Riser Height Calculator - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #181 of 200 Old 02-03-2016, 10:50 AM
Quoted: 319 Post(s)
Liked: 54
Originally Posted by KanosWRX View Post
Thanks for sharing!
Been looking for something like this for a while
Home Theater and Home Automation Enthusiast
MalevolentHamster is offline
post #182 of 200 Old 08-31-2016, 08:42 AM
busybe's Avatar
Quoted: 164 Post(s)
I understand this link is for height of the riser, but wanted to ask if 5 ft depth is enough if I want to put a sofa (sleek and not bulky) instead of recliners? I have limited space (total 18ft deep room).
busybe is offline
post #183 of 200 Old 08-31-2016, 09:46 AM
tradewinds's Avatar
Quoted: 16 Post(s)
not sure I understand, 5ft depth? please explain where this is measured from (e.g. ground to top back of sofa?)
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
post #184 of 200 Old 08-31-2016, 10:47 AM
busybe's Avatar
Quoted: 164 Post(s)
Sorry, I want to build a riser for 2nd row seating. Since I have limited space (from screen wall to the opposite wall, total 18 ft), I was thinking to build a riser and put sofa instead of recliners to save space. So, if I am thinking to put sofa on the riser, how deep should the riser be from one end to the other? Would I be ok with 5ft or even less?
busybe is offline
post #185 of 200 Old 08-31-2016, 10:59 AM
tradewinds's Avatar
Quoted: 16 Post(s)
so, you're asking about the width of the riser? If facing the screen, the length would be perpendicular, the width would be the distance from the backwall, in that case what is the width of the sofa? I think you would want to measure that first and add about two feet (maybe slightly less if space is a concern)
post #186 of 200 Old 08-31-2016, 11:16 AM
busybe's Avatar
Quoted: 164 Post(s)
Thank you! The sofa will be roughly 30-32" in depth(seat) and roughly 81" wide. So, I believe you are saying add roughly 24" to 30"? This 24" will be the leg room/space for people to walk out of the couch. correct?
busybe is offline
post #187 of 200 Old 08-31-2016, 11:19 AM
tradewinds's Avatar
Quoted: 16 Post(s)
correct, obviously give it as much as you can....then once that is done you can then calculate the height to clear the front row (top of people's head) based on the screen height to know how high to build the riser.
busybe likes this.
post #188 of 200 Old 08-31-2016, 11:34 AM
kmhvball's Avatar
Quoted: 531 Post(s)
Liked: 297
Sit in the couch in your living room, and put a piece of tape 24-30" in front of it... see if walking in front if it, particularly with someone seated, is comfortable enough with 24" of space. I would think with a 30-32" deep couch, if you did a 5' deep riser, that gives you 28-30" of space, would probably be okay.
busybe likes this.
kmhvball is offline
post #189 of 200 Old 08-31-2016, 11:47 AM
busybe's Avatar
Quoted: 164 Post(s)
Thank you kmhvball and tradewinds
busybe is offline
post #190 of 200 Old 09-07-2016, 02:23 PM
Gary Lightfoot's Avatar
Quoted: 728 Post(s)
Liked: 457
Is there a rule of thumb for staggered seating (front row has 3 seats, second row is 2)? My riser for the second row will be 12", but as the second row seats are staggered, and the heads will fall between the heads of the front row, the second row doesn't have to be so high does it?
I just wondered if there was a percentage reduction, though part of me feels that although the view ahead will be unobstructed, the heads will still obstruct off at the sides and the riser is still better off as if the seats were aligned and not staggered.
Anyone have experience of staggered seating on a riser?
Cheers
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #191 of 200 Old 09-08-2016, 04:23 AM
kmhvball's Avatar
Quoted: 531 Post(s)
Liked: 297
My seats are staggered some.. I have 4 in front structured |O^00^0| and 5 in back, structured |O|OOO|0|. In my case, my seat backs are higher than the top of the head, so, where the head is doesn't matter.
The outer two seats can kind of look through the wedge arms of the first row... but, I don't rely on that. I would have to go back and look, but I think my 2nd row is about 14", and it becomes a very close line of site... I can just see the bottom of the screen over the top of the front row when the 2nd row is reclined and 1st row is upright (so, easier line of site if both are reclined).
The riser height is also a function of the bottom of screen height... mine is nearly 30" up from the floor, the lower the screen starts from the floor - the higher the riser should be. Additionally, the distance from Screen to 1st row to 2nd row is also important. My screen is 'close' to my first row, it is about 8 or 9' away, and my second row is 6'9" behind. The closer to the screen, the higher the riser needs to be.
Conceptually though, if your seat backs are a bit lower, then I think your reasoning sounds good, but I can't say with great confidence whether it would work or not.
kmhvball is offline
post #192 of 200 Old 09-08-2016, 02:26 PM
Quoted: 728 Post(s)
Liked: 457
Thanks for the reply.
I guess the only way to find out for sure is to try the lower riser and see how it works out at say 8 inches, and then increase it to the calculated height of 12 inches if I don't think it's good enough. I'll need to use a couple of people or cardboard cut outs to simulate how it would look with real people at the lower riser height though, just to be sure.
I wonder if it's worth me reposting this in the ain part of the forum for more feedback in the mean time.
