Best lights for dimming - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 46 Old 09-21-2017, 06:02 PM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Im at the lighting phase of my room. I enjoi lighting dimmed down to the equivilent of an old 6watt candle light, all the way up to task lighting for working and cleaning up.
I F'ing hate noise, i seem to have a better ear for that Lol, and with that in mind, whats the quietest dimmable bulb.
My budget could be $200 for dimmer, and four lights at the peak of my vaulted ceiling, the vault line goes from front to back, the peak is 18" above the 8' point of the side walls. Room is painted dark brown, i've heard some bulbs react to different colors painted, not sure if that matters, or if its true.
Edison bulbs are probably the coolest light i've ever seem, there are sooooo many to choose from, just throwing that out there.
KG
Is it also a dimmer issue inregards to buzzing and noisy lights or is it always the bulb ????
kgveteran is offline
post #2 of 46 Old 09-22-2017, 04:37 PM
Quoted: 16 Post(s)
Liked: 5
With respect to Zigbee LED bulbs (where you can individually dim them), the only ones I've found so far with zero noise when dimmed are the Philips HUE. They also dim very nicely down to 3% or so. These don't require a dimmer switch..it's all done via the HUE app, or whatever automation hub you have the HUE hub connected to. I've been putting as many as 10 of these on a switch (it's only 90 watts all in for 10 bulbs) and then using automation and motion to decide which come on, when and at what power. For example, in night mode, you can choose to have only 2 of 10 come on, dimmed to 10% so late night wandering doesn't light the place up like Christmas.
Buzzing bulbs when dimmed drive me crazy.
My kids love the HUE lights too as they can be individually controlled by various HUE apps which will strobe and randomly flash them in sync to music as sampled by the mic on their iOS devices. Cheapest cool disco ever if your kids will be using the theater for parties etc.
dennwood is offline
post #3 of 46 Old 09-22-2017, 04:51 PM
8mile13's Avatar
Quoted: 1748 Post(s)
Liked: 1022
Dimmers can be noisy. Be also aware that subtle dimming is not something all dimmers can do.
I use dimmers now for 20 or so years. I bought and use these which are very cheap, 10 euro or so..no noise and subtle dimming. I had more expensive ones but at some point they stopped doing the subtle dimming so no more minimal dimming out of those.
8mile13 is online now
post #4 of 46 Old 09-22-2017, 08:12 PM
texpilot's Avatar
Quoted: 170 Post(s)
Liked: 81
UK Dreamer recommended the Philips R20 Warm Glow bulbs so I got some and they dim really really low with my Insteon dimmer. I mean really, really dim with no flickering and no buzz.
I wanted to use Insteon dimmers because they have the IRLinc kit to allow converting IR signals to send Insteon commands. I admit I haven't gotten to the point of setting that up yet but I'm hopeful that will work as planned. At least the Philips Warm Glow R20 has worked well.
UK Dreamer likes this.
texpilot is offline
post #5 of 46 Old 09-22-2017, 08:51 PM
LydMekk's Avatar
Quoted: 66 Post(s)
Liked: 43
Philips Hue is very good at low lvl dimming.
More expensive, but they work.
"If everything is under control you are just not driving fast enough"
Home Theatre Heaven in Spain - V2.0 - Build thread
LydMekk is offline
post #6 of 46 Old 09-22-2017, 09:27 PM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Has anyone had luck controling these bulbs with an Amazon echo Dot, or other voice recognition devices.
I would only use the Dot or other device in my Hometheater, lights only! Your thoughts ????
I think this would be cool.....
post #7 of 46 Old 09-22-2017, 11:07 PM
8mile13's Avatar
Liked: 1022
I actually have two lamps using philips R39 which come close to candles afaik..but i only use those in the main room in the evening. So not for a theater....
post #8 of 46 Old 09-23-2017, 12:36 AM
holl_ands's Avatar
Quoted: 573 Post(s)
Liked: 252
I use PHILIPS (do NOT substitute other brands) BT15 Series [e.g. 95-100 W, 150W) Halogens in Living Room....TWO in one Lamp on Maestro IR Dimmer [Lutron Switch Type], and another one in a second Lamp with a Manual Dimmer. ZERO noise and very linear dimming to VERY low, levels with NO flickering. Bright WHITE Light for Reading....easy on the eyes Yellowish when Dimmed to moderate levels.....and dim down to just one or two candles worth of light.
