Fidelio velvet - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BIGmouthinDC
post #1 of 16 Unread Yesterday, 01:21 AM - Thread Starter
Liked: 0
Red face Fidelio velvet
Where can i find fidelio black velvet?? I cannot find many sources online. Amateur building first home theater..
thanks
hardyravi is offline
post #2 of 16 Unread Yesterday, 05:32 AM
Quoted: 3422 Post(s)
Liked: 2887
http://www.voguefabricsstore.com/Fid...lack-1000.html
I don't use it unless a client has money to burn, I like Joanne's Royality 3 at 25% of the cost with a coupon.
post #3 of 16 Unread Yesterday, 07:13 AM
broomet's Avatar
Quoted: 13 Post(s)
I agree with Jeff. I just completed my front wall of the theater with that black velvet from JoAnn's. I compared the JoAnn's to some left over product from a previous theater where I used SyFabrics' Black Plush Triple Velvet. From what I could tell, they were the exact same product.
broomet is offline
post #4 of 16 Unread Yesterday, 09:25 AM
Liked: 2887
My past experience is that you can blow through the Joanne fabric (with force) not the Syfabrics. But products do change over time.
rboster likes this.
post #5 of 16 Unread Yesterday, 09:26 AM - Thread Starter
Liked: 0
Thanks Big and Broomet!! another question - I don't have AT screen. Do i still need to do entire screen wall with velvet.. or just around the screen?? and best way of applying the velvet.. i did see the velvet frames.. but how to get those frames on the wall.. apologies for the amateur questions..
post #6 of 16 Unread Yesterday, 09:31 AM
rboster's Avatar
Quoted: 974 Post(s)
Liked: 892
This is the on-going resource to combative light and reflections in an HT
"Black" Theater Improvment Thread (Once you go black you never go back?)
A lot of examples of making one's own panels, which velvet ppl prefer, where to buy etc etc. Paint etc is also discussed at great length.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
post #7 of 16 Unread Yesterday, 10:01 AM
Liked: 2887
do panels around the screen, attach with Velcro just like this:
My New Home Theater 2.0, Staggered Wall HT.
post #8 of 16 Unread Yesterday, 10:12 AM
DaveClement's Avatar
Quoted: 199 Post(s)
Liked: 87
You don't need velvet behind the screen if you can't see it, but you should paint the wall flat black. If the wall behind the screen is white or light colored, and there is any gap between the screen and the wall, light will pass through the fabric and bounce off the wall, washing out the blacks and lowering your contrast ratio.
DaveClement is offline
post #9 of 16 Unread Yesterday, 10:48 AM
Quoted: 101 Post(s)
Liked: 58
My screen was close enough to the ceiling and side walls that I simply wrapped the velvet around Vertical 2X10's and a horizontal 2X6.
Jerry
Fairbanks, Alaska
DIY In Progress Home Theater Build: http://www.avsforum.com/forum/19-ded...tic-build.html
Star Ceiling Build: http://www.avsforum.com/forum/19-ded...am-boards.html
arcticbowman is offline
post #10 of 16 Unread Yesterday, 11:12 AM
Quoted: 40 Post(s)
Liked: 4
Is the Joanne's fabric AT?
Beams37 is offline
post #11 of 16 Unread Yesterday, 11:47 AM
Liked: 2887
not enough for anything other than being placed in front of Subwoofers.
post #12 of 16 Unread Yesterday, 03:04 PM
Quoted: 40 Post(s)
Liked: 4
That's what I thought you would say. I guess I will be sticking to the original plan of GOM.
Beams37 is offline
post #13 of 16 Unread Yesterday, 07:40 PM - Thread Starter
Liked: 0
Thanks Guys for the quick reply's..
BIG how thick are the frames in the pic?? and what are they made of??
post #14 of 16 Unread Yesterday, 08:45 PM
Liked: 2887
post #15 of 16 Unread Yesterday, 09:49 PM
Quoted: 101 Post(s)
Liked: 58
Not the velvet that the OP posted about, but I just went to JoAnn's today to pick up some more Royalty 3 velvet. They only had a few yards left, and when they looked it up, it showed that it was being discontinued and they wouldn't be getting any more. They did not know if there was going to be a replacement for it.
Jerry
Fairbanks, Alaska
post #16 of 16 Unread Yesterday, 10:24 PM - Thread Starter
Liked: 0
Thanks Arctic for the tip!! Thanks Big!! More questions coming in!!!
