Home cinema @ Attic - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By wse
post #1 of 9 Old 04-02-2017, 04:01 PM - Thread Starter
Liked: 0
Home cinema @ Attic
Hello everyone, what do you think about this project for my Attic, i bought a new home and i have permission of my wife to make my first home cinema
I was thinking on a 7.1.2 Atmos with a 115" screen !
I would like a very clean cinema ! My idea was hiding everything except surround and back speakers !
Can i put the projector behind the wall ? It will have heating problems ?
What is the best solution for the equipament like amplifier, blue ray, mediacenter etc... where can i put them ?
Best regards
Luís
ID:	2064673   Click image for larger version
ID:	2064681   Click image for larger version
ID:	2064689   Click image for larger version
Luís Amaral is offline
post #2 of 9 Old 04-02-2017, 04:14 PM
wse
wse's Avatar
Quoted: 2204 Post(s)
Liked: 809
WELCOME
Get the largest screen you can, you will not regret it
Also plan for 9.4.6 taht way when you upgrade and you will then you will not have to drill additional holes in your walls and ceiling
Mashie Saldana likes this.
wse is offline
post #3 of 9 Old 04-02-2017, 05:29 PM
Quoted: 45 Post(s)
Welcome. Looks like you have a cool idea for your build.
As for hiding your equipment, would it be possible to hide it behind one of the blue "columns"?
Beams37 is offline
post #4 of 9 Old 04-02-2017, 06:46 PM
Tedd's Avatar
Quoted: 1147 Post(s)
Liked: 437
What's the size of the room, and what's the ceiling height at the low side of the room?
Why have you jammed all the seating on the back wall, and in the back corners, and right on top of the surround speakers? And is four seats actually needed?
It looks really nice, but won't sound nearly as good as it could.
Could an av rack go outside the theater? What's the purpose of the rooms outside there?
Where's the entry door going?
Tedd is offline
post #5 of 9 Old 09-24-2017, 05:54 PM - Thread Starter
Liked: 0
Five months later
ID:	2287810   Click image for larger version
ID:	2287812   Click image for larger version
ID:	2287814   Click image for larger version
ID:	2287816   Click image for larger version
ID:	2287820   Click image for larger version
ID:	2287822   Click image for larger version
post #6 of 9 Old 09-25-2017, 05:49 PM
Tedd's Avatar
Liked: 437
no attached thumbnails...
Tedd is offline
post #7 of 9 Old 10-03-2017, 05:23 PM - Thread Starter
Liked: 0
ID:	2292206   Click image for larger version
ID:	2292208   Click image for larger version
ID:	2292210   Click image for larger version
ID:	2292212   Click image for larger version
ID:	2292216   Click image for larger version
ID:	2292218   Click image for larger version
ID:	2292220   Click image for larger version
ID:	2292222   Click image for larger version
ID:	2292226   Click image for larger version
post #8 of 9 Old 10-03-2017, 06:43 PM
sirjaymz's Avatar
Quoted: 146 Post(s)
Liked: 80
Originally Posted by Luís Amaral View Post
Coming along very nicely. Are you planning on getting any RT60 readings with all the mineral wool on the wall?
You may want to add some diffusors into the room to give some ambiance to the surround, otherwise it may sound too dead.
Also, looks like you pulled the seating away from the back wall. Good Choice. Again, helps with the surround envelopment.
I like painted screen detached idea from the main wall. very clever. not sure about the led light on the floor on the short wall.
what's your hardware?
Where are the speakers?
Nice plan. Keep after it.
JAMES JONES
HT1.0 | HT2.0
sirjaymz is offline
post #9 of 9 Old 10-05-2017, 05:33 PM - Thread Starter
Liked: 0
Later I want to add some difusores, on front I have a custom speakers made by a friend of mine they have a excellent sound, on back and surround I have KEF KHT 2005.3 speakers, central is a B&W !!!
ID:	2293330   Click image for larger version
