BritInVA Construction Thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #331 of 1333 Old 08-14-2006, 12:50 PM - Thread Starter
BritInVA's Avatar
Originally Posted by r00ster View Post
BTW good luck on the bathroom they are a killer.
No kidding - the tiling was easy - the grouting is slow a tedious and my finger tips are now sore from smoothing the gout lines.
Unfortunately looks like I was not meticulous enough in getting excess grout of a few tiles - anyone got recommendations for removing dryed on grout - the tiles have a rough face.
Cheers,
Mark
BritInVA is offline
post #332 of 1333 Old 08-14-2006, 01:03 PM - Thread Starter
BritInVA's Avatar
One bit of HT news. Got my fabric for the wall panels over the weekend. From Hancock Fabrics "Diamonds Decorator Fabric in Gold" (item 756676N) - they had a Sale on Saturday got 40$ off
Anyone got recommendations on a spray Fire Retardant?
Cheers,
Mark
BritInVA is offline
post #333 of 1333 Old 08-15-2006, 06:23 AM
mastiff34's Avatar
Cheers,
Mark
A moist sponge work's great for smoothing out the grout lines.
As for removing dry grout, I got this tool from the tile shop that is basically a circular
piece of brillo, works great on removing group from stone tile. I think it was called a scuff pad or something like that.
Loganed on 4/8/2008
List to be completed
Install blinds - DONE
Finish plumbing my bathroom - WIP
Build EQ Shelves - WIP
Program insteon - DONE
My Build Thread
mastiff34 is offline
post #334 of 1333 Old 08-15-2006, 10:51 AM
new_to_this's Avatar
Cheers,
Mark
I've never heard of anybody using their finger tips for smoothing out grout lines. No wonder it was so tedious. Smoothing grout is the easiest part of tiling for me. Why is it better then just using a wet sponge?
new_to_this is offline
post #335 of 1333 Old 08-15-2006, 06:27 PM - Thread Starter
BritInVA's Avatar
Thanks 'mastiff34 ' & 'new_to_this'
I am using a damp sponge on the grout but I find a damp finger gets a neater more even finish.
My biggest problem right now is drilling thru these stone tiles to fix the shower to the wall. If I use a standard masonary bit in a non-hammer action drill it barely dents the tile. If I use hammer action it breaks the tile
I'll see if I can get a carbide-tipped masonry bit tomorrow - or should I be using something else like a diamond tipped bit?
BritInVA is offline
post #336 of 1333 Old 08-15-2006, 06:46 PM
chinadog's Avatar
Quoted: 75 Post(s)
Liked: 279
Mark, I tried all the damn carbide bits at HD, with no success. I managed to work it just right where I cut use a tile saw to mark an arc for the pipe and use a separate piece of tile to fill the hole on the side of the tile. What I mean "managed to work it just right" is the flange or the shower pipe or the spout covered the imperfections. You'd never know I pieced it. Granted I lucked out doing it this way since I used 6 inch tile. Hopefully you can find a decent bit to solve your problem.
Good luck.
Bud
chinadog is offline
post #337 of 1333 Old 08-15-2006, 07:01 PM - Thread Starter
BritInVA's Avatar
Bud - yeah know that trick, most of my pipe holes were near tile edges so were pretty easy. I had tried a tile cutting bit in my rotarzip but was useless and went to method you suggested.
My problem is I need to drill 5/16" holes to screw the shower surrond to the wall. Plus will have other fixtures for toilet paper / towls etc.
Cheers,
Mark
BritInVA is offline
post #338 of 1333 Old 08-15-2006, 08:43 PM
Big Worms's Avatar
You need these.
I bought them at Walmart and they are the best for drilling into tile.
.: Ernie :.
Big Worms is offline
post #339 of 1333 Old 08-15-2006, 08:45 PM
Chiahead's Avatar
Originally Posted by Big Worms View Post
You need these.
I was burning through bits trying to make 2 holes for a closet sliding door guide in a peice of tile, until I bought one of these. Went through the ceramic tile like butter.
Michael
PSN: Chiahead
Chiahead's Man Cave - Indexed
Loganed on 8/29/2008
Chiahead is offline
post #340 of 1333 Old 08-15-2006, 08:45 PM
Toxarch's Avatar
You could always try a colbalt or titanium drill bit. Something like you would use to drill metal. Might work as long as you don't apply too much pressure. You might have to chip or scratch the tile to keep the bit from walking and of course try it on a practice piece first.
