Webb Theater Construction Pics - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #91 of 166 Old 08-05-2004, 11:33 AM - Thread Starter
patrickwebb's Avatar
Question .... did you staple around the wall outlets to secure the fabric, or did you only cut a hole in the material at the outlets for access? Also, will you sconces completly cover the opening, or are you planning on some form of trim?
I did staple around the wall outlet on the left wall and I am hoping that the wall plate will cover the staples. As i was doing it, i questioned if it would look ok, i will need to revisit the outlet and give you an answer on how it turns out. As to the sconces, I did staple there also, i plan on making the sconces large enough to cover them.
patrickwebb is offline
post #92 of 166 Old 08-05-2004, 11:52 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Patrick:
What is the screen size you settled on?
CPanther95 is offline
post #93 of 166 Old 08-05-2004, 12:14 PM
CptnRandy's Avatar
Two tone - all the way.
It will give you much more of a "floating" effect with the screen set into the screen wall - a sense of depth.
Randy
CptnRandy is offline
post #94 of 166 Old 08-05-2004, 12:35 PM - Thread Starter
Originally posted by CPanther95
Patrick:
96" diag
post #95 of 166 Old 08-05-2004, 12:47 PM
CalypsoCowboy's Avatar
I'd say two-tone as well.
All men are animals, some of us just make better pets.
Moose Drool Moovie Theater
CalypsoCowboy is offline
post #96 of 166 Old 08-05-2004, 12:57 PM
AaronNWilson's Avatar
I say go for all black fabric on the screen wall. The two tone so close to the screen would be too distracting imo. There's nothing that creates image punch like a completely black screen wall.
AaronNWilson is offline
post #97 of 166 Old 08-05-2004, 01:06 PM - Thread Starter
I played with some lighting enhancements, and here is low lighting shots that can kind of give you close to movie watching lighting...
2 tone...
http://thewebbspot.com/stl-web/galle..._dim.sized.jpg
black...
post #98 of 166 Old 08-05-2004, 01:09 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
another vote for black
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #99 of 166 Old 08-05-2004, 01:18 PM
DC_Steve's Avatar
Another vote for black here. This would move any potentially (more) reflective surfaces further out of the field of view. IMHO, this would give you a more immersive experience.
The Feynman Problem Solving Algorithm:
1) Write down the problem.
2) Think very hard.
3) Write down the solution.
DC_Steve is offline
post #100 of 166 Old 08-05-2004, 01:23 PM
AnthonyP's Avatar
black
AnthonyP is offline
post #101 of 166 Old 08-05-2004, 01:47 PM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Both look good if WAF is an issue - but I think Black gives a much more "picture floating" effect than the 2-tone which pretty much defines the screen area.
post #102 of 166 Old 08-05-2004, 02:16 PM
PamW's Avatar
Black!
Pam
PamW is offline
post #103 of 166 Old 08-05-2004, 03:17 PM
Anthony Cler's Avatar
Quoted: 12 Post(s)
Looks great!
What are your room dimensions?
Anthony Cler is offline
post #104 of 166 Old 08-05-2004, 03:22 PM - Thread Starter
Originally posted by Anthony Cler
Looks great!
Final dimensions after drywall and fabric end up being 19'4"X 13'4"X 7' 10" .
post #105 of 166 Old 08-05-2004, 04:01 PM
jeffelliott's Avatar
Count my vote for black!
jeffelliott is offline
post #106 of 166 Old 08-05-2004, 04:43 PM
audiman's Avatar
Quoted: 13 Post(s)
Liked: 26
Black also.
audiman is offline
post #107 of 166 Old 08-05-2004, 06:58 PM
Brett Wilson's Avatar
I vote for black too - as Cpt Randy said, it will give a much better impression of the image floating there.
- Brett
Brett Wilson is offline
post #108 of 166 Old 08-05-2004, 07:31 PM
CptnRandy's Avatar
Hard to tell from the photos - is there any space between the screen wall and the procenieum? Take a look at my construction photos and you can see they look pretty similar.
I'm strongly for a black screen wall, but the two tone on your procenieum.
Randy
post #109 of 166 Old 08-05-2004, 08:22 PM
PAP
PAP's Avatar
Black
Good, cheap, easy - pick any two.
PAP is offline
post #110 of 166 Old 08-05-2004, 09:27 PM - Thread Starter
Randy
Yes, Randy, there is about a 4" space.
post #111 of 166 Old 08-06-2004, 12:02 AM
Fireball's Avatar
I like the black also.
Fireball is offline
post #112 of 166 Old 08-07-2004, 07:05 AM
Carlton Bale's Avatar
Carlton Bale is offline
post #113 of 166 Old 08-09-2004, 12:22 AM - Thread Starter
Thanks to all for giving your opinions. I think i am going to temporarily put up the 2 tone and then watch some movie clips and then do the same test with all black. My wife is definitely pushing all black, but i just think the 2 tone will give it a nicer look without comprimising the movie viewing.
BTW, i had my htpc up and running this weekend, with full audio and it was so great to finally get a feel for what it is going to be like in a few more weeks. My daughter loved watching Nemo!
post #114 of 166 Old 08-09-2004, 05:38 AM
TurboDog1's Avatar
Another vote for black....The two-tone is a distraction to me, at least judging from your pics.
Great theater, BTW.
TurboDog1 is offline
post #115 of 166 Old 08-09-2004, 08:12 AM
AnthonyP's Avatar
It is your theatre and your choice (and if you are not sure, I guess that is the best way about it) but on a slightly different subject, I guess you are not showing this thread to your wife :)
AnthonyP is offline
post #116 of 166 Old 08-09-2004, 08:23 AM - Thread Starter
No, I told her that I asked for everyone's opinion on the matter. I value her opinion as well, but I hold all artistic control on this room. :D
post #117 of 166 Old 08-09-2004, 11:57 PM
skeets's Avatar
YEAH!!!, What he said.
"Get your hands out of my pocket"
skeets is offline
post #118 of 166 Old 08-10-2004, 10:17 AM
BigScreen's Avatar
Quoted: 279 Post(s)
Liked: 240
I'll throw my vote in for the two-tone up to the screen. From an aesthetic point of view, I think that the two-tone allows the screen to be part of the room without overwhelming it.
The dark shots were a good idea, since they illustrate how things may look when you're watching a movie.
Another idea is to perhaps find a happy medium between the two approaches and increase the amount of black on each side of the screen. I happen to like it the way you have it, but it's something to consider as an option.
Publisher - The BigScreen Cinema Guide
DTS:X Resources | Dolby Atmos Resources
Men and women range themselves into three classes or orders of intelligence; you can tell the lowest class by their habit of always talking about persons, the next by the fact that their habit is always to converse about things; the highest by their preference for the discussion of ideas. - Henry Thomas Buckle - historian and author
BigScreen is offline
post #119 of 166 Old 08-11-2004, 04:49 PM - Thread Starter
post #120 of 166 Old 08-11-2004, 08:04 PM
Charles R's Avatar
Liked: 541
Might try taking the two-tone in a foot or so on each side of the screen wall. This way there wouldn't be a wall divider which can look harsh and it might tie the headers in a bit without crowding the screen.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Closed Thread Dedicated Theater Design & Construction
