Riser Height Calculator - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #151 of 200 Old 04-07-2014, 07:36 PM
CunningOrb's Avatar
Absolutely subscribing to this thread. Can't wait to run the calc when I finally know my room dimensions.
CunningOrb is offline
post #152 of 200 Old 04-11-2014, 12:56 AM
Dizzy49's Avatar
Quoted: 35 Post(s)
Liked: 30
Yikes, according to my calculations, my riser has to be 18.5". I REALLY wanted three rows, but 3' of riser in a basement with a height of 85" isn't going to work frown.gif
Sean Hull
Denon 3808ci | PS3 80Gb | Harmony One | Toshiba XA2 | Samsung 61" PN60E6500EF | HTPC with HDMI
Dizzy49 is offline
post #153 of 200 Old 05-25-2014, 02:56 PM
Eric Sands's Avatar
In the variable plug ins, what is R defined as?
As in: R*D2=V2
Eric Sands is offline
post #154 of 200 Old 06-04-2014, 08:37 AM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
All, I am trying to figure out what height my riser needs to be and I am kinda flying blind here. I know the following variables.
I plan on using a Benq W1070 for my PJ and I have mounting flexibility to place it between 11-17' from the screen. I know I will have a row of three Berkline Tangiers on a riser at roughly 18', the riser will be 7' long and 10' wide. I know the front row will sit as close to the front of the riser as possible so let's call it 11' for the front row. Based on BIG and other comments and I can verify this tonight at home I think my seated viewing height will be 38" (42" to top of heads seated, account for some sinking into the recliners). I also will have bar seating behind the riser that will not rest on the riser as my riser will simply be a "box" in the middle of the room to elevate the 2nd row seats. The bar will be most likely 42" tall and I'm not worried about folks at the bar having partially obstructed views as much as I am the second row.
I plan on using a 16x9 AT screen that will be 130" WIDE, not diagonal. Any help is appreciated as I need to get this done so I can order my carpet.
wraunch is offline
post #155 of 200 Old 06-04-2014, 09:13 AM
kmhvball's Avatar
Quoted: 546 Post(s)
Liked: 301
There is a riser calculator somewhere on here, but couldn't find it off hand.  One other input is the "height of of bottom of screen", and this I believe is the screen itself (not the black velvet surround material).  The higher the bottom of the screen, the lower the riser and lower the bottom of the screen, the higher the riser.
A 130" wide makes for an ~ 73" image height, so, depending on your ceiling height and whether you are using a stage, that could make for a higher riser!   A question out of curiosity, will you use the 130" wide for 16:9 reasons... or, use 130: wide for 2.35:1 and then when viewing 16:9 material, be able to use more 'height' on the screen.
I am leaning towards a 130" wide, 2.35:1, but don't like that it makes the 16:9 max image smaller, I was thinking of doing a DIY that could make the screen 'taller' so, I could have a larger 16:9 image, but maybe an easier way is just ordering the 130" wide 16:9, of course, causing larger bars on top/bottom of the 2.35 image at 130" wide.
kmhvball is offline
post #156 of 200 Old 06-04-2014, 09:41 AM
Sands_at_Pier147's Avatar
It is a sticky at the top of the forum. Which happens to be this very thread we are posting in ...
It appears my hypocrisy knows no bounds.
Brian
The Cinema Rouge Home Theater
Sands_at_Pier147 is offline
post #157 of 200 Old 06-04-2014, 09:46 AM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Yeah I know about the calculator website. I will check it tonight. I am beginning to think I will have to shrink to a 120" wide 16:9 screen or go 2:35 in order to avoid a 20" tall riser.
wraunch is offline
post #158 of 200 Old 06-04-2014, 11:00 AM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
A 130" wide makes for an ~ 73" image height, so, depending on your ceiling height and weather you are using a stage, that could make for a higher riser!   A question out of curiosity, will you use the 130" wide for 16:9 reasons... or, use 130: wide for 2.35:1 and then when viewing 16:9 material, be able to use more 'height' on the screen.
