the definitive Grafik Eye master thread!! - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #721 of 1589 Old 06-18-2009, 05:17 PM
DMF
DMF's Avatar
Hey, that's pretty cool. It would have been great in my room where the GE essentially doubles as a wall station. I could have put it in the attic with the accessories and set a wall station into the old box. Wouldn't have even had to open the wall.
Lutron seems to have accelerated their R&D. Do you have a feel for whether there is an increase in demand for HT conversions in parallel with the demand for big TVs?
No matter where you go. ... There you are.
DMF is offline
post #722 of 1589 Old 06-19-2009, 09:33 AM - Thread Starter
cinemascope's Avatar
Te GrafikEye is still first and foremost a commercial device.... even these new iterations.
Home theater is just an excellent use of an existing product, after all a board room and a media room/HT have many similarities.
- video and/or overhead/slide projectors
- low light for presentations (or movies)
- task lighting for certain areas
- physical light control of drapes/blinds....
Oh, and the QS absolutely rules over the 3100/3500
Certified: Vantage InFusion, AMX A.C.E.
Lutron HomeWorks, Lutron RadioRa2 (Level 2)
cinemascope is offline
post #723 of 1589 Old 06-19-2009, 12:43 PM
starbuckcat's Avatar
Anyone have 35-40 feet of PELV wire that would like to sell? PM
starbuckcat is offline
post #724 of 1589 Old 07-06-2009, 12:43 PM
huntrm's Avatar
Got a question - need some advice. I own a GE 3104, and have an IR transmitter wired to the front of the unit. However, as pointed out on the first page of this thread, a bulge will show up when you try to put the cover on.
I've gone over the options in this thread, and not sure they'll work for me because my IR transmitted is slightly larger than the ones recommended. I see two options:
1) Use a dremel on my IR transmitter, try to whittle down as much as possible on it (get it close to the size of a Xantech IR transmitter)
2) Remove the small, round IR receiver plastic cover on the GE. Then, insert my transmitter in the cover hole and the hole of the IR receiver.
Can option #2 even be done? How do I remove this small piece of plastic (pliers)? Anyone done it?
huntrm is offline
post #725 of 1589 Old 07-12-2009, 01:45 PM
huntrm's Avatar
I ended up using a dremel with a VERY light cylindrical sanding accessory, and ended up grinding a small hole to the left of the IR. I didn't go all the way through the plastic. I also sanded down the IR itself, made it work.
The cover now goes on almost 100% perfectly.
huntrm is offline
post #726 of 1589 Old 07-24-2009, 05:00 PM
Jailguy's Avatar
I just picked up a 6-zone QS and I'm doing all my wiring. The two "ports" in the back say "IR Data" & "IR Com". How do I hook the QS to the IR repeater?
Jailguy is offline
post #727 of 1589 Old 07-27-2009, 01:11 PM
DMF
DMF's Avatar
Did you read the installation instruction booklet?
DMF is offline
post #728 of 1589 Old 07-27-2009, 08:15 PM
Jailguy's Avatar
Yes, it doesn't really get specific with anything dealing with IR. I think I may have figured it out, but I'd be interested in what everyone else did?
On a side note, does anyone know where I can get replacement covers for my QS. I can't only find covers for the older models.
Jailguy is offline
post #729 of 1589 Old 07-30-2009, 02:08 PM
DMF
DMF's Avatar
I don't have specifics about the IR - I've never installed a QS.
For covers, call Lutron support. They're undoubtedly available. IIRC, they're about $150, depending on the finish you want.
DMF is offline
post #730 of 1589 Old 08-10-2009, 12:46 PM
Coopsav's Avatar
Jailguy, I did an IR on my set up if I remember when i get I'll post the wiring for you.
