Fabric Frames - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 37Likes
post #451 of 1009 Old 11-08-2007, 08:31 PM
dth122's Avatar
Quoted: 25 Post(s)
Originally Posted by William Seaward View Post
Actually, there isn't any green in mine. I wonder if they changed the color?
Strange. If you go to post #28 in my thread (linked below), there are two fabric color samples pictures. The top was is was GOM is calling ultramarine. Doesn't look anything like what you posted. Maybe they changed it.
Interesting...
- Dave
dth122 is offline
post #452 of 1009 Old 11-21-2007, 06:43 AM
GB_KSU's Avatar
I am going to build a few frames for my father-in-laws room and had a question. This is not a dedicated theater and I will want to attach the frames snug against existing drywall. What is the best way to do this? Sorry if this is a repeat please just point out a post number.
GB_KSU is offline
post #453 of 1009 Old 11-21-2007, 09:08 AM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
GPowers is offline
post #454 of 1009 Old 12-30-2007, 02:40 PM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
I have been playing with MainLobby. Working on getting all the single button macro Done. Here is a sample screen:
More are at the Stargateunofficial web site
GPowers is offline
post #455 of 1009 Old 01-03-2008, 11:34 AM
T.Wells's Avatar
G-
Wow, I really am following your footsteps. I am currently finishing a fabric framed theater and also working on MainLobby control. I hope to automate my theater with as few button pushes as possible.
Your work on ML looks great. Did you design that scene yourself? I am using the 019's (a pic in my construction thread).
-T.Wells
T.Wells is offline
post #456 of 1009 Old 01-03-2008, 02:23 PM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
Originally Posted by T.Wells View Post
G-
-T.Wells
I checked out your construction thread, very nice room.
The elements were all done by a member (Dan Nay) on the Cinemar Forum. I just took all the pieces and rearranged them.
All the buttons are based on mapped macros, so the theater can be turned on and off with ONE button.
Tonight I'am going to start playing with the MLServer web server and see if I can start the theater up from my Apple iTouch. Should be fun.....
GPowers is offline
post #457 of 1009 Old 01-07-2008, 07:09 AM
T.Wells's Avatar
Thanks! The theater is still a work in progress. I hope to start the frames and finish the screen wall next month.
I have found the folks over on the Cinemar forum very helpful. I am starting to learn the software and looking to automate things based on variables. I just found out that DVDLobby reports the aspect ratio of each movie being played. I am thinking about automating my theater based on the single touch of the movie:
User picks movie on touch screen, software reports aspect ratio and then triggers ->
- Power up equipment (select proper inputs and load/play movie)
- Set proper lighting level
- Set placement of anamorphic lens (in vs. out)
- Provide and trigger proper screen dimensions
-T.Wells
T.Wells is offline
post #458 of 1009 Old 01-07-2008, 09:27 AM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
Over the weekend I got the new iPod Touch examples from Cinemar. Made a few changes and created three web pages for my iPod Touch.
Some one might say "oh Big deal". Well do not forget that these buttons on the iPod touch execute the same Mapped Commands that the Flash bases MainLobby does. So you get the the following advantages with the iPod touch:
1. Instant On , their is no boot time
2. Quick wireless connection
3. Small and light
4. Runs the same Command Maps as full version of MainlLobby
5. If you know how to create a web page it easy.
Moe photos of the iPod screens:
For me this is version 1 using the example from Cinemar. Cinemar also includes several JavaScript examples for accessing MLServer variables, screen refreshing and others.
GPowers is offline
post #459 of 1009 Old 01-18-2008, 07:55 AM
RobertR's Avatar
Quoted: 494 Post(s)
Liked: 660
Hi Greg, can you tell me how much liquid nails you used to attach the frames? Thanks.
RobertR is offline
post #460 of 1009 Old 01-18-2008, 09:09 AM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
A dab in each corner about 1.5 inches accross and a zig zag bead on all four sides.
GPowers is offline
post #461 of 1009 Old 01-18-2008, 03:07 PM
RobertR's Avatar
Quoted: 494 Post(s)
Liked: 660
RobertR is offline
post #462 of 1009 Old 01-18-2008, 05:39 PM
RobertR's Avatar
Quoted: 494 Post(s)
Liked: 660
Follwup question: Is there a specific reason for using poly batten on the upper frames instead of leaving them empty?
RobertR is offline
post #463 of 1009 Old 01-18-2008, 09:27 PM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
When is first started look at building a home theater, i started look at the cost of every thing i wanted to do. The acoustics were important so I started researching the cost of getting a Home Theater acoustic designer to plan, speck, draw and supervise the construction and finish of the theater.