I am going to play around with the riser calculator at home, can't access it now. When I used BenQ's throw calculator it says the screen will be about 20" from the floor. I am going to do a DIY 16:9 screen that will be about 73" tall. I did the calculation using the Carlton Bale v3.3 calculator and it tells me I need a 19" riser. That seems a bit crazy.
wraunch is offline
post #159 of 200 Old 06-04-2014, 12:46 PM
Eric Sands's Avatar
As in: R*D2=V2
R is the only variable not defined above.
post #160 of 200 Old 06-04-2014, 01:20 PM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
wraunch is offline
post #161 of 200 Old 07-24-2014, 09:11 AM
JRock3x8's Avatar
Quoted: 766 Post(s)
Liked: 199
my only question is around the projector in how that factors into the riser height. At some point my riser raises my head into the picture.
I really wish I could figure out a cheap and dirty way to build a temporary riser so I could play with different heights. I suppose a stack of drywall with a sheet of plywood on top would probably do the trick. But that's not necessarily cheap or easy to deal with.
JRock3x8 is offline
post #162 of 200 Old 09-22-2014, 11:55 AM
ChldsPlay's Avatar
Quoted: 772 Post(s)
Liked: 426
Does this calculator assume an upright position as opposed to a reclined one?
The Hodor Theater - Now with Atmos
Projector - Panasonic PT-AE8000U
LCR speakers - JTR Noesis 228 HT (3)
Surr./Back - Klipsch Pro Cinema KPT-8000M (4); Atmos In-ceiling - Niles DS8HD (4)
Subwoofers - Passive JTR Captivator Pro (2) - Powered by Crown XLS 5000.
Receiver - Yamaha Adventage A3050
ChldsPlay is online now
post #163 of 200 Old 09-22-2014, 01:09 PM
kmhvball's Avatar
Quoted: 546 Post(s)
Liked: 301
I don't know with any certainty, but my assumption has always been it assumes a 'similar recline' between the two rows. So, if both rows are fully reclined or both rows are fully upright, I would think line-of-site would be similar.
I would guess if your 2nd row was fully upright, and the front row fully reclined - the riser height would need to be less. However, my hope is at minimum, the calculator determines a riser height that doesn't require the front row to be reclined.
So, a next question could be can the 2nd row be reclined and front row be up-right' and does the calculator cover for that?? That would be 'best case'..
kmhvball is offline
post #164 of 200 Old 09-22-2014, 01:22 PM
ChldsPlay's Avatar
Quoted: 772 Post(s)
Liked: 426
That would be best case, but in those instances, I would think the riser heights would get to be fairly extreme in some cases. I found that if the seats in both rows are reclined, the calculated riser height needed is much less than if they are both upright.
post #165 of 200 Old 11-04-2014, 11:00 AM
sterlingma1's Avatar
Quoted: 21 Post(s)
Originally Posted by Ryked View Post
Just wanted to say thanks for the riser formula. Worked like a charm.<br><br>
Here are some pictures of the riser.<br><br><img alt="" src="http://i98.photobucket.com/albums/l264/Ryked/HT%20-%20Platform/DSCF5678.jpg" style="border:0px solid;"><img alt="" src="http://i98.photobucket.com/albums/l264/Ryked/HT%20-%20Platform/DSCF5679.jpg" style="border:0px solid;"><br><br><img alt="" src="http://i98.photobucket.com/albums/l264/Ryked/HT%20-%20Platform/DSCF5681.jpg" style="border:0px solid;"><img alt="" src="http://i98.photobucket.com/albums/l264/Ryked/HT%20-%20Platform/DSCF5682.jpg" style="border:0px solid;"><br><br><img alt="" src="http://i98.photobucket.com/albums/l264/Ryked/HT%20-%20Platform/DSCF5685.jpg" style="border:0px solid;">
just now starting my HT project. I would love to know the depth of your risers (looks like 5 or 6 ft. on the picture. Also, whats your screen size and distance to the head position from the screen?
