Moulding Designed for LED Lighting - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By corekneelius
  • 1 Post By Tedd
post #1 of 8 Unread Yesterday, 09:12 PM - Thread Starter
Quoted: 287 Post(s)
Liked: 134
Of course, I find this a week after I installed my crown moulding.
Murphy's Law.
Luxxus is the name of the product line. There are some rather interesting (and attractive IMHO) designs. Makes my Home Depot's selection look as boring as a pile of rocks. If you want to have a look, there are ~313 different choices (perhaps more).
The Luxxus model C362 is one of the versions that appears designed to support (and conceal) a LED strip.
Did I mention it's ~$6.50 per lineal foot???
If you want a deeper/wider space to hold your LED up lighting, check out their model C351. It will only set you back $11.15 per lineal foot + shipping. No big deal, right?!
Alright.... I know what you're thinking. Where's the eye candy???
The C362:
And the larger C351:
You'll find variations of the C351 as well that are slightly wider/taller/more ornate. Click the thumbnails below for larger pics.
ID:	2039609   Click image for larger version
My HT build: The Final Frontier
Quiet Glue: Why I Avoid It
HT Geek is online now
post #2 of 8 Unread Yesterday, 10:36 PM
corekneelius's Avatar
Quoted: 22 Post(s)
Well I thought I had my crown picked out until I just saw this! Back to brainstorming I guess. Thanks for sharing
HT Geek likes this.
corekneelius is offline
post #3 of 8 Unread Today, 12:05 AM
Tedd's Avatar
Quoted: 986 Post(s)
Liked: 365
A few of those C351 profiles remind me of rain gutter.
HT Geek likes this.
Tedd is offline
post #4 of 8 Unread Today, 06:58 AM
Quoted: 3359 Post(s)
Liked: 2835
one thing to keep in mind is that when you run molding for a indirect lighting there is no law that says it has to come in one piece from the factory. You can create your own design. Start with a rectangular stick then add something to create a front lip.
post #5 of 8 Unread Today, 07:20 AM
Ward216's Avatar
Quoted: 22 Post(s)
At those prices I'll stick with modding trim with a table saw to conceal a 1/4 wide LED strip.
Sent from my R1 HD using Tapatalk
There's room for ALL of God's creatures...right next to the mashed potatoes!
Ward216 is offline
post #6 of 8 Unread Today, 07:24 AM - Thread Starter
Quoted: 287 Post(s)
Liked: 134
Yes. This is what I settled on. And much cheaper than these prepped solutions. I have to find time to post pics and update my build thread quite a bit. In a nutshell, I used baseboard + crown to create the effect I wanted on the side of my soffit, and then used a smaller height crown piece on the very top (for appearance and also to hide the DW seams).
The concept of these crown mouldings designed for this purpose is pretty cool tho IMHO. The company has some very nice looking moulding designs of other types as well. Albeit, they are all relatively expensive. I'd personally rather spend my $ on other things for the build.
post #7 of 8 Unread Today, 08:28 AM
Tedd's Avatar
Quoted: 986 Post(s)
Liked: 365
One of the projects I had in mind, when I bought my Track Saw with a 4' track and added an 8' long track. I can join tracks to cut long runs safely.
I can layer up profiles, and work angles over long runs of wood. Joints can be staggered with this approach, so one can create very long
runs of molding this way.
Narrow but deep, slot load molding is also on my radar, for perimeter down lighting effects, with a cloud type ceiling.
Tedd is offline
post #8 of 8 Unread Today, 02:08 PM
NickTheGreat's Avatar
Quoted: 386 Post(s)
Liked: 260
I was hoping this is a good solution for us. :
NickTheGreat is online now