At this point I had to make choice due to a limited budget. Do I want a real Home Theater or just a set of plans. It was that expensive to hire a professional. I'm not saying you should not hire a pro, I just could not afford one.
So i did the next best thing. I read anb learned as much as i could and copied what the pros were doing. I do not always know all the reasons why something was done. Just that the formula produced a better end product.
And the poly was one thing of that nature. As I recall the poly is done for acoustic reasons and to fill the void behind the GOM.
GPowers is offline
post #464 of 1009 Old 01-20-2008, 09:09 AM
RobertR's Avatar
Quoted: 494 Post(s)
Liked: 660
Thanks Greg. It's good to benefit from the experience of others.
RobertR is offline
post #465 of 1009 Old 02-01-2008, 11:13 AM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
Robert:
How is the progress or your theater coming? Are your frames up yet? Have you posted any photos of your progress?
GPowers is offline
post #466 of 1009 Old 02-08-2008, 06:42 AM
Carlton Bale's Avatar
I searched the sites previously mentioned in this thread for GOM fabric, but I can't find anything on either SilentSource.com or InterfaceFabric.com. Can someone recommend a place for ordering GOM fabric?
Carlton Bale is offline
post #467 of 1009 Old 02-08-2008, 06:45 AM
tradewinds's Avatar
Quoted: 16 Post(s)
fabricmate.com
A little difficult to navigate.
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
post #468 of 1009 Old 02-08-2008, 06:46 AM
aaron_hinni's Avatar
Bryan Pape (user bpape on this forum) at Sensible Sound Solutions is where I got mine. Fabricmate is another popular place to get it.
aaron_hinni is offline
post #469 of 1009 Old 02-08-2008, 06:52 AM
budk's Avatar
www.acousticalservices.com is another source.... although I have no personal experience with buying from them yet.
Bud
There is a solution to every problem.
2nd Run Cinema - A fabric frame theater
budk is offline
post #470 of 1009 Old 02-08-2008, 06:55 AM
chucky08016's Avatar
I think your link may be broken. Nothing is coming up.
chucky08016 is offline
post #471 of 1009 Old 02-08-2008, 11:04 AM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
here is the page on http://www.silentsource.com/fwallcoverings.html
Best thing is to use the GOM site to request samples, then call Silent Source
GPowers is offline
post #472 of 1009 Old 02-08-2008, 11:21 AM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
The GOM samples page is:
http://samplecenter.guilfordofmaine.com/
AKA: InterfaceFabric.com
GPowers is offline
post #473 of 1009 Old 02-10-2008, 02:21 PM
RobertR's Avatar
Quoted: 494 Post(s)
Liked: 660
I finally started to put my frames up:
Many thanks to Greg for all the knowledge he's shared in the thread!
RobertR is offline
post #474 of 1009 Old 02-10-2008, 02:45 PM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
Your theater is starting to look finished. I like the color that looks like a texture. Keep sending the pictures.
GPowers is offline
post #475 of 1009 Old 02-10-2008, 07:08 PM
garykagan's Avatar
Nice looking frames!!!
Gary Kagan
garykagan is offline
post #476 of 1009 Old 02-13-2008, 10:36 AM
judsonp's Avatar
I am planning to use Dazian Janus material to cover my frames. As I started to think about how I would put everything together I realized I might have an issue shooting a brad nail through the fabric to hold it on the wall while the liquid nails drys. Has anyone tried this? My concern is the janus is a tighter weave than the GOM and the nailer might leave a hole in where the nail went through. The weave is about the same as celtic and expo.
Judson
judsonp is offline
post #477 of 1009 Old 02-13-2008, 10:52 AM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
Judson
Someone else here on the forum built 1 x 4 wood runners that ran horizontally across the wall. He then attached Velcro to both the wood runners and the frames. The runners provided a more stable surface to attach and support the Velcro over trying to glue the Velcro to drywall. This technique would not require the brads.
GPowers is offline
post #478 of 1009 Old 02-13-2008, 12:38 PM
judsonp's Avatar
Thanks Greg!
judsonp is offline
post #479 of 1009 Old 02-19-2008, 10:26 AM
judsonp's Avatar
I, like many of you are always looking for ways to speed up the process of building frames. I found this picture on the web page woodzone.com. Looks like a pretty easy jig for building lots of frames.
Hope it helps!
judsonp is offline
post #480 of 1009 Old 02-19-2008, 11:54 AM - Thread Starter
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
If you do not want to build one Rockler has one:
Frame Clamp
GPowers is offline
