Riser Height Calculator - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #91 of 200 Old 07-25-2007, 10:58 PM
JustMike's Avatar
Quoted: 58 Post(s)
Liked: 63
SUPER cool! Thanks a bunch.
Mike Kobb
(Formerly "ReplayMike". These opinions are mine alone, and in no way reflect the opinions of employers past or present!)
"Mike's Money Pit" Build Thread
JustMike is offline
post #92 of 200 Old 08-01-2007, 09:18 AM
gnolivos's Avatar
Quoted: 358 Post(s)
Liked: 280
What's the general consensus on offset seating? I will have 3 front, 2 rear... not really sure how to take this into account when using the calculator. Im pretty sure I will need less height on the riser than if I had a 3+3 seating configuration, without the offset. With 3+2, the rear viewers will get to see between the front viewer's heads.
Thoughts?
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
post #93 of 200 Old 08-03-2007, 03:45 PM
gnolivos's Avatar
Quoted: 358 Post(s)
Liked: 280
No one care to comment? I figure this is something that needed further discussion!
Thoughts?
gnolivos is offline
post #94 of 200 Old 08-05-2007, 02:43 AM - Thread Starter
robbyc30's Avatar
I think there are a lot of variables that would be dependent on the type of seating you're using: couches, theater chairs, with or without arms, high or low backs. I think it's way too complicated for a simple calculator like this. Even if you get it all sorted out, what if the two people in front of you don't sit straight up in the middle of the seats, but both lean in towards the center? Unless you are really restricted with the riser height, I'd wouldn't count on seeing "through" the front row. Just my opinion.
Rob
robbyc30 is offline
post #95 of 200 Old 09-10-2007, 10:23 AM
miltimj's Avatar
Thoughts?
Unless your screen is narrow enough that it can fit between the two viewers' heads in front of you, they will be in the way regardless of seating configuration (3-3, or 4-3, etc). Their head will just be in the way at a different position along the bottom of the viewable image.
miltimj is offline
post #96 of 200 Old 09-18-2007, 11:07 PM
outcast_p's Avatar
Is there any posted info on the average hight of someones head/eyes on different seating?
Figure the average person is 5'10" or 6'.
The reason I ask is im limited on ceiling hight, and I want to go with as big of a screen as i can, but i would like to know what my options are for seating.
outcast_p is offline
post #97 of 200 Old 09-20-2007, 10:40 PM
trunks's Avatar
I don't think so, but if somebody wants to do the research I would post/link to it right on the calculator. I guess we could also collect it right here if people want to post their own measurements (standing height, seating manufacturer/model, seated floor to eye height, seated floor to top of head height).
Personally I think you can stick with the default numbers and it will work out pretty well. I mean it may never be perfect, but at least in your own theater you can ask tall people to sit on the back row. Of course I'm not very sensitive to this problem, so I know this won't work for everybody.
trunks is offline
post #98 of 200 Old 10-20-2007, 08:28 AM
Texas Tuck's Avatar
Very handy program. Thanks for saving me a few "steps".
Texas Tuck is offline
post #99 of 200 Old 10-20-2007, 01:00 PM
inky blacks's Avatar
Originally Posted by trunks View Post
IPersonally I think you can stick with the default numbers and it will work out pretty well.
Please explain to me why the "default number" for front row head height is 42", while the back row head height default number is only 36". Does that calculation presume children or midgets in the back rows? It makes a huge difference in riser height if you switch to using the same head height for front and back rows.
IB
inky blacks is offline
post #100 of 200 Old 10-20-2007, 04:01 PM
scottsol's Avatar
Quoted: 23 Post(s)
Liked: 27
Because the back row number is actually eye height, since the image needs to clear the front row heads but only needs to reach the back row eyes.
scottsol is offline
post #101 of 200 Old 10-20-2007, 04:03 PM
Originally Posted by scottsol View Post
Because the back row number is actually eye height, since while the image needs to clear the front row heads it only needs to reach the back row eyes.
Thanks. That makes sense.
IB
post #102 of 200 Old 11-01-2007, 05:45 AM
dbbarron's Avatar
Anyone having trouble with the calculator - seems to be hanging up on calculation - tried IE, Firefox and Safari (from different computers, networks and firewalls).
db
dbbarron is offline
post #103 of 200 Old 11-03-2007, 11:43 PM
trunks's Avatar
db
Seems to be working fine, but I'll take a more in-depth look at it tomorrow. The only thing I see in the error log are divide by zero errors (user input errors). I'll add some input verification and error handling so those can't happen anymore.
-Jake
trunks is offline
post #104 of 200 Old 11-16-2007, 08:26 AM
dbbarron's Avatar
Worked again for a few days and died. Sproadic (never had trouble in the past).
I've DLd the .xls file for now.
db
dbbarron is offline
post #105 of 200 Old 11-16-2007, 11:46 AM
MGNiko's Avatar
Great calculator, it confirmed my height idea of 12"
MGNiko is offline
post #106 of 200 Old 11-18-2007, 08:22 PM
trunks's Avatar
db
I added the input validation today. please PM me with the values you are submitting if you have any problems in the future. Also, please note that the URL changed for the calculator. I don't think this could be causing any problems, but I will probably let the old domain expire next year.
-Jake
trunks is offline
post #107 of 200 Old 11-21-2007, 10:23 PM
MGNiko's Avatar
How would one calculate for a 3rd row? Just make another equal to the 2nd row?
MGNiko is offline
post #108 of 200 Old 02-11-2008, 05:54 PM
Demetri99's Avatar
quick question, should my front row look up a little and my second row be looking dead center of the screen(with full view of screen as well) is this correct??