I also have Philips LED 15W (actual) Floodlights on compatible Dimmer with adjustable Low Light Level (to minimize Flickering]....but they NEVER get very dim.....
https://www.amazon.com/Philips-24933.../dp/B002DR1RXM [150 W Equiv.]
I see that many Philips bulbs with different watt ratings in the BT15 Series are Discontinued.
You might want to try OTHER Halogen bulbs (incl PAR type) made by Philips.
holl_ands is offline
post #9 of 46 Old 09-23-2017, 06:49 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Im beginning to see a trend, Philips seems to be a common bulb, Totally unrelated now that i think about it, i built my own home 17 years ago and my new fixtures came with philips bulbs, they lasted forever!
I really like the idea of the amazon dot controling the floods, any idea's now that the bulbs seem to be Philips, or even i nice i.r. Controled dimmer........
post #10 of 46 Old 09-23-2017, 08:48 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
The plot thickens..... Seems the Lutron Maestro (i bought a used one, $19 Ebay) MIR600 isnt compatable with LED's......almost :0(
Its the load that is to light. Seems the Maestro needs 40watt load to work properly, thats why guys throw in an incandesent light to bump up the load in a stream of lights.
So, now im onto bulbs and how to fly em. I made a wooden chase along the peak of my vaulted ceiling to run wires. Its about 10" wide and goes from my PJ to the front of the room. PERFECT to mount pucks to, but puck lighting is for under cabinets in kitchens, not sure that translates well to my HT.
I may need to fabricate some outlets, any thoughts
post #11 of 46 Old 09-23-2017, 08:54 AM
texpilot's Avatar
Quoted: 170 Post(s)
Liked: 81
Any reason you wouldn't just buy a different dimmer??? I had a Maestro in my theater for years until starting my theater renovation, and it sucks at dimming LEDs: they only dim down to like 20% before flickering and the cutting off. Same bulbs with the Insteon dimmer dim waaaaay down.
Point is if puck lights are the best fit for your ceiling situation, don't let your Maestro dimmer be the deciding factor.
You can get an Insteon remote, both simple and one that supports scenes.
texpilot is offline
post #12 of 46 Old 09-23-2017, 09:12 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Ok, checked them out, about $50, but does it come with a remote like the Lutron, im not understanding the method, i.r. commands. my friend has app control over his lights and im not a fan. simple i.r. commands work just fine for me.....
I still have a Harmony 1100 :0/
post #13 of 46 Old 09-23-2017, 09:13 AM
texpilot's Avatar
Quoted: 170 Post(s)
Liked: 81
Remote is an additional cost. You can also buy the Insteon Hub for $65 and use your smartphone as the remote.
texpilot is offline
post #14 of 46 Old 09-23-2017, 09:18 AM
KBMAN's Avatar
Quoted: 339 Post(s)
Liked: 170
I use 2 old LUTRON dimmers (circa '02?), on incandescents no less...I can't stand LED (although I have some LED Flood lights on my house). These old LUTRONS (I forgot the model #) will not work with LED...and it's analog all the way, i suppose. I learned the remote codes from the controller, and have it in my Harmony and URC, which is another primary reason I still use them. IR controlled btw. NO NOISE, SUPER LOW DIMMING...'Winning' lol...
KBMAN is offline
post #15 of 46 Old 09-23-2017, 09:19 AM
KBMAN's Avatar
Quoted: 339 Post(s)
Liked: 170
In fact, At first, I had all LED in my theater, and switched over to the old school, just to let you know.
