The Laranberg Theater Begins - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 194 Old 09-16-2009, 07:51 PM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 83
chinadog is offline
post #182 of 194 Old 09-16-2009, 07:59 PM - Thread Starter
larryep's Avatar
thanks Bud
can you believe it has been 4 years since we started are theaters.
where does the time go.the madness never ends!
congradulations on the home theater revealed dvd series!
larry
larryep is offline
post #183 of 194 Old 02-20-2010, 05:05 PM - Thread Starter
larryep's Avatar
any of you guys wanted to simplify your system and get 7.1 channels of audio to your speakers get a amp. My denon avr started to hiss thru all sp eakers. I knew it was on its way out. i was already doing analog inputs into the denon receiver so I decided to stick with using analog.Right now I only have one device and that is the HTPC. I decided to go with this amp
http://emotiva.com/upa7.shtm
the audio from this amp has made my speakers sound the best they have every sounded. I guess if I add other devices I will get a preamp\\processor.The tuner solution is internet radio with pandora and ALOT RADIO PLAYER toolbar for local radio. My wires on my rack have been simplify which is always a plus. I control my speakers with windows 7 audio controller and the software that uses audio. I have finally crossed over to seperates and I like it, well kind of no preamp\\processor!
larryep is offline
post #184 of 194 Old 03-31-2010, 04:25 PM - Thread Starter
larryep's Avatar
My backlit Lenovo N5901 Mini Wireless Keyboard
http://www.avsforum.com/avs-vb/showt...7#post18412747
larryep is offline
post #185 of 194 Old 07-20-2010, 06:39 PM - Thread Starter
larryep's Avatar
here is xlobby running on windows 7. starts movies,pics and music
Uploaded with ImageShack.us
here is xlobby running in xp mode.
for lighting and curtain control
larryep is offline
post #186 of 194 Old 11-13-2010, 06:14 AM - Thread Starter
larryep's Avatar
larryep is offline
post #187 of 194 Old 02-12-2011, 06:59 AM - Thread Starter
larryep's Avatar
any tablet users out there to control htpc?
I have seen some nice tablets under 300 dollars. I would prefer to spend no more than 200 hundred dollars though. While xlobby is still my front end it can be control thru web base or client on a tablet.
what are you guys using for remote control?
larryep is offline
post #188 of 194 Old 08-25-2011, 07:11 PM - Thread Starter
larryep's Avatar
larryep is offline
post #189 of 194 Old 11-21-2011, 05:38 PM - Thread Starter
larryep's Avatar
RII WITH MIMO MONITOR
larryep is offline
post #190 of 194 Old 09-13-2012, 10:05 AM - Thread Starter
larryep's Avatar
larryep is offline
post #191 of 194 Old 06-28-2013, 03:27 AM - Thread Starter
larryep's Avatar
larryep is offline
post #192 of 194 Old 12-08-2013, 05:47 AM - Thread Starter
larryep's Avatar
running the 4810 for 4 months in a enclosed space with quiet fan mentioned above. have not had any issues. Projector is sticking out from drywall cubbie by 4 inches. The only downside of having a projector in a enclosure is accessing connections. I use male to female hdmi's for oppo and chromecast. male to female 3.5 cable for ir connection
using old projector spot {which is right above jvc 4810} for battery backup ir and hdmi connections and potential darbee 5000.
larryep is offline
post #193 of 194 Old 10-18-2016, 11:57 AM - Thread Starter
larryep's Avatar
larryep is offline
post #194 of 194 Old 10-18-2016, 12:22 PM
VTstang's Avatar
Quoted: 98 Post(s)
Liked: 58
Originally Posted by larryep View Post
I appreciate people bumping their build threads so that we can see ones that are otherwise buried, but most of your pic links are broken....
VTstang is offline
