Stages and risers almost complete - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 10-15-2005, 06:59 AM - Thread Starter
Mark P's Avatar
Liked: 30
Originally Posted by v1rtu0s1ty View Post
Hi mark,
I really would like to learn how you created those rounded stage. What tool did you use and can you share how you did it please?
And also on your ceiling, I saw a big perfect round hole/circle in the middle that's been drywalled. What did you do so that when drywall is bent while being installed, it doesn't break? It's totally cool!
Thanks! Awesome theater!!!!!!!!!!!!!!!!!!!!
I detailed the stages on the first page I think, Maybe the second?
the " Hole" was coverd in 3/8 plywood first and to sheetrock it you soak the drywall and it becomes more flexable, the plywood makes a ridgid surface to push the wet drywall into. A friend of mine did my sheetrocking for me, this would have takin me weeks, his crew and him were done in a day having it firetaped, they finished it the next day using hot mud
Mark P is offline
Old 10-16-2005, 08:18 PM
v1rtu0s1ty's Avatar
I have a question. Please look at the image below: On the blue arrow, how were you able to make a curve/arc on the wood? What tool did you use? How thick is the wood?
On the red line, am I correct that it is a plywood? How thick is it?
Neil
v1rtu0s1ty is offline
Old 10-16-2005, 09:02 PM
AnthonyP's Avatar
v1rtu0s1ty: to me it looks like two pieces a flat one on top and an other on the side.
AnthonyP is offline
Old 10-16-2005, 09:18 PM
v1rtu0s1ty's Avatar
yeah, i know they're separate. But how was the cutting done on the wood pointed by the blue arrow?
Old 10-16-2005, 09:25 PM
AnthonyP's Avatar
sorry, from your question I though you were asking how he curved the wood.
AnthonyP is offline
Old 10-16-2005, 11:15 PM
Toxarch's Avatar
I would guess he just drew the curve on some wood and cut it with something like a jig saw or maybe a reciprocating saw.
As for the red arrows, you might be able to bend 1/2" plywood like that if it's a real easy curve. I used 2 layers of 1/4" plywood.
There are no stupid questions, but there are a LOT of inquisitive idiots. Me being one of them at times.
My HT Website in progress.
Toxarch is offline
Old 10-17-2005, 12:18 AM
v1rtu0s1ty's Avatar
Old 10-17-2005, 12:33 AM - Thread Starter
Mark P's Avatar
Liked: 30
sorry guys I was at a Hometheater get together up here in Portland tonight, very fun
I used 8 sheets of 3/4 plywood layed on top (4 on top of 4) of each other making a 1-1/2" thick piece of plywood 8' wide by 16' long then I made a "compass" I will call it out of a 1 x 6 pine board that my Plunge router fastened to at one end ( using a 1/4" upspiral bit) and put a screw centered into the other end 8' away , this allows me to cut a perfect arc in several passes as to not burn up the bit , then I moved the screw 3-1/2 inches closer to the router but used the same hole and routed again making what appears to be a long curved 2x4
My method is hard to explain but easy to talk through or show, maybe I will see if any of my old picks show what I am talking about
Mark P is offline
Old 10-17-2005, 12:36 AM - Thread Starter
Mark P's Avatar
Liked: 30
Oh sorry I forgot, the fronts are indeed 1/2" plywood with relief cuts every inch about 1/8" deep using a sliding chop saw with a laser line on the blade this takes little time but 1/4" would surely make the bend .
Mark P is offline
Old 10-17-2005, 12:48 AM
v1rtu0s1ty's Avatar
Hi Mark,
I understand now when you explained how you made the cutting for the arc shape. That's really cool. Hmmm, I've been seeing/hearing the equipment called router. Did a google search and I saw this, http://www.amazon.com/exec/obidos/tg...84021?v=glance
I'm interested on how this looks like, 1/4" upspiral bit. Do you have some screenshot? It's because, I would like to know how the staircase nosing is built. This way, I don't have to buy the nosing at Home Depot. And also, once I have the tool, I can create my own nosing most especially for custom shape stage or riser.
Old 10-17-2005, 01:22 AM - Thread Starter
Mark P's Avatar
Liked: 30
heres a pic of it going together , the entire process was filmed in HD but I neglected to take pics of the actual routing
Mark P is offline
Old 10-17-2005, 01:38 AM - Thread Starter
Mark P's Avatar
Liked: 30
heres an upspiral bit,
available at any Lowes or Home Depot
I use 1/4" x 2-1/2 long , took 2 to build this stage but thats alot of routing and yes that router you provided a link to is a plunge router , I prefer Hitachi s because they give you freebie accessories and they route forever with simple quick changing of bits
Since I am carpeting over the edges of the stages I just used a 1" roundover bit on the top and bottom edge of the "platform"
Mark P is offline
Old 10-17-2005, 08:47 AM
v1rtu0s1ty's Avatar
Thanks Mark! That really helped me a lot!!!!
