Is a 11.5" walkway do able? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 09-19-2017, 08:47 PM - Thread Starter
bruin27's Avatar
So my room is narrow, 10', the furniture I want to get will eat up most of that width and will leave me with 11.5" on each side... I personally don't think I'll mind but wanted to see if anyone here has a similar spaced walk way in their room?
bruin27 is offline
post #2 of 16 Old 09-19-2017, 09:26 PM
LydMekk's Avatar
Quoted: 67 Post(s)
Liked: 45
Should you not consider skipping one seat at each row to get more space?
You know its too narrow to traverse
"If everything is under control you are just not driving fast enough"
Home Theatre Heaven in Spain - V2.0 - Build thread
LydMekk is offline
post #3 of 16 Old 09-19-2017, 09:27 PM - Thread Starter
bruin27's Avatar
It's a sofa I'm putting in, not theater seats.
bruin27 is offline
post #4 of 16 Old 09-19-2017, 09:33 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2165 Post(s)
Liked: 981
  • Get used to the idea of jumping over the Couch.....or,
  • A lot of butt rubbin' on the walls
MississippiMan is offline
post #5 of 16 Old 09-19-2017, 09:37 PM - Thread Starter
bruin27's Avatar
Yea figured that haha...
bruin27 is offline
post #6 of 16 Old 09-19-2017, 11:19 PM
UK Dreamer's Avatar
Quoted: 127 Post(s)
Liked: 111
Why not push the sofa to one side, then you'd have a single 23" wide walkway?
I'm all for symmetry myself, but sometimes compromises have to be made.
UK Dreamer is online now
post #7 of 16 Old 09-19-2017, 11:19 PM - Thread Starter
bruin27's Avatar
I was thinking that also, I'll play around with it when the sofa gets here
bruin27 is offline
post #8 of 16 Old 09-20-2017, 05:30 AM
Spyderturbo007's Avatar
Quoted: 201 Post(s)
Liked: 80
This what I had to do because of my limited width. I was initially hesitant due to the lack of symmetry, but I think it looks nice that way. The only downfall is that the guy on the end gets to eat the surround speaker.
Spyderturbo007 is offline
post #9 of 16 Old 09-20-2017, 08:01 AM - Thread Starter
bruin27's Avatar
How wide is your room?
bruin27 is offline
post #10 of 16 Old 09-20-2017, 09:28 AM
NickTheGreat's Avatar
Quoted: 434 Post(s)
Liked: 307
You shouldn't go less than 24". 18" at the minimum. I'd do it off center since it's a couch and not seats.
NickTheGreat is offline
post #11 of 16 Old 09-20-2017, 09:43 AM
Quoted: 3898 Post(s)
Liked: 3333
I think jumping over the couch is a perfectly acceptable solution.
post #12 of 16 Old 09-20-2017, 09:45 AM
Liked: 3333
post #13 of 16 Old 09-20-2017, 09:46 AM - Thread Starter
bruin27's Avatar
Or
Haha these are great... I've got 4 kids so I'm sure it'll be more like the first gif
bruin27 is offline
post #14 of 16 Old 09-20-2017, 09:47 AM
Mistere311's Avatar
Quoted: 26 Post(s)
I have the similar dilemma, my room is 130 inches wide. I settled on a 100 inch wide theater row, and will be shifting it to allow for 30 inch walkway. The armrest on the seat closest to the wall is 5 inches I think, but the seat will have the surround speaker close to the ear. It was a compromise I had to make based on the room. My vote is to shift the sofa to allow for egress. To visualize it, use some tape on the floor or tall boxes to mock-up what your actual experience will be like.
Mistere311 is offline
post #15 of 16 Old 09-20-2017, 09:47 AM
DaveClement's Avatar
Quoted: 279 Post(s)
Liked: 185
Less than a foot on either side would be pretty awkward to get by. Try putting furniture that you have of a similar height that distance from a wall and give it at try, even if it is just a kitchen chair. You should be able to squeeze by, but it probably wouldn't be practical for 'everyday" use.
If you don't plan to fill every seat with every movie, putting the couch against one wall and sitting at the other end and in the middle section will probably be ideal, since both of those positons will likely be close to the L/R center of the room.
On those occasions where you want to fill the entire couch and don't want to force anyone to sit close to the wall, slide it over a foot for movie viewing and slide it back again when you are done.
DaveClement is offline
post #16 of 16 Old 09-20-2017, 10:06 AM
Liked: 981
Or
Swinging?
.........or this might work?
