Royal Fortune Construction Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #541 of 855 Old 01-14-2008, 08:06 AM
BritInVA's Avatar
Nice tile job - bar sign looks great too.
For Pub accessories take a look at: http://www.thepubshoppe.com/
Cheers,
Mark
BritInVA is offline
post #542 of 855 Old 01-14-2008, 09:48 AM - Thread Starter
jikkjack's Avatar
Originally Posted by aham23 View Post
that is one nice snack bar area. i think its just what my wife has in mind. where did you get the "fins up" triangle sign? very cool.
Thanks Aham. I got that sign at the local Publix. Covert operation.
jikkjack is offline
post #543 of 855 Old 01-14-2008, 09:50 AM - Thread Starter
jikkjack's Avatar
Thanks Mark. Will take a look at that site. The basement still needs lots of decorations/furniture.
I am now considering some big changes...stay tuned.
jikkjack is offline
post #544 of 855 Old 01-15-2008, 06:41 AM - Thread Starter
jikkjack's Avatar
Quick update. Just wanted to show off my new toy. I am in the process of setting up my new MX-980 Remote with a nice parchment graphical display. This theme really compliments the Nautical theme in our house. I had to alter the default graphics a little but the real work with any URC remote is setting up all of the macros and testing.
Well - at least I know what I will be doing for the next few days.
jikkjack is offline
post #545 of 855 Old 01-15-2008, 07:19 AM
BritInVA's Avatar
How easy is it to customize & program......assunimg there is a PC app. Can you get the codes fort other devices from the web or do you need to get the remote to learn.
Will be eagerly awaiting your results and how you like your new toy.
Cheers,
Mark
BritInVA is offline
post #546 of 855 Old 01-15-2008, 07:39 AM
aham23's Avatar
SWEET the 980 looks freaking awesome! the remote and BluRay are my next purchase. for remotes the 980, 810, and 900 are on my short list. let us know what you think. customized graphics are sooo cool on a remote. later.
aham23 is offline
post #547 of 855 Old 01-15-2008, 08:36 AM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Jason
You can come over and build my wet bar next
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #548 of 855 Old 01-15-2008, 08:46 AM - Thread Starter
jikkjack's Avatar
ha ha! Ok. Sounds good. I still have to add one of those Bowl Sinks to mine. I am just being lazy and taking my time to get to that project. Since I did not originally plan to have a bar area, I didn't run all of the copper pipes under the sink area. I have a friend who is a plumber that told me it would not be hard at all to retrofit into my current area. He is going to assist me when I get around to it.
jikkjack is offline
post #549 of 855 Old 01-15-2008, 10:34 AM
John Martin's Avatar
Jason,
Do you have a closeup photo of the front of your bar showing the bead board? I am curious how you did your corners.
John
John Martin is offline
post #550 of 855 Old 01-15-2008, 11:53 AM - Thread Starter
jikkjack's Avatar
John,
I will snap one tonight. I just used a piece of corner trim found at HD in a L pattern. It hid the seems perfectly and is low profile.
jikkjack is offline
post #551 of 855 Old 01-15-2008, 11:59 AM
No need for the picture then. I thought that is what it was but it was hard to tell. I am using bead board as well so i was curious as to how you did that area.
John
post #552 of 855 Old 01-15-2008, 12:17 PM
smakovits's Avatar
Quoted: 30 Post(s)
Originally Posted by jikkjack View Post
Ok. I am putting up all of my linacoustic and batting first and then will add the firing strips once I finalize my decision on what I want to do. Right now the thinking is basemolding, chair rail molding, and crown. It is so easy to cut the linacoustic that I am not worried about having to retrofit the furing strips in later.
Batting on the other side.
Ok. That brings us to where I am right now...
By putting that material up on the walls is that an easy way to do acoustical treatments? And does JoAnn fabric sell it as "linacoustic". Do others recommend this method as well?
smakovits is offline
post #553 of 855 Old 01-16-2008, 07:57 AM - Thread Starter
jikkjack's Avatar
NO. If you read on further into my thread - you will see that I ended up ripping it all down and hired Bpape to help me with acoustical treatment selection/placement. I originally was just copying what others had done...big mistake.
JoAnn fabric does not have Linacoustic. They sell the polybatting.
jikkjack is offline
post #554 of 855 Old 01-16-2008, 03:13 PM
smakovits's Avatar
Quoted: 30 Post(s)
Ah, I see...I guess I missed the part about ripping it down...sometimes I get lost in long posts and just miss stuff. Are your new acoustic treatments a much better solution?
post #555 of 855 Old 01-17-2008, 09:20 AM - Thread Starter
jikkjack's Avatar
Night and day my friend...I am soooo glad I changed it out.
jikkjack is offline
post #556 of 855 Old 01-21-2008, 08:27 AM
BritInVA's Avatar
Jason - how is the MX-980 Remote. Now you've had it a week what are your thoughts on ease of use & ease to program?
