Sandmans Home Theater Construction Begins! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 3772 Old 09-18-2005, 09:11 AM
suffolk112000's Avatar
You guys... this thing looks awesome!!
I vote for the coffered ceilings. Just make the cross sections smaller like SVonhof mentioned.
Craig
Domino's donÂt fall all at once, they fall one at a time...
suffolk112000 is offline
post #92 of 3772 Old 09-19-2005, 12:50 AM - Thread Starter
SmX
SmX's Avatar
Update:
Double Layer Drywall Is Done on walls and 3 Layers on ceiling with GG in between. Also All finished Mudding. Equipment Rack is the Last to do because the AC guy needs to get in above It to run the Supply and return Lines and make the Duct Boxes to feed the room.
Also finished Pre Cutting all the 3/4" MDF for the Soffits.
Here are some boring Drywall flicks
More to Come...
Follow SmX on Facebook
SmX Video Projection Screens and Masking Systems
WWW.SMXSCREEN.COM
SmX is offline
post #93 of 3772 Old 09-19-2005, 03:13 PM - Thread Starter
SmX
SmX's Avatar
An Update,
We are no Longer going to use MDF for the Soffits, actually we were never planning on using MDF (a misunderstanding on my behalf). The Soffits are going to be framed out with 2" x 2"s and left open to be used as bass traps and will get filled will Cotton Batts or a mix of Cotton/R-19 and the Frame will get wrapped with a paper so the Highs don't get Sucked up then covered with GoM.
The Light Trays will still be made out of MDF and part of the Columns too. The Left over MDF will be used for another project I have to do in our home once this project gets completed.
WWW.SMXSCREEN.COM
SmX is offline
post #94 of 3772 Old 09-19-2005, 10:40 PM - Thread Starter
SmX
SmX's Avatar
I been getting a couple PMs from people wondering about how I am treating the room. I recently brought BPape in on my project to consult me on how to acoustically treat my room and he is doing an awesome job.
So Far we Tackled the Bass Absorbtion Issues by turning the Soffits and Columns into Bass Traps and Making some Bass Trap Panels for behind the Screen wall Using Cotton Batts.
We are now working on treating all the reflection points on the Walls & Ceiling. He is a great guy to work with and loves talking about this and thinking out great solutions.
More to Come...
WWW.SMXSCREEN.COM
SmX is offline
post #95 of 3772 Old 09-20-2005, 04:54 AM
bpape's Avatar
Send a message via AIM to bpape
Thanks for the kind words. For those following along, the front corners will have broadband bass absorbers floor to ceiling (gotta love false walls). With the speakers he is using up front, doing too much in terms of soft absorbtion on the front wall is a concern.
Between the main speakers and between the broadband absorbers and the speakers will be wooden sealed resonant panel traps. Out in the room on the wall bottoms, there will be a few more of the panel type traps but tuned to a different center frequency.
I am serious...and don't call me Shirley.
www.sensiblesoundsolutions.com
bpape is offline
post #96 of 3772 Old 09-27-2005, 04:22 PM - Thread Starter
SmX
SmX's Avatar
Updates...
Its been a slow week due to my helpers grandmother passing away and him having to go to NY to attend the Funeral and Wake. So this week I got the Duct Work installed by a pro (cost $250.00). I Framed out The Platform and Stage by myself this week as well.
I also got my Supplies for the Bass Traps and treatments for the room from BPape which was extremely good priced, he is really working with me.
I am holding Off on doing the Soffits until my helper comes back.
Here are the Cotton Batts for the Bass Traps along with other Stuff That Arrived from BPape. It was allot of Boxes! Boxes were Big but not Heavy, after all its only cotton and fiberglass.
Here is the Duct work that got done. We used Duct board instead of Flex to reduce sound transmission because the Ducts act like a muffler and pretty much kills sound going through it. I already tested them out by placing a Speaker blasting in front of the Duck openings and went inside the home and Heard absolutely nothing coming through the exchanger or supplies. The Ducts still need to be encased and sealed with 3/4" MDF...
