Column dimensions?? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By jimmyk36
  • 1 Post By Jer123
post #1 of 7 Old 09-13-2017, 03:54 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 170 Post(s)
Liked: 81
Column dimensions??
I'll be building my columns tomorrow that will house the in-wall surround speakers as well as a sconce on each. Just curious to know.... what are the dimensions of your columns? Width? Depth? Pictures??
It may not be your job, but perhaps it's your opportunity.
MPJ's theater build: http://www.avsforum.com/forum/19-ded...ter-build.html
mpjmeyer is offline
post #2 of 7 Old 09-13-2017, 04:11 PM
jimmyk36's Avatar
Quoted: 89 Post(s)
Liked: 41
Mine are 6" x 14" (additional 2" spacer from the wall) using 3/4" MDF with Triad Inwall speakers.
Each of the 6 columns have speakers in them. The front two on the side walls act as the "wide" speakers, the rear two on the side walls are the "surround - left and right", and the two columns on the rear wall are the "Rear Surround" channels.
I built the columns out of 3/4" MDF and used Titebond glue and Kreg Jig Pocket Holes to hold them together. After the glue dried for a day I removed the screws from the pocket holes so I could use a router to round the edges. The screws were too long and would have hit the router bit. The glue holds just fine on its own.
The total column dimensions are 14" wide by 6" deep. I had to mount them 2.5" off the wall for the front wide speakers as the In Ceiling speakers I used as the wides are about 7.5" deep. The columns on the rear wall were also moved out so they would be flush with the two Monster Bass Traps from GIK Acoustics.
Kreg Jig Pocket Holes to hold together until the glue dries:
Jigsaw cutouts for the Triad in wall surround speakers:
Part of the assembly line:
Painted Mouse Ears Black
Triad In-Wall Surround added:
Triad In-Wall Speaker Grill Added - HOPE IT DOESN'T SHOW UNDER THE DMD BLACK FABRIC!!!!
Original "Built in" Column Location - DO NOT BUILD YOUR COLUMNS UNTIL AFTER THE DRYWALL STAGE - Build them separately....
Luckily it was very close to where I needed it to be. But I did have to make the opening bigger to fit the Triad Speaker:
View of the Triad In-Wall Surround attached to the Column:
YAY!!! - The White Grills don't show through the DMD Black Fabric! Looks like I probably didn't need to paint the columns black either!!! Oh Well - at least I know the paint is there This is installed over the original drywall column:
Rear columns flush mounted with the GIK Monster Bass Traps. I joined two Monster Bass Traps together and covered with DMD Maroon Fabric:
View of the back of one of the the "wide" speaker columns. Still need the DMD fabric stretched and stapled in place:
mpjmeyer likes this.
jimmyk36 is online now
post #3 of 7 Old 09-13-2017, 06:08 PM
brazensol's Avatar
Quoted: 197 Post(s)
Liked: 56
There is also a thread in the sticky "show me" thread that might help.
brazensol is offline
post #4 of 7 Old 09-13-2017, 08:25 PM
Liked: 3
I went with 18"x6"...
At first I thought they were too wide, but after dressing them up with trim, I think they look great.
Jer123 is offline
post #5 of 7 Old 09-13-2017, 11:53 PM
Elill's Avatar
Quoted: 109 Post(s)
Liked: 91
I build mine as half rounds with a shelf in them so I could angle the surrounds to an idea position relative to the MLP....not the sort of work you can get done in a day though, it was a big job
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #6 of 7 Old 09-14-2017, 02:08 AM
LydMekk's Avatar
Quoted: 39 Post(s)
Liked: 36
Elill, I agree. Will build mine deep enough so I can rotate the speakers slightly so all surrounds points directly toward the MLP.
"If everything is under control you are just not driving fast enough"
LydMekk is offline
post #7 of 7 Old 09-15-2017, 10:23 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 170 Post(s)
Liked: 81
Thank you for the responses, I ended up going 15" wide and 6" deep with the columns....check out my build thread for pictures
mpjmeyer is offline
