RGB LED in long runs! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 09-22-2017, 02:38 PM - Thread Starter
jer181's Avatar
Quoted: 88 Post(s)
Hello,
What is everyone doing to run longer strips of RGB LED's?
I have 2 runs at 23ft and want to use one power supply to connect the bulkheads on either side of the room.
jer181 is offline
post #2 of 20 Old 09-22-2017, 02:43 PM
LydMekk's Avatar
Quoted: 69 Post(s)
Liked: 48
Philips Hue sells converters from normal CAT5/6 to their connector strips, aka you can run network cable from the transformator to a point further along your ceiling and connect the next light strip there.
"If everything is under control you are just not driving fast enough"
Home Theatre Heaven in Spain - V2.0 - Build thread
LydMekk is offline
post #3 of 20 Old 09-22-2017, 02:43 PM
mpjmeyer's Avatar
Quoted: 211 Post(s)
Liked: 135
I started a thread in regards to this exact same question..ended up getting a 65ft. kit from hitlights.com that comes with a 150 watt power supply, you can see it on post 81 of my theater build. My plan is to run 2 different directions around the theater so they meet on the opposite side of the room. hitlights.com also sells their components separately
What LED strips do you guys use for long runs??
It may not be your job, but perhaps it's your opportunity.
MPJ's theater build: http://www.avsforum.com/forum/19-ded...ter-build.html
mpjmeyer is online now
post #4 of 20 Old 09-22-2017, 03:11 PM - Thread Starter
jer181's Avatar
Quoted: 88 Post(s)
Your using 2 separate power supplies though? I only have an outlet on one side of my room up in my soffit.
jer181 is offline
post #5 of 20 Old 09-22-2017, 03:22 PM
mpjmeyer's Avatar
Quoted: 211 Post(s)
Liked: 135
No, only using 1 power supply which will be plugged into an outlet that I as well installed in my soffit. The power supply allows 2 separate runs to be connected to it which will travel in opposite directions....like this:
post #6 of 20 Old 09-25-2017, 03:21 PM - Thread Starter
jer181's Avatar
Quoted: 88 Post(s)
Attachment 2286614
I understand now. Yes, I'll just have to try and daisy chain them. Hopefully 46ft isn't too long or I don't know what I'm going to do
jer181 is offline
post #7 of 20 Old 09-25-2017, 03:27 PM
mpjmeyer's Avatar
Quoted: 211 Post(s)
Liked: 135
You should be fine, I'll be running about 50' of led's....25' in each direction. Before I placed the order, I called to confirm everything would work and they said I would be fine doing that
post #8 of 20 Old 09-25-2017, 03:40 PM - Thread Starter
jer181's Avatar
Quoted: 88 Post(s)
I have tried to reach out to companies to ask that question and have not been able to get an answer.
What are you using for a power supply? RGB or RGBW lights too?
jer181 is offline
post #9 of 20 Old 09-25-2017, 04:14 PM
mpjmeyer's Avatar
Quoted: 211 Post(s)
Liked: 135
I've never had an issue getting ahold of hitlights, they were very supportive which I always appreciate in a company.
Here's the kit I purchased: https://hitlights.com/collections/le...nt=42899648324
Comes with this 150 power supply: https://hitlights.com/collections/le...-150-350-watts
post #10 of 20 Old 09-26-2017, 01:07 PM - Thread Starter
jer181's Avatar
Quoted: 88 Post(s)
thank you very much. Yes, its lists right on their web page that its good for up to 65ft runs.
Do you actually have it installed already?
jer181 is offline
post #11 of 20 Old 09-26-2017, 01:13 PM
mpjmeyer's Avatar
Quoted: 211 Post(s)
Liked: 135
Not yet, I'm hoping to start painting my theater either this week or next at which point I'll also be installing the crown molding around my soffit for the LED's
post #12 of 20 Old 09-27-2017, 06:47 AM
Moebius's Avatar
Quoted: 155 Post(s)
Liked: 91
In a daisy chain at 46 feet, you might see a light level drop at the end. Depends on a lot of factors including the quality of the LED strips and how much resistance they impart. However, if that occurs, all you'd need to do is run them parallel. Connect the first strip to the power supply and a set of wires to run to the second strip. If you have a parallel supply like mjpmeyer got, then you hook the lights to one and the wires to the other. Otherwise just attach together. Then the second set of lights get connected to the end of the wires rather than the first strip.
Remember, no matter where you go... You're not where you were anymore.
Moebius is offline
post #13 of 20 Old 09-27-2017, 07:37 AM
If possible, connect your LED strip (or strips) in one long ring, with both ends going back to the power supply. Now connect the positive of ONE end of the strip to the supply, and the negative of the OTHER end of the strip to the supply. You're not "double ending" the supply, you're feeding positive from one end and negative from the other.
Now as the LEDs get further away from the positive connection, they're getting equally closer to the negative connection. The overall length of copper for each LED is equal, so the voltage drop should be equal, with no visible dimming at the far end because effectively there is no far end.
Name:	LED wiring.png
mspritch is offline
post #14 of 20 Old 09-27-2017, 02:24 PM - Thread Starter
jer181's Avatar
Quoted: 88 Post(s)
That's just my issue. In order to run in parallel I have to take down the drywall on the ceiling and run another wire. Looks like its my only option. Either that or if I can get away with just daisy chaining them (one end only to the power supply and the other end would not come back to the power supply).
jer181 is offline
post #15 of 20 Old 09-27-2017, 11:04 PM
repeli's Avatar
Should be okish.
Depends on the strip, and also voltage. 24V should be easier for longer runs, because less ampers.
We have installed 8 meters with some dimming in other end. But this was many years ago. Worst case you get some dimming in far corner.
repeli is offline
post #16 of 20 Old 09-28-2017, 02:52 AM
Can you run a wire alongside the strip to take one or other side of the supply to the far end?
mspritch is offline
post #17 of 20 Old 09-28-2017, 07:44 AM - Thread Starter
jer181's Avatar
Quoted: 88 Post(s)
The only wire I have running across right now is the 4wire (red,blue,green,black) running across the room (on the far side of the room from the power outlet). It looks like no matter what I'll have to run another wire across to the other side of the room to power the other strip.
jer181 is offline
post #18 of 20 Old 10-14-2017, 03:04 PM
pwlong's Avatar
Hello,
I had the same situation as you -- long run of ~65 feet around the perimeter of a soffit.
After much research I decided that chaining up shorter strips was too much of a hassle, and I got a single solution made by LEDwholesalers.com. Wireless remote, color-changing with preprogrammed patterns, dimmable -- love it.
I tucked it up behind the crown molding running around the inside of the soffit box, and ran it through a conduit to stash the transformer and power supply in the mechanical room next door:
http://havingfunalongtheway.com/base...ater-lighting/
pwlong is online now
post #19 of 20 Old 10-20-2017, 02:33 PM - Thread Starter
jer181's Avatar
Quoted: 88 Post(s)
oh wow, they had something that ran 65ft off a single run of LED?? can you post the link to exactly what you bought?
I ended up running a RGB connector in the front of the room too so I hope that I can just run them in parallel off of one single power supply.
jer181 is offline
post #20 of 20 Old 10-20-2017, 10:53 PM
pwlong's Avatar
This one:
https://www.ledwholesalers.com/v2/in...earch=20206RGB
