electrical box/clip for metal studs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-17-2004, 05:29 AM - Thread Starter
mich5's Avatar
I am using metal studs and need electrical boxes/clips for them. I went to local HD and they did not have what I needed.
Can I use piece of wood (2X4 10"-12") screwed to metal studs and put regular boxes and clips for wood? Will it be up to the code?
If not, I need to buy boxes/clips for metal studs. Where can I buy them and how are they different from the ones for wood?
Thank you.
mich5 is offline
post #2 of 8 Old 06-17-2004, 08:23 AM
Larry Fine's Avatar
Mich, the blue Carlon boxes with the metal bracket on the side are made to attach to steel or wood studs. You'll need a couple of sheet-metal or drywall screws for secure attachment.
You could also attach regular nail-on boxes to 1' pieces of 2x4, and then screw them to the studs, again with sheet-metal or drywall screws through the metal and into the wood.
The 1' of wood will give you room for a cable staple. Beyond the wood, you should secure the cable with wire-ties that hace screw-eyes and the afore-mentioned screws, or self-adhesive ones.
If the cable rund through holes in the metal, they must be protected with plastic "grommets" made for the purpose, and properly attached. Flex-enclosed cables don't require this protection.
Larry
www.fineelectricco.com
My system (new larger pix!)
Larry Fine is offline
post #3 of 8 Old 06-17-2004, 08:55 AM - Thread Starter
mich5's Avatar
Larry,
Thanks a lot for reply. One more question: do you have a picture (or website) of this wire-tie with screw hole? That's exactly what I was looking for and could not find at HD.
Thanks a lot for your help.
mich5 is offline
post #4 of 8 Old 06-17-2004, 10:48 AM
MikeWh's Avatar
I think it's more of an "eyelet" (rather than a "screw-eye"). AKA a "mounting head."
http://www.planetcableties.com/specialty_ties.shtml
I did a quick google search and found this supplier, but no pic (sorry):
http://www.rcgoptic.com/cwsupplies.html
(item CT-8SC)
Also, Nelco makes a screw mount for their ties:
http://www.nelcoproducts.com/shoppin...t=Screw+Mounts
or an anchor mount:
http://www.nelcoproducts.com/shoppin...+Anchor+Mounts
or a low-profile mount:
http://www.nelcoproducts.com/shoppin...+Profile+Mount
MikeWh is offline
post #5 of 8 Old 06-17-2004, 10:50 AM
Skyboss's Avatar
Skyboss is offline
post #6 of 8 Old 06-17-2004, 09:48 PM
Larry Fine's Avatar
How was that? I answered you by remote control, the same way my cats make the doors open. :D
Larry
post #7 of 8 Old 06-18-2004, 06:43 AM
MikeWh's Avatar
Larry, we are all but puppets in your remote control world. :D :D :D
MikeWh is offline
post #8 of 8 Old 06-18-2004, 11:15 AM - Thread Starter
mich5's Avatar
Thanks, all. I really get a lot of answers from this site and you guys (and gals) are great. Thanks for the help.
mich5 is offline
Closed Thread Dedicated Theater Design & Construction
