Best black paint for ceiling tiles. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-22-2005, 11:55 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
What's the best way to paint ceiling tiles and which paint? Looking for that black hole effect with no sheen.
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #2 of 13 Old 02-22-2005, 12:12 PM
TheFerret's Avatar
Have you already bought the drop ceiling? If not, keep in mind they do make black panels.
When will D* stop pushing HD-Lite while charging us for full HD? Digital input on a CRT is a reality, not a possibility.
TheFerret is offline
post #3 of 13 Old 02-22-2005, 12:46 PM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
If you run a search using "painting" you'll find a few threads addressing your specific question.
Ron
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
post #4 of 13 Old 02-22-2005, 12:56 PM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Thanks guys!
Ferret, where do you know I can get them?
vitod is offline
post #5 of 13 Old 02-22-2005, 02:23 PM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
Here is a thread about black ceiling tiles that showed using the search function THE fastest way to find your answers:
http://www.avsforum.com/avs-vb/showt...hlight=ceiling
and there are others too that talk about retailers of black ceiling tiles.
Retired Moderator
post #6 of 13 Old 02-22-2005, 04:49 PM
TheFerret's Avatar
Let me work on my memory. There is a company that specializes in commercial building supplies that I contacted here in Atlanta (they are not local, IIRC). I think it was USG that actually manufactured them.
post #7 of 13 Old 02-24-2005, 01:16 PM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
:p
vitod is offline
post #8 of 13 Old 02-24-2005, 01:37 PM
kasabe's Avatar
As someone who recently finished painting about 100 ceiling drop tiles. I used regular cheap old Home Depot Behr paint. Flat black. I rolled each dropped tile and took a brush to get the edges. Although if i had a paint sprayer I probably could gone faster. Make sure you have a good dense roller to get all the crevices. Otherwise my ceiling looks great.
Another thing I have done is cut acoustic tiles 2x2 and wrap them in black fabric that works good too.
Performance Home Cinema
www.kasabedesigns.com
kasabe is offline
post #9 of 13 Old 02-24-2005, 05:34 PM
TheFerret's Avatar
Many HDs rent sprayers.
post #10 of 13 Old 02-24-2005, 06:38 PM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
What fabric did you use?
vitod is offline
post #11 of 13 Old 02-24-2005, 09:21 PM
rynberg's Avatar
Doing that completely destroys any mid and high frequency sound absorption of the tile. USG, Capaul, and Hunter-Douglas make black tiles, it's easier, will look better, and will have better absorption (depending on the tile and depending on how much absorption you are looking for).
rynberg is offline
post #12 of 13 Old 02-27-2005, 09:23 AM
kasabe's Avatar
I know this sounds totally absurd and maybe incomprehensible, but can you believe I wasn't concerned about the detriment to the mid and high frequencies as much as I was concerned about a big white ceiling I needed black as inexpensively as possible.
I understand that you alter the acoustical qualities of drop tiles by adding a thin layer of paint to it. But, I am guessing that absent of purchasing all new black tiles, most of us on a budget when faced with an exisiting ceiling full of white tiles would rather paint it and enjoy the dark ceiling and spend the money on more meaningful things like the gear or treating more important areas of the room.
I agree with you if you have the budget, replacing the tiles with black tiles would be appropriate or wrapping them in black FR701.
kasabe is offline
post #13 of 13 Old 02-27-2005, 08:31 PM
triodeuser's Avatar
Another poster on a thread I read here at AVS today was talking about the merits of Sherwin Williams flat black paint.
Said it had no sheen to it and used a different formulation than others - used a resin for a base -
http://www.avsforum.com/avs-vb/showt...0&pagenumber=1
Regards
Ken L
triodeuser is offline
Closed Thread Dedicated Theater Design & Construction