If you want to use something like a carbide tip masonry bit, I find that sharpening them first will do wonders. Sparpen them on a grinder of some kind until you get a nice sharp bevel and point. Then use it do drill and it will work so much better than it did out of the package. That might help you drill the tiles. I use my table grinder on my masonry bits before I drill anything with them in the hammer drill.
There are no stupid questions, but there are a LOT of inquisitive idiots. Me being one of them at times.
My HT Website in progress.
Toxarch is offline
post #341 of 1333 Old 08-16-2006, 06:21 AM - Thread Starter
BritInVA's Avatar
Guys - Thanks for the advice.
Went into Wallmart on way into work this morning and picked up a set of those bits for a few cents under $10 so hopefully will have better luck tonight. I also had to pop into Lowes for a few other items - the same set was a few cents under $16
I never really thought of using Wallmart for stuff like this - think I'll pay a bit more attention to what they stock.
Cheers,
Mark
BritInVA is offline
post #342 of 1333 Old 08-17-2006, 05:42 AM - Thread Starter
BritInVA's Avatar
Those bits worked
Was quite slow but worked and got my holes drilled - Thanks again for suggestion.
Cheers,
Mark
BritInVA is offline
post #343 of 1333 Old 08-17-2006, 08:19 AM
Big Worms's Avatar
Good to here Mark.
.: Ernie :.
post #344 of 1333 Old 08-26-2006, 06:58 PM - Thread Starter
BritInVA's Avatar
Well visitors have gone up to Boston (they are back on Thursday) so was able to get some work done in the HT.
I got another coat of red up - still not 100% happy as my drywall finish isn't as good as it could have been. I may end up papering over it. Here is a pic.
I also got all the electrics wired and on and I mounted the PJ. I hooked up a portable DVD player and picture looked great
Going to hook up all the equipment tomorrow to ensure its all working. Won't be a great deal more progress until labor day.....when I hope to start on the panelling in the HT area.
Cheers,
Mark
BritInVA is offline
post #345 of 1333 Old 08-27-2006, 07:30 PM - Thread Starter
BritInVA's Avatar
Got the HT Equipment all wired up and tested.
Reminder on Equipment.
- Denon AVR 2807
- Panny AE900U
- Oppo 971H
- Ascend CMT SE L,C,R
- Axiom QS-8 surrounds
- HSU STF-2 Sub
- ADC J10 Power Conditioner
A few small gripes
The way the terminals are arranged on the back of the Axiom QS-8's mean you cannot use banana plugs - which would have been useful given the weight and awkwardness of wiring.
I had heard the Denon 2807 manual was useless - and can confirm. Talk about badly written and no seemingly obvious logical order.
But enough griping.
After all was set up the picture (on painted temp screen) and sound (in untreated room) was outstanding .......so I know it can only get better. We watched Shrek 2 and was noticing all sorts of detail we never saw before.
Need to put a IR repeater and 'all in one' remote high up on things to buy.
Cheers,
Mark
BritInVA is offline
post #346 of 1333 Old 08-28-2006, 03:23 AM
jerrodshook's Avatar
Things are coming together nicely Mark. Isn't is great to finally get a picture coming out of that projector? And hearing sound from your speakers? And just sitting in there knowing you built it? Gotta love it!
jerrodshook is offline
post #347 of 1333 Old 08-28-2006, 05:19 AM - Thread Starter
BritInVA's Avatar
Jerrod - Yeah does feel great. Just got to stop watching movies and finish now
Going to be doing some honey do's until labor day and then hopefully back in full swing aftfrom then on.
BritInVA is offline
post #348 of 1333 Old 08-28-2006, 05:50 AM
Thunder7's Avatar
Which ones are you looking at? I am in this situation as well, but am considering going with RF/IR.
-Dave
-There are Ten Thunders in the Wake: The Seventh Thunder is Tribal Man again. --Triumph 1984
-My HT Blog (archived) and Photo Gallery
Thunder7 is offline
post #349 of 1333 Old 08-28-2006, 06:11 AM - Thread Starter
BritInVA's Avatar
Dave - I had in the past bookmarked the Hot Link Pro but I still need to research what others have recommended. This one seems very flexible.
For the remote I'm considering the Universal Remote Control MX-3000 - its a bit expensive (Retails around $1,000) but deals can be found for nearly half that.