Here is the Platform the Chairs will be on, the Platform was built in 2 parts made out of 2" x 12"s and took about 5 hours to make by Myself. It will contain Outlets and Conduits and will be filled with Insulation. The Widow in the Back will be Sealed once all my materials are brought in. The window was a big convinience, saved walking through the house with everything...
Here is the Stage, which will be filled with about 4,000 lbs of sand. The Stage was built in 4 parts which are not tied together yet in the pictures below.
The stage was made with 2" x 10"s and Took about 4 hours to make.
Front View of Stage
This is a Side View of the Room to show the distance between the Stage and Platform
By the way, taking these pictures was impossible without a Wide Angle Lens, I could not Capture the whole side. I forgot I had one, so I ended up using it
More to come Soon...
WWW.SMXSCREEN.COM
SmX is offline
post #97 of 3772 Old 09-28-2005, 08:05 AM
Quoted: 3819 Post(s)
Liked: 3246
You are really moving and that framing looks great. I think that the Sandman will soon be hauling that sand to fill the stage.
Let's see if my prediction that you don't have enough holds true.
Also don't forget that you don't want to fasten the stage to the walls. Leave a little gap. That way any vibration created in the stage won't get to the walls.
post #98 of 3772 Old 09-28-2005, 08:16 AM
I may have missed this, but what is going to be the distance between first row and screen? How big is the screen?
I love the stage. It looks like you could actually use it! It really has some character.
Also love the way your riser curves as well. You are doing a wonderfull job.
Craig
post #99 of 3772 Old 09-28-2005, 10:18 AM - Thread Starter
SmX
SmX's Avatar
Thanks for the great comments guys, you guys keep giving me motivation.
From what it says on the bag, it takes 11 50lb. bags to fill a 4' x 4' x 4" area. The Main stage without the little radius sections in front is 43" x 181" x 9.5" tall. After you take out all the Space for the 12 Joists in the middle that takes away 18" from 180" which ends up being 163" x 43"x 9.5" ID
So 163" x 43" x 9.5 is 66,585.5 Square Inches and 11 50 lb. bags is 9,216 Square Inches. 66,585 divided by 9,216 equals 7.2 so 7.2 x 11 bags is 79.47 bags.
I ordered 80 bags (4,000 lbs.) plus I had 2 here already, so I have 82 bags total.
But who knows, my math could be way off?
As far as not attaching the front Stage to the walls, that was my first intention to avoid transfer of vibration to the walls. I even used Foam on a roll all around the sides of the stage that meets the walls and left a half inch gap all around the stage. But after talking to BPape which is consulting me on this project, he said it would be fine to tie the stage into the wall. I still think I rather not tie the stage into the wall and will talk to him further on that. I personally rather keep the stage floating.
The Distance from the first row of eyes to the screen is 120" The width of the screen is 120" or 138" diagonal 16:9. I personally like a Big Picture and will be sitting up front. Second Row of eyes is 185" from the Screen.
The Big Question for Me Now is whether to have a Lip or not on the Stage and Platform. A Lip will be great to run a rope under for accent lighting. I may be running Fiber optics for my rope lighting instead of rope lighting. Its just a Pain in the ass to keep having sections of the rope burning out on you when Fiber is Lifetime with only having to change one or 2 bulbs when they go.
Ruben
WWW.SMXSCREEN.COM
SmX is offline
post #100 of 3772 Old 09-28-2005, 11:27 AM
SVonhof's Avatar
Quoted: 14 Post(s)
Ruben, FYI, I have had no problems with any of the sections of rope-light burning out. This is probably helped by the fact that I have a Lutron Grafik Eye controlling the lights and it never goes full-off to full-on instantly, but always ramps up to the level that it is set to. The minimum time for ramp-up I have set is 1 second.