Greatly appreciate the info.
sterlingma1 is offline
post #166 of 200 Old 01-30-2015, 03:43 PM
DrBabs's Avatar
Quoted: 62 Post(s)
all the links are dead. is there a new riser calculator out there? i seem to remember one like this:
http://web.archive.org/web/201103240....com/riser.cgi
DrBabs is offline
post #167 of 200 Old 02-09-2015, 12:53 AM
UK Dreamer's Avatar
Quoted: 126 Post(s)
Liked: 109
Exclamation
Looks like someone has 'lifted' the domain and it's now just a repository for cr@ppy adverts!
A shame, as it was a really useful resource.
UK Dreamer is offline
post #168 of 200 Old 02-10-2015, 08:02 AM
just jim's Avatar
Quoted: 81 Post(s)
Liked: 54
I have it, but it is .xls which can't be attached below. If you haven't gotten it from someone else that knows how to use a ^$% computer to get around these things, send me a PM and I 'think' I can email it to you.
Winterfell theatre build - working title
just jim is offline
post #169 of 200 Old 02-11-2015, 05:56 AM
UK Dreamer's Avatar
Quoted: 126 Post(s)
Liked: 109
Thanks Jim,
Not needed by me, as I've already used it, and my riser will be well in excess of what's required. But for others, it sucks that someone is trying take advantage of an idle domain.....or so it seems.
post #170 of 200 Old 03-20-2015, 09:51 AM
genofive0's Avatar
Quoted: 31 Post(s)
Liked: 32
Any one have this or a working link
genofive0 is offline
post #171 of 200 Old 03-20-2015, 10:07 AM
KanosWRX's Avatar
Quoted: 178 Post(s)
Liked: 59
Can use this one,
http://www.diymovierooms.com/Home-Th...s/Riser-Height
Carrick likes this.
KanosWRX is offline
post #172 of 200 Old 03-20-2015, 03:30 PM
genofive0's Avatar
Quoted: 31 Post(s)
Liked: 32
Thank you so much
post #173 of 200 Old 03-22-2015, 06:13 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 788
Save as a zip file and attach that
mtbdudex is offline
post #174 of 200 Old 06-09-2015, 02:12 PM
Liked: 1
Thank you!
wurm02 is offline
post #175 of 200 Old 08-06-2015, 11:10 AM
lemonslush's Avatar
Quoted: 828 Post(s)
Liked: 414
I got a riser of 16" which seems kind of high. I figured I would sit 50" high at the top of my head. I dont have the actual chairs we will be using yet, did you guys wait to do actual measurements or general estimates ?
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
post #176 of 200 Old 08-06-2015, 02:23 PM
sigma722's Avatar
Quoted: 462 Post(s)
Liked: 248
50" estimate seems high. I would think most would have it around 42", possibly even less for certain seats.
sigma722 is online now
post #177 of 200 Old 08-11-2015, 05:11 PM
kmhvball's Avatar
Quoted: 546 Post(s)
Liked: 301
A lot of the seats I looked at, had a seat height of 20" - 22". I sat on my home couch, and measured the top of my head down to the seat cushion... added to 20", to get the top of my head, which was around 44".
If you look at a lot of seat back heights, i.e., headrest height, they range from 40-44".
I would guess 44" to be a good number, but certainly at 50" you would be more than covered!!
lemonslush likes this.
kmhvball is offline
post #178 of 200 Old 08-13-2015, 02:49 PM
FoeHammer865's Avatar
still the links are broken....:-(
"When I left you, I was but the learner, now I am the master."
FoeHammer865 is offline
post #179 of 200 Old 01-11-2016, 06:33 AM
Mike191's Avatar
Quoted: 18 Post(s)
Mike191 is offline
post #180 of 200 Old 02-01-2016, 09:30 PM
HiFiGuy1's Avatar
Quoted: 104 Post(s)
Liked: 57
Originally Posted by Mike191 View Post
That's a nice calculator. Thanks for the link.
Philip Springer, owner -- Apex AV Systems, Inc.
THX and ISF certified systems integration specialist
WWW:ApexAVS.com
Twitter:@ApexAVSystems
Instagram:apexavsystems
HiFiGuy1 is offline
