And now the door jamb is not thick enough? If this is what you mean I had the same problem when I put OSB on the walls and then drywalled over top of the osb. Just take some 1x stock and strip it to fit the gap. Caulk or use wood putty and paint it. Nobody will eve know.
unretarded likes this.
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is online now
post #4 of 5 Old 01-19-2017, 03:34 PM
DaveClement's Avatar
Quoted: 163 Post(s)
Liked: 64
I believe this is referring to the gap between two communicating doors that are installed for sound isolation in a "room-within-a-room" scenario, where the inner and outer door frames should not touch each other to keep the inner and outer walls isolated from each other.
I've heard two schools of thought on this. One is to leave a 1/4" or so gap between the doors so that air can move into the wall structure so that pressure does not build up when the doors close. The other is to seal the gap with flexible material, such as a gasket or backer rod and caulking to prevent musty smells from within the walls from getting out into the living spaces.
DaveClement is offline
post #5 of 5 Old 01-19-2017, 04:14 PM
schmidtwi's Avatar
Quoted: 166 Post(s)
Liked: 121
I'll give @Ted White credit for a great solution that I plan to use for my communicating doors. I've had this bookmarked for a few years... Sweetwood 11.1 Theater destroy and rebuild
"That gap in between doors is simply filled with a bead of sealant and covered with a piece of wood trim. You can attach the trim piece on one side of the gap only. That's about as decoupled as is practical "
obleo likes this.
The Schmidt Haus Theater - WIP (or not) since 2010
schmidtwi is offline