Coopsav is offline
post #731 of 1589 Old 08-10-2009, 04:25 PM
Warren_G's Avatar
I went to a local supplier of electronic parts and was able to get a handful of 3mm IR emitters for 75 cents each. You would need to do a little soldering, but its not difficult. These would fit in without a bulge, although I am mounting mine in the back of seat that is right in front of the GE on the wall. What I need to find now is a programming manual for my Grafik Eye, as I would like to use some of the extended scenes. I have scenes 1-5 set up for movie viewing, TV viewing, full on, full off, etc. What I would like to do is access more scenes that I can set to the same levels, but have different dim times, so that if I bring the house lights up for an intermission macro, it will go back to the movie viewing level without taking the full minute I have set on Scene 4.
Warren_G is offline
post #732 of 1589 Old 08-11-2009, 07:34 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Warren G,
If you are using a Harmony remote they have the 16 scenes available as part of the database. They don't call them scenes, I think they call them light 1 light 2 or something like that. Anyways you can select i.e. scene 8 and then manually adjust the GE (I know you may know this already, for the benefit of others) to what setting you want and it will remember that as scene 8.
Even if you don't have a Harmony you can get one pretty cheaply to be able to teach your remote the commands after you download them from the database.
oman321 is offline
post #733 of 1589 Old 08-11-2009, 08:22 AM
Coopsav's Avatar
Jailguy, did you purchase your IR repeater from Lutron? as that's what I did so I may not help. My GRX-CIR wired up with 4 wires like any of their wallstations.
Coopsav is offline
post #734 of 1589 Old 08-11-2009, 10:34 PM
raZorTT's Avatar
Has anyone hooked up an occupancy sensor to their QS?
I was wondering if you had to buy the lutron sensor or if other sensors would work?
Cheers,
Simon
raZorTT is offline
post #735 of 1589 Old 08-13-2009, 08:07 PM
DMF
DMF's Avatar
Warren_G, there is a document for the extended command set on the Lutron site. I can't point to it right now, but if you can't find it call Lutron support and they can point you to it.
DMF is offline
post #736 of 1589 Old 08-13-2009, 11:45 PM
Warren_G's Avatar
I never even thought of just using the 16 settings available on the harmony and then setting the levels on the GE directly. Its so simple, its brilliant. Thanks for the tip.
Warren_G is offline
post #737 of 1589 Old 08-26-2009, 09:09 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Warren,
How did you make out. Get it resolved?
oman321 is offline
post #738 of 1589 Old 08-30-2009, 09:07 PM
raZorTT's Avatar
Cheers,
Simon
Anyone hooked up a sensor to their GE?
Simon
raZorTT is offline
post #739 of 1589 Old 09-01-2009, 07:19 PM
Warren_G's Avatar
I got it resolved and it works like a charm. I embedded one of the 3mm IR emitters in the back of one of my theater seats, and it controls the GE exactly as I had hoped.
You can see the IR eye as the small dot in the middle of the seat here:
Warren_G is offline
post #740 of 1589 Old 09-09-2009, 12:22 PM
DMF
DMF's Avatar
Cool solution!
DMF is offline
post #741 of 1589 Old 09-16-2009, 11:29 AM
family_man's Avatar
I have a question on dimming. I am looking at the 3104 and I have a zone that is only going to be two recessed lights. I am planning on using MR16 capable recessed lights. If I use two 20w MR16 lights it will hit the grafik eye's 40W minimum per circuit. But in that case, where the dim control still work well since its so close to the minimum? I didn't know if the grafik eye needed a minimum because it can't reduce its output much more than the 40W. Thoughts? Experiences?
family_man is offline
post #742 of 1589 Old 09-17-2009, 02:40 PM
frank1940's Avatar
Since no one has responded to your question, I thought I would do so even though I don't have an answer for you.
What I would do in your situation is call Lutron US product support directly at 1-800-523-9466 and get the answer from the horse's mouth.
frank1940 is offline
post #743 of 1589 Old 09-17-2009, 05:19 PM
DMF
DMF's Avatar
I'm pretty sure the zone minimum is 25W rather than 40W.