SVonhof is offline
post #101 of 3772 Old 09-28-2005, 11:42 AM
bpape's Avatar
Ruben,
I'm sure you never thought about filling a stage when you picked your moniker
As for attaching the stage to the walls - with the isolated wall construction, I don't see it being a problem at all to attach it. Realistically with all that sand in it - you probably don't NEED to - that's for sure. With all the sand in it, I also hardly think there will be much of any vibration that it'll be passing to the walls. Either way will work. I personally don't think there will be any difference either way. I just prefer to tie everything together and make it as solid as possible.
bpape is offline
post #102 of 3772 Old 09-28-2005, 11:53 AM
Liked: 3246
Way back on the first page:
"What I ordered was
1,000 lbs. of Pavers Sand to fill Stage"
OK so you have 4 times as much as I thought. That should do it.
post #103 of 3772 Old 09-28-2005, 12:01 PM
Cloud zer0's Avatar
This is amazing!
it should work out like a charm, because you VISuALiSed everything before doing it in great detail.
I hope your sound mats will keep sound away from neighbors well.
Great work, good luck !
Cloud zer0 is offline
post #104 of 3772 Old 09-28-2005, 12:01 PM
Liked: 3246
On the lip thing. From my local consultant "Clarence"
A lip aids in installing the carpet. You carpet it with two pieces rather than bending one piece over and down. When the carpet installers showed up at his place he asked them and ended up ripping a 2x4 in half and mounting to the edge of the plywood. (not certain that would work for curved sections).
post #105 of 3772 Old 09-28-2005, 01:11 PM
Tom Kay's Avatar
Quoted: 20 Post(s)
To SandmanX and Reaper;
These renderings that you guys do are blowing me away. It's almost more exciting to see the drawings that you do, than the finished HT's. Awesome work, and it must be nice to have an almost exact idea of what your theater will look like before it's even started. That'll keep you nailing and drywalling.
I have made some drawings using a program called Corel Draw. It's a good program, for what it is (more of a semi-techincal drawing program, but less technical than AutoCad) and if I were a real ace with it, I could make the pictures more photo-like, but comparatively, my drawings are almost like clip art or stick figures. Still it's handy to be able to plot things out to scale on computer and change things quickly as needed.
Keep up the renderings ! they are really neat to see.
Cheers, Tom Kay, Ottawa Canada.
There's a proper time and place for spontaneity, dammit!
Tom Kay is offline
post #106 of 3772 Old 09-29-2005, 12:49 PM - Thread Starter
SmX
SmX's Avatar
"What I ordered was
Yeah, that was some real Bad figuring on my behalf You was right.
WWW.SMXSCREEN.COM
SmX is offline
post #107 of 3772 Old 09-29-2005, 01:39 PM
reaper's Avatar
Thanks for the compliment. They are fun to do, although a lot of work. But in the end, I think it always pays off. Almost every guy I have worked with has improved his design in some pretty signficant manner after seeing the renders... I'd say 90% or more. It certainly kept me motivated during the build of my theater... that's for sure...
reap
reaper is offline
post #108 of 3772 Old 09-29-2005, 04:04 PM
BjsAust's Avatar
Looking great! Very impressive so far.
BjsAust is offline
post #109 of 3772 Old 09-29-2005, 07:10 PM - Thread Starter
SmX
SmX's Avatar
Well Today Marks one Month since I started constructing The Theater. I feel it would of went a bit faster if I had more reliable helpers. But, Looking back at my first Post in this thread, I just realized how much things got changed along the way.
For One, I stated the room was going to be 20' x 16' x 8.5 ceiling
it ended up being 20'-4.5" x 15' -1" x 9' Ceiling.
I Stated I was Going to do Double Drywall with RSIC Clips on The Ceiling
it ended up Being 3 layers of 5/8"s Drywall with Green Glue between each layer.
I stated I was going To use 5/8"s & 1/2" Drywall
I ended up using Double layers of 5/8"s
I stated the rear Platform was going To be 10" high
It ended up being 12" high
I stated all lighting will be Low voltage
Now all lighting will be High Voltage or ?line Level I should Say.
I started with 60 Pieces of 5/8"s Sheet Rock and
I ended up needing 84 to complete the room
I thought I was gonna Need 1,000 lbs of Sand to fill The stage
I ended up needing 4,000 lbs.
WWW.SMXSCREEN.COM
SmX is offline
post #110 of 3772 Old 09-29-2005, 07:51 PM
Liked: 3246
I think we have all felt your pain. But I think you will be really impressed with the result. I know we all are watching this thread in anticipation of it all coming together.
I started out thinking a wall with a built in RP and a nice curved sectional.
