15 foot curtain rod - AVS Forum | Home Theater Discussions And Reviews
Old 03-17-2004, 09:47 AM - Thread Starter
Andrew Lillie's Avatar
Hi all,
I would like to hang some drapes or curtains across the wall that my screen is on. There are windows on either side of the screen and would like to have system where by everything is covered, or the curtains open to reveal the 100 inch screen, or open to the windows.
This means I need a continuous curtain rod / rail of about 15 feet. I can put a brace in the middle (also at the center of the top side of the screen).
I have searched for such a thing, but have had no luck.
My current solution is to tension a wire cable across the span, with a support in the middle. I will use turn buckles to make it very tight and run loops on the cable to hang the 9 foot or so curtains. There will be 4 panels of fabric, two on each side of the center brace. My biggest concern is sagging. It will be a lot of fabric hanging on the cable and the longest and the unsupported span is 7.5 feet.
Any other options. I am sure there must be since theaters etc have very long spans of curtains. Where does one find a really long curtain rail / rod and how much are they?
thanks
Andrew
_______________________
thread search terms for others: long curtain drape rail rod wire cable
Andrew Lillie is offline
Old 03-17-2004, 10:30 AM
HeyNow^'s Avatar
I used electric conduit. I think it comes in 10 foot lengths. You can add a coupler at each end and add short pieces to make up the 15 feet. It is supported by J hooks from the soffet.
HeyNow^ is offline
Old 03-17-2004, 10:31 AM
thebland's Avatar
Quoted: 1493 Post(s)
Liked: 847
I have a powered Makita drapery rod that can extend up to 18 ft. I installed it myself and comes with an IR remote control and a programmable timer. Very slick
check www.smarthome.com (search under makita drapery rod or motorized Makita, etc.)
or I purchased mine through Dennis Erskine here at AVS!
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
Old 03-17-2004, 11:38 AM
R_Willis's Avatar
http://www.continentalwindowfashions...averserods.htm
Here is a place that offers some pretty big curtain rods in a variety of setups.
Thanks go to Erik Farstad for the link.
R_Willis is offline
Old 03-17-2004, 12:03 PM
RIT
RIT's Avatar
Andrew, I used copper tubing (plumbing),its cheap and paintable.
Home theater on a budget.
RIT is offline
Old 03-17-2004, 04:01 PM - Thread Starter
Some great suggestions and links, thank you!
Andrew