Cheers,
Mark
BritInVA is offline
post #350 of 1333 Old 08-28-2006, 12:20 PM
jandawil's Avatar
Hey Mark....I've been lurking and following your thread for some time now and it looks great!! Almost done. I imagine you were just floored when you finally saw that huge image on your screen. I personally needed a cigarette after first seeing the 900u's image on my bare wall and that was without audio. Enjoy it....you've earned it.
jandawil is offline
post #351 of 1333 Old 08-28-2006, 01:05 PM - Thread Starter
BritInVA's Avatar
I'm going to be building my own rack that will be on wheels in a closet disguised as a ticket booth. I've been looking around for a cheap cable management solution and came across these.
Intellinet Rack Mounting Cable Management Ring Pack
Cost for a Pk of 20 is $37.95 + Postage $4.95
Other places seen to charge $5 - $10 each
BritInVA is offline
post #352 of 1333 Old 08-28-2006, 01:31 PM
Cathan's Avatar
I tend to just ziptie my cables once i know I'm finally done. It's cheap and easy.
Cathan is offline
post #353 of 1333 Old 08-28-2006, 01:42 PM - Thread Starter
BritInVA's Avatar
My problem is all my cables enter the closet above the door so I wanted something to manage the cables around the door frame....I'll be using zip ties too.
BritInVA is offline
post #354 of 1333 Old 08-28-2006, 02:11 PM
aaron_hinni's Avatar
I made good use of the screw mount cable ties. I think you can pick em up at the big box stores. They are wire ties with an eyelet at the end to put a screw through.
I also remember seeing someone use simple wire shelving for the horizontal runs.
aaron_hinni is offline
post #355 of 1333 Old 08-28-2006, 07:09 PM
documentarymaker's Avatar
Mark,
DO NOT buy your MX-3000 from an unauthorized dealer. Buy from "proremotes.com" or the like. Universal has cut off support for remotes purchased from "gray market" sources. You wont be able to update your software. See remotecentral.com for info (the universal forum).
I bought mine from an Ebay dealer yr ago and now i'm fudged. No more software support!
As for the cable management - I use these cool little anchors that screw in and then have little slots for the zip-ties to thread through. They come in several sizes and are in-valuable when trying to organize a non-metal rack.
I dont know the name of them - perhaps someone else has used them and can help us out...
Kevin -
In an average home theater room there are 1,257 objects Chuck Norris could use to kill you, including the room itself. There are no weapons of mass destruction. Just Chuck Norris.
documentarymaker is offline
post #356 of 1333 Old 08-28-2006, 07:15 PM
I just read an earlier post where you mentioned the QS8's not leaving room for banana plugs. How does your wiring come out of the wall? Did you run your wires through a box? I am planning on using the same speakers and the same kind of plugs so this concerns me....
Kevin -
post #357 of 1333 Old 08-28-2006, 07:26 PM - Thread Starter
BritInVA's Avatar
Kevin - Yes I used Carlon Adjustable back boxes - symmetrical on each side.
Its possible that you could align the speaker such that the plugs project into the outlet box. But that would have meant the speakers not being symmetrical on each side due the the connection design.
BritInVA is offline
post #358 of 1333 Old 08-28-2006, 07:53 PM - Thread Starter
BritInVA's Avatar
Kevin - a little more info:
This is the back view of the QS8 and the mount
The connections are not quite central and the mounting bar is in a shape of a 'T' so you cannot center over the outlet box (unless you cut the mounting bar).
Cheers,
Mark
BritInVA is offline
post #359 of 1333 Old 08-29-2006, 09:32 AM
Cathan's Avatar
I used the spade styled connectors the second time I mounted my QS8s. My first attempt I tried to use plugs and ran into the same issue. Now I just connect the cable directly to the binding post. Given that I never remove the speakers from the wall, not having the quick disconnect feature isn't a major loss. If ido need to take them down I can rest them on a ladder while i loosen the posts.
Cathan is offline
post #360 of 1333 Old 08-29-2006, 12:33 PM - Thread Starter
BritInVA's Avatar
For now I've just used the wire directly into the bindiing post. Like Cathan says no big deal as normally once they are up thats it - but while I'm mid-build they will be down at times.
Its really not a big deal - just wish I hadn't bothered preparing with bannana plugs - that 10mins could have been put to good use on something else
BritInVA is offline
