SWithey Home Theater Construction - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 02-08-2006, 02:13 PM - Thread Starter
swithey's Avatar
Okay, just added Option #6. I don't think I'll get the WAF on this one but made it anyway
swithey is offline
Old 02-08-2006, 02:23 PM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 86
Any way to keep the detail but give yourself a few more inches on the sides of black? You do lose a lot of detail (the WAF factor) with option six, although probably best with the lights off!
Bud
chinadog is offline
Old 02-08-2006, 02:25 PM
sk8conz's Avatar
Option 5 or 6 gets my vote.
I have my screen on a very dark blue wall (WAF meant black was out). Once the lights go down, the wall looks black anyway and the picture just appears to hang in space.
Very nice as you get drawn into it.
Darrin
sk8conz is offline
Old 02-08-2006, 02:32 PM - Thread Starter
swithey's Avatar
Bud
Bud,
Okay, there is now an Option #7 as you descibed above. I may be able to get this one passed the wife. Let mm know if this is what you were talking about.
swithey is offline
Old 02-08-2006, 02:45 PM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 86
Steve,
Exactly. Looks great. I officially change my vote to number 7!
Bud
chinadog is offline
Old 02-08-2006, 02:49 PM
Big Worms's Avatar
#7 looks good. That is my vote.
.: Ernie :.
Big Worms is offline
Old 02-08-2006, 03:39 PM
v1rtu0s1ty's Avatar
Originally Posted by swithey View Post
I like the emboss effect on the wood where you had the X in the middle. Can you please share how do to that?
Here is my wild guess: Cut a 1/2 think plywood. Make the shape you like and stick it to the other plywood underneath it.
v1rtu0s1ty is offline
Old 02-08-2006, 03:40 PM
jandawil's Avatar
Hey Steve...nice work. Another vote for 7 here. I think it will make your picture jump out more. 5 was nice too...
jandawil is offline
Old 02-08-2006, 03:43 PM
ronnie_jackson's Avatar
I also like #7. Very visually appealing.
Ronnie
ronnie_jackson is offline
Old 02-08-2006, 03:46 PM
Big Worms's Avatar
He hasn't done them yet (I think), but the way I would do it is use a router with a straight bit. Then just paint the inside black.
.: Ernie :.
Old 02-08-2006, 03:47 PM
SmX
SmX's Avatar
Black is a must. I just finished my screen wall, about to update my thread in a few. The black sucks you into the movie. #6 or #7.
Ruben
Follow SmX on Facebook
SmX Video Projection Screens and Masking Systems
WWW.SMXSCREEN.COM
SmX is offline
Old 02-08-2006, 03:58 PM
v1rtu0s1ty's Avatar
Of course #7!!!
Old 02-08-2006, 04:44 PM
sk8conz's Avatar
#7 !!!
sk8conz is offline
Old 02-08-2006, 05:31 PM - Thread Starter
swithey's Avatar
Big Worms got it right. It will start with 3/4" MDF with maple veneer applied to the top. Then using a straight-edge, I'll make the grooves with a 1/2" router straight bit (just like SandmanX/Ruben did on his columns). Then I will insert the 1/2" aluminum strips into the notches to make the finishing touch.
I have not done these yet but when I do, I plan to document the process.
swithey is offline
Old 02-08-2006, 05:50 PM
sleeks's Avatar
-Brian
sleeks is offline
Old 02-08-2006, 06:03 PM - Thread Starter
swithey's Avatar
Looks like the overwhelming majority like #7. Thanks guys I'll run it by the wife this eve and see what she thinks.
swithey is offline
Old 02-08-2006, 06:16 PM
v1rtu0s1ty's Avatar
So, all I need to buy is a plunge-router tool and the straight-edge bit. Thanks guys for the information. It helps me a lot. By the way, do you have a full picture of that picture you showed to us?
Old 02-08-2006, 06:20 PM - Thread Starter
swithey's Avatar
We're IN Had the 5min meeting with the wife and Option #7 was the winner. This will make the build process easier too -- yea!!
Thanks again guys.
swithey is offline
Old 02-08-2006, 10:01 PM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 86
5 minutes? It took that long? Man, she must be pretty picky. Did you tell her I said it was OK?
HA!
Bud
chinadog is offline
Old 02-09-2006, 07:33 AM - Thread Starter
swithey's Avatar
HA!
Bud
LOL!!! She did take her time to look through every option. She deleted ones she did not like until there were only a few left. I had to sell her a bit on the one with a larger black border.... but in the end, everyone was happy
swithey is offline
Old 02-09-2006, 09:51 AM
ciotime's Avatar
Im also planning on doing a home theater room. Have you started making your absorbers yet? Also where exactly will you place them?
ciotime is offline
Old 02-09-2006, 10:28 AM - Thread Starter
swithey's Avatar
No, I have not started on them yet. They will be placed on the front left and right corners of the theater (behind the false wall). The corners will be full from front to rear (24" wide, 24" deep x 8' tall) with cotton. Sandman used the same stuff. Here it is below from his construction thread (Ruben, hope you don't mind the pic-link).