KBMAN is offline
post #16 of 46 Old 09-23-2017, 09:30 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Ok.... so lets say I want (4) lights running front wall to back wall, looks like the dimmer and a remote will work fine, but without the hub, its all on, all dim, and all off ??
post #17 of 46 Old 09-23-2017, 09:43 AM
texpilot's Avatar
Quoted: 170 Post(s)
Liked: 81
I believe that would be the case, yes. I'll go look at the manual for the remote when I can to see if it supports scenes.
But know that with just one circuit powering all the bulbs, the bulbs will all be controlled together in this case, as you're using a Smart Dimmer, versus individual Smart Bulbs (which are a lot more expensive).
If you really want individual bulb control on a single circuit, the Philips Hue is the way to go. They make a remote as well, but it doesn't look like it has scenes, and there's no way to control it via IR (which I really need for my theater), so I skipped it.
But the Hue really does look like an awesome system, but it's quite expensive.
texpilot is offline
post #18 of 46 Old 09-23-2017, 09:44 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
don't get me started Lol, im ready to go on the DarkWeb for incondecent outlaw 100watt bulbs hahahaha
brazensol likes this.
post #19 of 46 Old 09-23-2017, 09:48 AM
texpilot's Avatar
Quoted: 170 Post(s)
Liked: 81
Try the Philips Warm Glow ... with a good (modern) dimmer, they dim so low your eyes take a while to adjust to the light level before you can see again, its that dim. Just don't expect that with an old or incompatible dimmer (like a Maestro).
texpilot is offline
post #20 of 46 Old 09-23-2017, 09:48 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
But know that the bulbs will all be controlled together in this case, as you're using a Smart Dimmer, versus individual Smart Bulbs (which are a lot more expensive).
Thanx for all ur help, looks like as long as I can get em dim enough I have no problems, $50 for the dimmer, $39 for the remote, and then its What bulbs to use, plain vanilla LED no built in dimmers.
post #21 of 46 Old 09-23-2017, 10:50 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Are they cool to the touch ?
and another thing, the wiring diagram shows a black,red,white, bare. Are the black and red, the in and out of hot ? Dimmable SPST kinda
post #22 of 46 Old 09-23-2017, 11:20 AM
texpilot's Avatar
Quoted: 170 Post(s)
Liked: 81
I'll leave one on a while and get back to you.
Not sure what you mean by "dimmable SPAT kinda." Insteon can be controlled via a smartphone or the hub, so it needs an "always on" wiring scheme.
For the incoming power line: black to black, White to white, bare to ground. On the outgoing power line (from the dimmer to the lights): black goes to the red on the dimmer, White to white, bare to ground.
So yes, the black and red are the in and out of the hot wire, respectively. You got it!
texpilot is offline
post #23 of 46 Old 09-23-2017, 11:48 AM
holl_ands's Avatar
Quoted: 573 Post(s)
Liked: 252
I also learned an expensive lesson...NO, IR controlled Lutron Maestro MIR600 [aka "Spacer" when bundled with R/C] is NOT Compatible with LEDs (and probably also LCDs)....but they work fine for Halogen & Old Incandescent Bulbs. And for Ceiling Fans, only use Dimmers that are LABELED for Fan Use.
http://www.lutron.com/en-US/Products.../Overview.aspx
https://www.amazon.com/Lutron-600-wa.../dp/B000JJYJMM [Spacer Kit with IR R/C]
https://www.amazon.com/Lutron-MIR-60.../dp/B003Z8VWLK [Just the Dimmer]
https://www.amazon.com/Lutron-Dimmer.../dp/B000MBKNM2 [4 IR Switch Group]
http://www.lutron.com/en-US/Products...er/Models.aspx [IR Group uses "Companion" Dimmers]
Kits (only) also found at Home Depot (etc).....and shop around for best price.....
Lutron Dimmer IR codes are on Harmony Website, but back when I did it, I had to manually enter the BRIGHTER and DIMMER codes via Learning Feature.....holding down the UP/DN Buttons on the Spacer R/C for several seconds at a time.....with numerous retries until I got it to output IR Codes for as long as I held down the Harmony buttons.
