Chair rail height? - AVS Forum | Home Theater Discussions And Reviews
 13Likes
  • 2 Post By BIGmouthinDC
  • 1 Post By Spyderturbo007
  • 2 Post By javeryh
  • 3 Post By BIGmouthinDC
  • 1 Post By Fazzz
  • 2 Post By UK Dreamer
  • 1 Post By javeryh
post #1 of 17 Old 10-05-2017, 05:46 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 208 Post(s)
Liked: 130
Chair rail height?
I'm going to install chair rail 35" from the floor. Did you install chair rail evenly around the entire theater or did you compensate for platforms and raise the trim from 35" from floor to 35" from riser also?
It may not be your job, but perhaps it's your opportunity.
MPJ's theater build: http://www.avsforum.com/forum/19-ded...ter-build.html
mpjmeyer is offline
post #2 of 17 Old 10-05-2017, 05:54 AM
Quoted: 3897 Post(s)
Liked: 3331
I've done it both ways. It depends a bit on the overall look of the theater and whether continuous design lines looks better than stepped up lines. If you are going to step it up you should do it where there is a break in the wall like a column rather than doing it in the middle of an otherwise flat section of wall. If you have low ceiling heights, stepping it up will make the rear of the room feel more cramped.
mpjmeyer and texpilot like this.
post #3 of 17 Old 10-05-2017, 06:10 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 208 Post(s)
Liked: 130
My ceiling is 8' tall with about a 12" riser. I drew the line evenly around the theater so I know where to paint and will probably just stick with that.
mpjmeyer is offline
post #4 of 17 Old 10-05-2017, 07:34 AM
Spyderturbo007's Avatar
Quoted: 201 Post(s)
Liked: 80
I did mine evenly all the way around the room. I didn't follow any "standard" measurement, just what I thought looked nice.
Not sure if this helps you visualize it or not.
craigmohead likes this.
Spyderturbo007 is offline
post #5 of 17 Old 10-05-2017, 09:36 AM
javeryh's Avatar
Quoted: 264 Post(s)
Liked: 221
I did the step up method with a break at the column.
javeryh is online now
post #6 of 17 Old 10-05-2017, 01:51 PM
BSHuff's Avatar
Quoted: 64 Post(s)
Liked: 66
The real question: Is the chair rail functional or decorative? Are you moving chairs on the riser and needing to protect the wall?
BSHuff is offline
post #7 of 17 Old 10-05-2017, 06:51 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 208 Post(s)
Liked: 130
100% decorative for me. Just started pinting today so I still could change my mind....but I'm thinking I'll keep it even...maybe.. what you guys think?
mpjmeyer is offline
post #8 of 17 Old 10-05-2017, 07:50 PM
Liked: 3331
you will never finish that theater if you go pinting all day, I like the straight lines.
UK Dreamer, texpilot and Mr. Sir like this.
post #9 of 17 Old 10-05-2017, 08:08 PM
Fazzz's Avatar
Quoted: 116 Post(s)
Liked: 75
I have low ceilings - just over 7' - so I kept my chair rails the same height all around. I'm about 31" from the carpet to the top of the chair rail. Based on a lot of research there isn't a hard and fast rule on height (about 28-32" from what I found) so I picked what felt right to me.
ID:	2293380   Click image for larger version
mpjmeyer likes this.
Fazzz is offline
post #10 of 17 Old 10-06-2017, 04:55 AM
Quoted: 201 Post(s)
Liked: 80
It's functional in my case, but not in the way you think. It's there to hide the transition from the black fabric to the red fabric. Without it, you'd see a million staples.
BIGmouthinDC likes this.
post #11 of 17 Old 10-06-2017, 06:07 AM
Liked: 3
I wanted the chair rail to be continuous without a break, but wanted a consistent height too. I did 28" around the room with a 7'9" ceiling.
Jer123 is offline
post #12 of 17 Old 10-06-2017, 07:24 AM
Quoted: 201 Post(s)
Liked: 80
I like your color choice. Purple and black was my other choice.
post #13 of 17 Old 10-06-2017, 07:41 AM
UK Dreamer's Avatar
Quoted: 127 Post(s)
Liked: 111
Constant height here - following the steps.
Name:	Cinema Build-1040624.jpg
ID:	2293510   Click image for larger version
Name:	Cinema Build-1040800.jpg
ID:	2293512   Click image for larger version
Name:	Cinema Build-1040832.jpg
UK Dreamer is offline
post #14 of 17 Old 10-06-2017, 05:54 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 208 Post(s)
Liked: 130
Now I'm considering raising the chair rail up with the riser. Only thing about mine is it wouldn't be a smooth transition since I have columns on the steps. One side of the column would be 35" from the floor and the other would be 35" from the riser....how would that look?
mpjmeyer is offline
post #15 of 17 Old 10-07-2017, 04:42 AM
Liked: 3
Chair rail height?
Thanks, I tried to match the burgundy and brown from Acoustimac's DMD material...
Jer123 is offline
post #16 of 17 Old 10-07-2017, 06:09 AM
javeryh's Avatar
Quoted: 264 Post(s)
Liked: 221
Get some painter's tape on the wall and see for yourself!
texpilot likes this.
post #17 of 17 Old 10-07-2017, 06:22 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 208 Post(s)
Liked: 130
After thinking about it, I'll probably keep it even. If I did a hard transition at the column, the chair rail would be all uneven and wouldn't look right.
mpjmeyer is offline