In either case, the unit will have no problem with your application.
DMF is offline
post #744 of 1589 Old 09-20-2009, 09:22 PM
family_man's Avatar
Frank1940, DMF,
Thanks for the reply. After I posted I did call up the support line, and they said that if you fall below the minimum, the problem is that the lights might flicker and that the zone lights may glow even when fully off.
I do have a second question after reading this thread. I have want to use an RF remote and as I understand I can either run an emitter to the front of the Grafik Eye or connect GRX-IRI.
If I run the emitter to the front, I can't use CAT5 inside the box because its a fire risk (unless possibly if I wrap in electrical tape) so are those who are running the emitter to the front running it outside the gang box? Or is it possible to use a MUX wire through the box as an extension for the emitter on the front of the Grafik Eye. Does anyone know of pictures of how exactly they placed and extension wire through the wall and onto the front of the Grafik Eye?
All help appreciated.
post #745 of 1589 Old 09-27-2009, 07:06 AM
ctviggen's Avatar
Quoted: 116 Post(s)
Liked: 32
[*] Triac-based dimmers can pump out a lot of EMI (electro-magnetic interference); a metal box blocks EMI.
This may not be true, unless you're running metal conduit all the way to the metal box from the breaker box, where the metal conduit and box would therefore be grounded. If you're running romex to the metal box, the box isn't grounded and therefore I would assume have less ability to block EMI.
Also, what about the Grafik Eye itself? What shielding does it have? You could have the box nicely shielded, but then the front of the Grafik Eye is spewing EMI all over the place.
Anyone have trouble with the Grafik Eye affecting their system? I'd like to know, because I'm starting to run wires now and can run THHN and metal conduit to the Grafik Eye, if that's necessary. I am running THHN and metal conduit to my system's electrical outlets, and I'm going to use an isolated ground system there. So, that should help to protect me somewhat, but if I'm going to run conduit, I might be able to run another set of conduit if necessary (but I'd rather run romex).
Finally, how did you sound proof this box? (Or did you?)
Bob
ctviggen is offline
post #746 of 1589 Old 09-29-2009, 09:54 PM
family_man's Avatar
Originally Posted by cinemascope View Post
Here are some of the other threads that had various info regarding the Grafik Eye:
http://www.avsforum.com/avs-vb/showt...64#post5859064
http://www.avsforum.com/avs-vb/showthread.php?t=551838
The thread where members Bpape and Toxarch details the installation of an IR emitter, including a nice photo by Toxarch.
http://www.avsforum.com/avs-vb/showt...ght=grafik+eye
I noticed that the links referenced above are now dead. Does anyone have the pictures referenced above about the installation of an IR emitter? I would like to see the work Bpape and Toxarch have done before
post #747 of 1589 Old 10-01-2009, 08:50 PM
wo_riley's Avatar
Does anyone know what's the deal with the new Grafik Eye QS Wireless? What protocol does the wireless use? Will it work with devices like the iTouch? Is there a price premium such that it would be easier to work with a standard QS with another wireless interface?
wo_riley is offline
post #748 of 1589 Old 10-02-2009, 11:50 AM
eskay's Avatar
The threads are in archive. When you get the screen that it can't find the thread, click on the link to the 01/05-06/06 archives.
eskay is offline
post #749 of 1589 Old 10-07-2009, 08:31 PM
NM_Toronto's Avatar
Any comments on this product by Progress Lighting.
http://www.lightingdirect.com/progre...=shtca_1058208
Is it a rebranded Lutron product? Price is really cheap.
Any ideas what series it is based on the picture/description
Thanks in advance.
NM_Toronto is offline
post #750 of 1589 Old 10-08-2009, 11:41 AM
Crash11's Avatar
Quoted: 23 Post(s)
Thanks in advance.
Check this page here:
http://www.lightingdirect.com/index....ryid=15004&p=5
It's indeed a Lutron product.
Crash11 is offline