Old 10-17-2005, 12:39 PM
Toxarch's Avatar
Mark, I think your work on the stage is very nice but I really think you could have done it much easier. Just build the frame without the sandwiched plywood pieces and without the cutouts in the 2x6s. You can use 2x6s between the curve supports for added strength. Add the plywood for the face of the stage and then add the curved top for the stage. Should be much easier than engineering your own curves 2x4s out of sandwiched plywood and it'd be just as strong.
Toxarch is offline
Old 10-17-2005, 02:23 PM - Thread Starter
Mark P's Avatar
Liked: 30
you know I thought of that but I have rope lighting running top/bottom around each curve and the only way I could get rid of it ( hide it ) was to route channels for it into the 2 x 4s I made, its hard to explain I could probably take a picture
Mark P is offline
Old 10-18-2005, 07:14 PM - Thread Starter
Mark P's Avatar
Liked: 30
Isco 3 anamorphic lens showed up and this baby is a brute, weighing in a 10 lbs. Packaged very nice and is amazing . Took all of about 1/2 hour to be up and running thanks to Alan.
For those that have seen the Mercury HD and know how big it is , this lens just sorta fits right in. ( may have to beef up the balcony)
Putting it through the test in about 15 minutes with Batman Begins
Mark P is offline
Old 10-19-2005, 01:02 AM
mmmkam's Avatar
mmmkam is offline
Old 11-08-2005, 04:50 AM
jamis's Avatar
jamis is offline
Old 11-08-2005, 05:07 AM
Darkking's Avatar
Yeah! It's been a couple of weeks since last report. Guess the test of Batman Begins was successful and all is happening now is a whole lot of movie watching
Dave
Darkking is offline
Old 11-08-2005, 07:15 AM
dc_pilgrim's Avatar
I have been thinking about this thread in the last week or so, wondering how it was going. I had forgotten the name of the thread title. So I am mostly posting to remind me to check this thread more often.
Also, to add kudos on the theater. Thanks for showing off the lens too - its pretty mean looking.
dc_pilgrim is offline
Old 11-08-2005, 08:40 AM - Thread Starter
Mark P's Avatar
Liked: 30
Sorry guys,
No goodies, since the HTPC got sidetracked all the stuff that had been neglected getting ready for winter.
Once we found out the chairs were going to take 3 months , everything turned to movie watching mode and dealing with automation and loading up the media server .
If the weather turns foul I will work on the balcony .
Several mistakes made in this build
1. Hang screen
2. position projector
3. receive anamorphic lens
4. Install Blackouts
Mark P is offline
Old 11-11-2005, 03:16 PM
the crane's Avatar
You have to be flipping kidding me? That place is nuts!
I Golf
the crane is offline
Old 11-11-2005, 04:39 PM
SR1355's Avatar
I offically have lense envy!!!
SR1355
SR1355 is offline
Old 11-12-2005, 12:52 PM
heartsurgeon's Avatar
I'm working on a PDA as a voice command remote
that's really a neat idea.....
your "wow" factor is going to be over the top....even more.....
Rule #1: You haven't wasted your money...you just haven't spent enough yet.
Rule #2: When in doubt...get both.
Rule #3: No need to invoke malice when stupidity alone suffices.
heartsurgeon is offline
Old 11-17-2005, 07:25 AM
Static Wick's Avatar
Ba Ba Bad to the Bone...
Static Wick is offline
Old 11-19-2005, 08:03 AM
keithmcelhinney's Avatar
Please stop posting picture of you theater. My heart really can't take it!
I am in process of planning my new theater. My first theater was a definite budget job, but I loved it! I now am trolling the forums for design ideas for my new one which (hopefully) won't be such a budget theater. Now I come across yours and I can't think stop trying to fit in a balcony in my 9' tall basement!
To restate: ABSOLUTELY AMAZING!
-Keith
Keith McElhinney
keithmcelhinney is offline
Old 11-19-2005, 08:29 AM
R_Willis's Avatar
Love it.
Words can't really describe what you have going on there.
MarkP: you available for hire, if and when I win the super lotto?
R_Willis is offline
Old 12-03-2005, 09:50 PM
klutzo's Avatar
*sigh* I wish I had that space!
Awesome how you guys went into the attic though.. Very novel idea. Our new place has room for me to put in a 10x14' HT, so am planning it now. I don't think the wife would approve if I went up into the kitchen with a balcony seating plan. =>
Klutzo,
the newbie HT Boy.
Please, feel free to visit the klutzoplex! Click the link below. =>
Click here to visit the Klutzoplex
http://www.klutzoplex.com
klutzo is offline
Old 12-03-2005, 11:29 PM - Thread Starter
Mark P's Avatar
Liked: 30
Are you kidding me, I hope I never see a HT again, and i wouldnt wanna steal all your fun
Mark P is offline
Old 12-03-2005, 11:31 PM - Thread Starter
Mark P's Avatar
Liked: 30
Ask her if she'd rather cook or watch movies, she might suprise you with her answer
Mark P is offline