Cheers
Gary
post #193 of 200 Old 02-22-2017, 09:22 AM
busybe's Avatar
Quoted: 164 Post(s)
Thanks to all who guided me to build my riser. I am quite pleased with how it turned out, however, someone with similar room dimensions and theater chairs, you can do with roughly 42" wide instead of 52"(my riser's width). I could have saved roughly 10" to have my first row even farther. But still not bad..
My riser's dimension - 96inchesx 52inches x 13 inches . Seats are on top of 2x8 (additional height as they sit lower than normal chairs)
busybe is offline
post #194 of 200 Old 02-22-2017, 06:25 PM
Quoted: 728 Post(s)
Liked: 457
In the end I went with an 11inch riser and staggered seating in the second row. I'm please with how it turned out and the seating distances are 2 x screen height for the front row (for the CIH set up) and 2.9xSH for the second.
post #195 of 200 Old 04-21-2017, 03:19 AM
sam9s's Avatar
My Riser height is coming to be Zero by this calculation ....lol , can some one tell me where I am being wrong. Below is how I calculated
S=Screen height from the floor :16
H1=Height of seated front row viewers top of head :40
E1=Height of seated rear row viewers eyes (no riser) :40
D1=Screen to front row viewers eyes :156
D2=Screen to back row viewers eyes :160
H1-S=V1 :24
V1/D1=R :0.153846154
R*D2=V2 :24.61538462
V2+S=E2 :40.61538462
E2-E1=Riser Height :0.615384615
All values in inches. So basically its zero as my E2 value and E1 value is coming same ????
sam9s is offline
post #196 of 200 Old 04-24-2017, 03:04 PM
sigma722's Avatar
Quoted: 408 Post(s)
Liked: 229
H1-S=V1 :24
Your H1 and E1 should not be the same. One is the top of the head, one is eyes. probably a good 4-6" difference there. Also D1 and D2 are way too close together. Normally you have about 6.5' between rows, so 156 and then something like 234.
edit: So adjusting, I got a riser height of around 16" for you.
sigma722 is offline
post #197 of 200 Old 04-25-2017, 12:24 AM
sam9s's Avatar
Originally Posted by sigma722 View Post
Your H1 and E1 should not be the same. One is the top of the head, one is eyes. probably a good 4-6" difference there. Also, D1 and D2 are way too close together. Normally you have about 6.5' between rows, so 156 and then something like 234.
Ok yes D1 and D2 was the culprit, stupid mistake. There is a 5' distance between the first row and second. So id D1 is 156" D2 will be around 216" (18'x12). Keeping 4" difference between H1 and E1, the Riser height is coming to 13", .....woh! more than 1 feet, isn't that too high. My ceiling height is 8' (96"). The rear person would be at 50", too close to the ceiling .... wouldn't that ruin the Atmos experience for the rear seater. I sill feel there is something missing. Maybe I have to raise the screen height from the floor.
I guess there is no other way to actually create the riser and then check. I will start with 8-9" Riser and then since its woodwork can add a layer to raise the height if needed later before the final carpeting is done. That is the only way I can think, to move ahead...
Thanks for the assistance though, appreciate that.
Regards
Sammy
sam9s is offline
post #198 of 200 Old 04-25-2017, 06:35 AM
sigma722's Avatar
Quoted: 408 Post(s)
Liked: 229
Regards
Sammy
One thing that you can do is just do a base riser that is 7" or so, and then do the next 6-7" portion of the riser only where the seating is, with a little lip in front of the seating for feet that aren't reclined. Also, I think that 6'9 (even down to 6'6") is plenty high for people to get around in general for a second row personally. It's not like you are generally standing around socializing in the back row (unless you are planning one of those bar second rows, but even then, you likely don't need a riser) - generally you are just getting into or out of seating.
sam9s likes this.
sigma722 is offline
post #199 of 200 Old 04-26-2017, 01:05 AM
just jim's Avatar
Quoted: 74 Post(s)
Liked: 51
Using your numbers:
If E1 was 36" with a 13" riser, then E2 would be 49". Yes, 47" to the the ceiling from your eyes/ears, 6' 11" from the riser to the ceiling when standing. This is why you should start with a 9' plus ceiling height when possible. The Atmos effect will be what it is.
13" riser seems about right, there is a step in between at 7 1/2" of course. The step would be in the aisle only. Keep the entire riser at the same height or it will be difficult getting into the elevated seat and a tripping hazard in the dark. If your seating is reclining, make sure there is enough spacing for the foot support to come up, otherwise you will have to compromise on the viewing distance for the front row to the screen (moving the front row forward) and/or back row to the back wall (moving the back row closer to the wall and the rear speakers). [Where are YOU going to sit? ].
With out the the luxury of unlimited dimensions, putting more seats or rows in a room than what the room can mathematically accommodate will always have compromises. You have to make the decision on what compromises you can live with.
Good luck!
Winterfell theatre build - working title
just jim is offline
post #200 of 200 Old 04-26-2017, 10:43 AM
kmhvball's Avatar
Quoted: 531 Post(s)
Liked: 297
... the Riser height is coming to 13", .....woh! more than 1 feet, isn't that too high.
I have two 'seated' rows in my theater and my second row is 13" taller than the first, and is just barely adequate and my screen starts higher than yours, which then requires a lower 2nd row. As another posted suggested, I have a 'two height' platform... the very rear of the room (where the entrance is) and around the sides to the front row is 8" inches.. and then in the middle of the room where my 2nd row seats are, it is 13". I have lights under the lip of the center riser to help with safety...
kmhvball is offline