It's now a FP with sand filled stage, Wall treatments, riser for second row, Berkline 99's and tactile transducers (yet to install), a stand up granite top bar (plan) with four stools behind that. I boarded up two windows that I already had installed all the trim boards. Also had to cut holes in my freshly constructed walls to fish cables to the projector.
Of course my biggest mistake was taking my wife to a model home and letting her see a basement mini spa. What started out as a full bath, now is planned to become a bath with steam and a separate sauna attached. This required the removal of a 10 ft long framed up wall to reconfigure.
We still haven't seen Eye to Eye on the selection of carpet or the tile.
post #111 of 3772 Old 09-30-2005, 06:07 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
I've SEEN BIGmouthinDC's place....he should change his moniker to BIGProjectinDC!
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #112 of 3772 Old 09-30-2005, 06:14 AM
SVonhof's Avatar
Quoted: 14 Post(s)
I know what you mean BIG, I was going to do carpet on half the height of the walls and some simple trim to finish it off, a curved couch and some dark colors to go along with the projector.
I ended up using acoustically transparent fabric over wall treatments, three love-seats with shakers for every seat, a platform in the back, two windows blocked off completly, remote control lights and blinds.... And to top it off, after I had started working on things, my wife almost convinced me to swap sides of the room that the screen would be on and leaving the equipment where I had planned. That would have put all equipment in the back of the room and me trying to figure out how to fit everything...
SVonhof is offline
post #113 of 3772 Old 09-30-2005, 10:36 PM - Thread Starter
SmX
SmX's Avatar
Well Today was a Gruesome day.
I had to go to Home Depot and get 14 Sheets of 3/4" Plywood to finish the Platform and Stage. Spent 4 hours in Home Depot waiting for them to find someone to Drop the wood and then I had them rip all the sheets to the rough sizes I needed to finish the Stage and Platform.
They had also shorted me 30 Bags of Sand on the previous delivery so I had to pick that up as well. They had previously delivered 20 Sheets of warped 5/8"s plywood I was gonna use for the stages and I decided to return it and get 3/4"s allready ripped to Size.
Well The gruesomeness was having to load all that Sand and 14 Sheets of Plywood on the Home Depot Truck by Myself, Drive home unload It all by myself. Then Load up the 20 sheets of 5/8"s to bring Back, then unload the 20 sheets at Home Depot to return it.
On top of all this it was like 500 degrees out here today and all my clothes were Soaked from sweat like If I jumped in the pool.
After all that work, I was burnt out and called it the Day.
The biggest and hardest part of building is all the Loading and unloading and hours spent at Home Depot. One good thing about Home Depot is that you can return something from 2 years ago without a receipt and get a store gift card.
On a better Note, my neighbor is a contractor and gave me one of his guys to help me complete this project (*wish I would of known this before all the loading and unloading). So I will have a new helper starting Saturday (Today). He will have the awesome Job of Bringing the 4,000 lbs. of sand inside the house and start filling the stage.
Last Night I did Manage to get the Platform Wired up, conduited, and insulated. The platform will have 4 outlet boxes (2 on the Front Riser and 2 on the Back floor) and one double gang box for Cat 5/Phone line/cable.
WWW.SMXSCREEN.COM
SmX is offline
post #114 of 3772 Old 09-30-2005, 10:56 PM
SVonhof's Avatar
Quoted: 14 Post(s)
Ruben, be carefull with the Home Depot returns without a receipt. If you do it too many times, you will get flagged in their system and they will stop allowing you to return stuff. They will assume that you are stealing the stuff and returning it for something that you really want.
If you have the receipt, bring it with you always.
SVonhof is offline
post #115 of 3772 Old 09-30-2005, 11:05 PM - Thread Starter
SmX
SmX's Avatar
Yeah, I am already in the Home Depot System as a Suspend. The managers all know me well there and know I spend lots of money there and see me there almost every day.
I have returned literally Thousands Of Dollars worth of merchandise to Home Depot without the Receipt. Even though I save all my Receipts, it is too Much work too look though all the boxes for them and then try to find that 1 Home Depot receipt I need a few months down the road.