Also I recollect you have the PS3 in your set up. I believe that does not support IR/RF natively just Blue-Tooth. Have you found a way to control it with the MX-980? I read there is a way by using 'PS2 Controller to USB adapter' and then a 'external IR receiver' that slots into the adapter. But even then remote functions are limited.
Nearly ready to pull the trigger on remote.
Cheers,
Mark
BritInVA is offline
post #557 of 855 Old 01-21-2008, 08:36 AM
dc_pilgrim's Avatar
Yup also curious.
Three options I know of:
1. The old PS2 DVD remote to USB adapter
2. The Nyko remote + dongle (~$20 on amazon)
3 The one some developer made and has a following here:
http://www.avsforum.com/avs-vb/showthread.php?t=946674
The third one has two models, one for $50 that can turn the PS3 on /off (the missing feature in all the other options), and one for $35 that acts a reportedly more reliable version of 1 and 2 (which have had lag issues from time to time).
dc_pilgrim is offline
post #558 of 855 Old 01-21-2008, 01:56 PM
jjackknife's Avatar
[quote=jikkjack;12831542]NO. If you read on further into my thread - you will see that I ended up ripping it all down and hired Bpape to help me with acoustical treatment selection/placement...QUOTE]
JJ... do you have a solid screen?... or AT? Just curious as to what prompted the change from linacoustic to 703 on the front wall.
jjackknife is offline
post #559 of 855 Old 01-22-2008, 08:22 AM - Thread Starter
jikkjack's Avatar
Mark and Dave - I like the 980. The software editor is a little wonky at times but overall it is ok. Programming has taken me quite a bit of time and effort. I haven't decided on a PS3 solution yet but probably will buy one of the ones mentioned above. Since you have to go to the PS3 to put a movie in it...dosen't seem to necessitate the power on/off functionality for me rather the IN MOVIE controls. Currently, I have the PS3 controller and MX-980 sitting side-by-side on the seat to my right and that will not change even if I do get a control option for moives on the PS3.
Jjackknife - I have a solid screen. Bpape (Acoustical Engineer) prompted the changes with an acoustical analysis of the room.
jikkjack is offline
post #560 of 855 Old 01-22-2008, 09:17 AM
dc_pilgrim's Avatar
I agree that the power button stuff is overblown on PS3 control. I am mostly out of the universal remote market pending my move. But URC seems like a logical step up from Harmony (I have the 880 in my den, good not great).
post #561 of 855 Old 01-22-2008, 10:54 AM
bpape's Avatar
Sorry for the mini-hijack.
Mark (DC), tried to PM you but you're not accpeting PMs. Shoot me an email when you get a chance.
Carry on.
By the way, looking good Jason!
Bryan
I am serious...and don't call me Shirley.
Bryan Pape - Lead Acoustician
GIK Acoustics
bpape is offline
post #562 of 855 Old 07-02-2008, 07:57 AM - Thread Starter
jikkjack's Avatar
I have been pretty busy lately and noticed that I never posted final shots of my theater or the basement. So - this weekend I will try to get some updated (final shots). I am getting a new toy today to replace my very outdated projector. Anyone else have the new Panasonic AE-2000U? I am pretty excited about getting it and can't wait to see difference between my old 720P vs. new 1080P.
jikkjack is offline
post #563 of 855 Old 07-30-2008, 06:29 PM
morpheus6d9's Avatar
where the pics of the new projector
morpheus6d9 is offline
post #564 of 855 Old 08-26-2008, 12:08 PM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 83
Yeah, your thread has crickets chirping, pal.
Bud
chinadog is online now
post #565 of 855 Old 08-26-2008, 03:18 PM
Old
Old's Avatar
Second, I finished the backsplash (for decorative effect) on the back counter. This counter now just needs a new Popcorn Machine. I am looking this week for one to replace the plant.
I am VERY IMPRESSED!
Excellent work!
May I ask where you got your granite tiles, with the edge pieces?
Old
Old is offline
post #566 of 855 Old 08-27-2008, 07:03 AM - Thread Starter
jikkjack's Avatar
Thanks Old. I got them at Floor and Decor. They have a pretty good selection and great prices.
jikkjack is offline
post #567 of 855 Old 08-27-2008, 07:04 AM - Thread Starter
jikkjack's Avatar
@morpheus6d9 - I will try to post some updated pictures this weekend. I think it is a weekend where I actually don't have anything going on. Fingers crossed.
jikkjack is offline
post #568 of 855 Old 10-09-2008, 01:21 PM - Thread Starter
jikkjack's Avatar
Ok - after a long hiatus...I am back. I will have updated pictures this weekend and will also begin working on this:
More pics soon...
jikkjack is offline
post #569 of 855 Old 10-09-2008, 01:35 PM
nebrunner's Avatar
Quoted: 52 Post(s)
Liked: 53
cool, a mame machine will make a great addition to your basement!
I built one a few years back and have gotten a lot of enjoyment out of it.
nebrunner is offline
post #570 of 855 Old 10-09-2008, 03:08 PM - Thread Starter
jikkjack's Avatar
Awesome. Now I have a resource if I have any questions. Thanks for the post Nebrunner.
jikkjack is offline