One thing I'm doing slightly different is to run the material vertically instead of cutting it into a bunch of 2'x2' pieces stacked horizontally (like Sandman did). I'll need to make a simple 1x2 frame to hold it upright (to reduce compression). I plan to make a frame something like this.
swithey is offline
Old 02-12-2006, 05:19 PM - Thread Starter
swithey's Avatar
Weekend Update...
Click Here to Enlarge Photo
This is the NEW front wall. Notice the roomy false wall area behind the screen. This will make the front entertainment center very shallow since the speakers and sub woofer will live inside that area.
I made a diagram for the front wall to detail exactly where I would put every stud. I know this seems like overkill but you would not believe how much this helps in the planning process to get things right the first time.
This is a rendering of the final front wall design.
Watch out Bud, I'm building up speed and trying to catch up with you
swithey is offline
Old 02-12-2006, 07:09 PM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 86
Steve,
Looking good! I think I've got a target on my back now...
Bud
chinadog is offline
Old 02-13-2006, 11:41 AM
GeorgeIII's Avatar
Steve
Boy, 7 choices, no wonder you're having a hard time making up your mind.
Personally I like #6. I think it's because the screen is the prominent item on the wall. The other options (for me) emphasize the woodwork. Also in a timesaving sense, #6 cuts down on the amount of detailed woodwork that has to be done.
You know the more you think about this the harder a decision is. Now I'm coming up with reasons for one of the others because I really like nice woodwork. What we are deciding on is the visual effect when entering the room with some or all of the lights on. If the theater is light controlled, then the woodwork will disappear when the lights are turned off. That said I like #5 or #7.
I have a real hang up with the light tan fabric, it would be great with the lights on but I'd be afraid it would be too visible even in a darkened room. Personally I'd go with any option that didn't use the tan fabric.
It's your theater to live with, you need to decide. Which one does your wife like? How about getting some brown craft paper, black & white sheets and make a mock up?
Good luck
George
GeorgeIII is offline
Old 02-13-2006, 12:05 PM - Thread Starter
swithey's Avatar
George, thanks for the comments. I welcome any suggestions as this is a work-in-progress. And, since I'm doing it myself, it does not cost too much to change things as I go
Originally Posted by GeorgeIII View Post
Steve
As far as the woodwork -- my wife and I really like it. It is more work (for me) but I want the room to have a nice crisp and modern appearance when people walk in (with the lights on). Once the lights go off, yes the "wood" effect is minimized -- but hopefully if I do it right, the low lighting will take over from there (and the movie too LOL!).
I plan to have 6 lighting zones in the room. Each column will have a light shooting up at the angled vault (just for effect -- wife did not want wall sconces), rope lighting around the coffered ceiling, fiber stars inside or above (have not decided yet) the coffered ceiling and finally 9 can lights (3 front, 3 middle and 3 rear) each row on a separate zone. So making the lighting "just right" should be easy to do.
Honestly, I feel the same way. The bummer part is GOM 701 (or GOM Vertical Surface Solids 2402) does not come in a dark brown color that is acoustically transparent. All the walls will be a chocolate brown (GOM Anchorage 2335 - 2083 Coffee Bean). The brown anchorage is not AT so it cannot be used for speakers. WAF will not allow black over the speakers.
If I could find a dark brown AT material to cover my speakers, I'd use it. But as of right now -- I have not been able to locate anything that would work. If anyone knows a fabric that will work and is AC, PLEASE LET ME KNOW!
swithey is offline
Old 02-13-2006, 01:05 PM - Thread Starter
swithey's Avatar
George,
Looks like you got me thinking more about that. I found about 4 places that have this color but only this one had what looks like the dark brown that I'm going for (to match the walls). Here is an image of the fabric:
It is available here for $15/yard. I've requested a sample, we'll see what happens.
Simply Speakers
I had my blinders on as I was ONLY looking at GOM. Thanks for opening my eyes.
swithey is offline
Old 02-13-2006, 01:11 PM
George,
It is available here for $!5/yard. I've requested a sample, we'll see what happens.
Where did you find that stuff? Is it FR?
Also, to bad we have to be concerned with what it looks like with the lights on. It would be nice to finish it out in linacoustic, turn the lights off and call it done.
Ronnie
Old 02-13-2006, 01:29 PM - Thread Starter
swithey's Avatar
Ronnie
Ronnie,
You hit the nail on the head as far as finish out. It is a lot of work but it will be so much fun once it's done.
I updated my post above to include the vendor link. I meant to put it in the 1st time -- sorry.
Steve
swithey is offline
Old 02-13-2006, 02:00 PM
cool, thanks. I was hoping you were talking about wall fabric. Oh well.
Ronnie