WWW.SMXSCREEN.COM
SmX is offline
post #116 of 3772 Old 10-01-2005, 01:53 PM
Liked: 3246
I have a 1 inch stack of HD receipts for my basement project. Every couple of months I staple a batch together and put the big alligator clip around the accumulating stack.
When I return something I have this thing in my pocket. When they say do you have the receipt, I say Yes it's right here and hand them the stack. Never had a problem.
post #117 of 3772 Old 10-01-2005, 02:54 PM - Thread Starter
SmX
SmX's Avatar
Well the new helper arrived at 2pm on the dot today as I asked him to. We banged out bringing In all the Sand, Plywood, and 2"x 2"s and Got the Stage Lined and filled in under 3 hours. We worked only a few hours today just to do the Heavy Stuff.
About 35% of the Sand was Damp the rest was dry. So I put all The dry sand on the Bottom and the Damp Stuff on Top and got a powerful fan blowing on It now. The Stage ended up using 76 50 Lb bags to level it to the top. So I had 6 bags Left that I will just throw inside some of the cavities in the Radius sections of the Stage and use insulation for the rest of unfilled cavities. I threw those extra 6 Bags on top of the stage for now to dry out.
Here some Flicks, A Bit Messy, but you get the point
I took away the 2 radius parts of the stage to make filling the stage easier.
Come to find out my new helper use to build boats for a living and he is a very detailed carpenter, so that will Save me allot of work.
We continue on Monday.
I also went to Home Depot today and picked up my outlets and other things for the Platform. I will have a Plate on Front of the Riser of the platform that will contain a Stereo RCA Input, A Cat5E Input, a Phone Line, A SVHS Input and a Coaxial Cable input which will all run to the equipment Rack. I also have an 2" Empty Conduit Running from the Front of the platform riser to the Rack as well. I think that should cover all my needs for front of the Platform for now. This plate will serve usefull for when I need to hook up a video camera or a video game console that a friend may bring over as well getting online with a laptop, etc.
This is what I put together...
More to Come on Monday.
WWW.SMXSCREEN.COM
SmX is offline
post #118 of 3772 Old 10-01-2005, 05:39 PM
Liked: 3246
Any thought to butt kickers?
I thought that they were a gimmick that this 55 year old could pass up until I visited another local DIY HT and Whoa are these things neat. It gives the impression that your sound is literally shaking the house.
The reason I ask is now is the time to put in the wiring. I used plates with speaker banana connections in the front edge and a floor mount plate on the riser. Since I had the chairs before wiring I was able to determine the riser floor locations under the chairs not under an arm and not right under the motor. When complete you won't see any wiring on the riser. Having said that I haven't installed the aura shakers in my berklines yet.
post #119 of 3772 Old 10-01-2005, 10:10 PM - Thread Starter
SmX
SmX's Avatar
I never tried them, and I was going to have 3 of them pre-installed in My chairs at The factory to see if I like them, but after talking To a few people about them, I decided to pass on them. But I am still planningg to install outlets around the chairs for them in case I try them in the future and like them. So I should do the bananna plugs too as well, but like you said, I will not know where to position anything untill the chairs arrive.
So for now, I guess I can leave my floor boards untied untill the chairs arrive. I ordered my chairs on Sept 13 from leather direct so it may take another 4 weeks or so before they arrive due to them being a Leather and microfabric combo.
By the way, leather direct really worked with me on pricing. Their prices were already the best I found online, and they dropped even more off the chairs to accomodate my budget and give me the top grade Leather and Microfabric combo I wanted.
Get Those Bad Boys installed and let me know how ya like them.
WWW.SMXSCREEN.COM
SmX is offline
post #120 of 3772 Old 10-01-2005, 10:19 PM - Thread Starter
SmX
SmX's Avatar
Just a quick update The sand looks pretty much dried up already. I shoveled it around and it is coming along quite fast. It should Definately be 100% dried by Monday.
Also, if it is still a Slight bit damp when I close the stage up, won't it still dry up inside?
And if it doesn't, is it really gonna get much mildew in there? I just don't Know how anal I should be about having the dryest possible sand.
Ruben
WWW.SMXSCREEN.COM
SmX is offline