Do It Once, Do It Right & Never Do It Again.
Demetri99 is offline
post #109 of 200 Old 02-11-2008, 07:40 PM
tradewinds's Avatar
Quoted: 16 Post(s)
Good question. I am actually at this point also so this question could not have come at a better time. The way I look at it is that my first row will be the "premium" everyday seat so I will have the eyeballs in the middle of the bottom 1/3 of the screen, then using the riser height calculator, determine what the riser height should be for the second row to clear the heads of the first row.
My first concern is that my riser may need to be 14", so I'll have to use 2x12 instead of 2x10 or 2x8.
Second concern is if the screen is placed a bit higher for the first row to be looking up slightly, what would be the limit before neck strain sets in. I will have recliners in the first row and real theater seats in the back row.
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
post #110 of 200 Old 02-17-2008, 02:25 PM
Tyro's Avatar
Originally Posted by Cudak View Post
As mentioned earlier in this thread, good sightlines are the result of many variables which include riser dimensions. I still believe in a good drawing (in scale) instead of mathematical formulas. When you draw your floor plan, expand it to show a section through the room. Here is a typical sightline drawing without dimensions. You may of course simplify - the idea is to show the basic geometry.
You might want to change your web links. They lead to a sextoys site.
Tyro is offline
post #111 of 200 Old 02-19-2008, 03:15 PM
jstewperry's Avatar
I really appreciated the perspectives regarding riser height. We have just started our process for a 13Wx25Lx7.5H HT.
We originally had a 10'Wx7'Lx6"H riser for the second row roughed in when I realized that it may not be high enough for people in our 4 w/loveseat Pallisers to clear the first row of 4 w/loveseat Pallisers. My 92 inch diagonal screen has to be about 35 inches from the floor.
After seeing all of the commentary on this thread as well as the calculator, I expanded the riser to 12" with a 22" wide, 6" front step. This also leaves ample room to be on the top part of the riser before seating down (about 22" as well). I am glad I started with a decent sized 7' footprint. My wife thought I was obsessing and being overly anal about the whole thing.
Once my contractor made the change, it was clearly the right move. I will not have any issues seeing the full screen from the second row. I also ended up with just under 6'8" height from the riser to the ceiling.
Thanks again!
jstewperry is offline
post #112 of 200 Old 06-30-2008, 11:58 AM
rjduncan19's Avatar
Originally Posted by Harden View Post
Thanks. I missed that nuance.
What's the rule of thumb for a step? At what point is a step "too high" (i.e. you need an intermediary step before it). When I measure the steps in my house, it looks like they are between 6"-7" high.
Check your building codes (there is discussion on page 1 about this). Quick answer -- under 8" / step should be ok.
-Rick
rjduncan19 is offline
post #113 of 200 Old 07-02-2008, 01:39 PM
wwwdudeva's Avatar
Great tool! I was guessing I needed 12" and when I measured and punched the numbers into the calculator, it came up 11 5/16.
Thanks a million!
wwwdudeva is offline
post #114 of 200 Old 07-16-2008, 01:48 PM
bigbadbob's Avatar
Very cool program. Thanks for sharing.
RG
Klipsch Rocks!
bigbadbob is offline
post #115 of 200 Old 08-20-2008, 10:32 AM
BFI6603's Avatar
Just wanted to add my thanks to the rest. Used this calculator to determine my riser height and it worked beautifully to give me a riser height of 12". Showed a movie last night utilizing my new Berkline 099's...not a complaint out of anyone!
BFI6603 is offline
post #116 of 200 Old 11-16-2008, 07:18 PM
Ryked's Avatar
Just wanted to say thanks for the riser formula. Worked like a charm.
Here are some pictures of the riser.
sterlingma1 likes this.
First HTPC: Silverstone SST-GD05B-USB3.0 case, PC Power & Cooling Silencer MK III 500W, Gigabyte GA-Z77M-D3H-MVP MB, i3-3225 3.3GHz CPU, G.Skill Ripjaws Series 8GB DDR3-1600 Memory, A-Data XPG SX900 128GB 2.5" SSD and Asus BW-12B1ST/BLK/G/AS Blu-Ray.
Going to try out the HD4000 graphics for a bit.
Ryked is offline
post #117 of 200 Old 05-30-2009, 11:55 PM
ronzzkee's Avatar
pretty good
ronzzkee is offline
post #118 of 200 Old 08-06-2009, 04:12 AM
Lij
Lij's Avatar
Location: Hill Country bordering the Lower Wabash Valley of Indiana
Well, one way you can get around a riser is to create a bar behind your main seating area and have that seating be higher bar stools. Just looking for the more comfortable barstools that someone can sit in for the duration of a movie. Another advantage is that the rear seating area is then closer to the main seating area.
A friend went the opposite way and sunk his floor for the main seating area by about a foot into his basement (the extra height might have improved his audio response also). Then he built a table height bar directly behind the main sunken seating area [bar height is just below the average top of heads] and uses some very comfortable upholstered, high-back office chairs for bar seating. It brings six people close together in his 14 foot wide room.
Without music, life would be an error... if music be the food of love, play on.
My Audio/Video Configuration
Lij is offline
post #119 of 200 Old 08-22-2009, 03:38 PM
tulsaweather's Avatar
What is the seat height for the average/representative reclining HT chair?
17ish" like normal chairs?
tulsaweather is offline
post #120 of 200 Old 12-10-2009, 08:15 PM
1TONY1's Avatar
[quote=trunks;5243133]Rob -
I made a simple script based on this forumla.. I hope you don't mind.
thanks,
jake
NICE !!
Kudos on my first post.
1TONY1 is offline