PS: I would be interested if anyone finds an AFFORDABLE IR Controlled Dimmer....whether for Lutron Switch Plate like Maestro...and preferably OTHERWISE that I can use with my Floor Lamp....so far, this is all I found in a quick search:
https://www.varilight.co.uk/dimmers/v-plus-ir.php [Varilight IR Series]
https://www.varilight.co.uk/dimmers/...s-for-leds.php [Varilight IR Series for LEDs]
https://www.varilight.co.uk/configur...p?code=ISI601M [Varilight IR Series Example]
https://www.varilight.co.uk/dimmers/...y-v-pro-ir.php [Varilight IR Series Compatibility List]
http://www.insteon.com/ [Insteon IR et.al. R/C SYSTEM]
https://www.smarthome.com/switchlinc...and-white.html [Insteon Example]
The ONLY way to make sure a PARTICULAR LED/LCD Bulb is Compatible with a PARTICULAR Dimmer is to check the manu's Compatibility Lists to ensure that EITHER the Bulb or the DIMMER mfr has actually conducted a Successful TEST, see my fol. post:
http://www.digitalhome.ca/forum/202-...ml#post2881394
http://www.lutron.com/TechnicalDocum...st_Maestro.pdf [Latest Lutron LED/LCD Dimmer Compat. List]
http://www.usa.lighting.philips.com/...tibility-guide [Latest Phillips Bulb Compat. List]
Forgot to mention: GE Halogen's were NOISY when dimmed....the filaments were NOT mounted very well.
post #24 of 46 Old 09-23-2017, 03:17 PM
texpilot's Avatar
Quoted: 170 Post(s)
Liked: 81
They are. Left it on at full power and barely any warmth at all. Mind you these are just 60 watt R20 bulbs though.
texpilot is offline
post #25 of 46 Old 09-23-2017, 03:58 PM
mbarland's Avatar
Quoted: 16 Post(s)
I'll echo what some others have said. For any LED lighting, I've found that Philips are by far and away the best. I have a few different models around, since the technology changes. They dim nicely, but nothing will dim like an incandescent (or halogen failing that).
I use Insteon dimmers with Philips LED bulbs in every fixture of the house EXCEPT my theater. Nothing can (yet) compare to the subtle glow of an incandescent dimmed to around 5%. At this point all the LEDs, with regards to dimming, seem to have compromises. And some randomly buzz, but none of the Philips bulbs I've tried buzz. The other manufacturers, it's hit and miss, even within the same model.
mbarland is online now
post #26 of 46 Old 09-24-2017, 06:35 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Thats good to know. I checked out ur build thread btw, nice build.
post #27 of 46 Old 09-24-2017, 08:06 AM
texpilot's Avatar
Quoted: 170 Post(s)
Liked: 81
Thanks, I've been stymied held up by an issue that I'm finally moving past. I hope to post an update tonight after this weekend's progress.
texpilot is offline
post #28 of 46 Old 09-24-2017, 11:19 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Yup, a work in progress. I built a 600lb door to close off my room from the rest of the house, and i know what its like to move on to other phases.
post #29 of 46 Old 09-24-2017, 03:56 PM
KBMAN's Avatar
Quoted: 339 Post(s)
Liked: 170
Yeah, that's what I have..2 Lutron Meastro SPACERS....Running 50 watt mini floods in my theater. Spacer #1 is at the front of the theater, while Spacer #2 is at the back...that way I can just lean back and beam my remote to the back of the room, to control them. Works Great! Heat is way more obvious in my theater, but the lights aren't on during movies..
KBMAN is offline
post #30 of 46 Old 09-24-2017, 04:00 PM
KBMAN's Avatar
Quoted: 339 Post(s)
Liked: 170
and I bought some LED wall-adhesive light motion sensors (2 of em) which work wonderful when someone gets up and walks to the back of the room...namely ME, when I go to the beer fridge
KBMAN is offline
