BritInVA Construction Thread - Page 45 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1321 of 1333 Old 01-19-2013, 02:17 PM - Thread Starter
BritInVA's Avatar
The top is a solid piece of Ply covered in the Dazian fabric. Everything else is just a frame covered in Dazian and fiction fitted.
Got your DM..... unfortunately I don't have any additional pics of the screen wall. It’s just a mix of 2x2 and and 2x3 that was ripped with angles on a table saw. Here are a few pictures of corners I just took.
Althou the speaker platforms appear to float they are pretty rigid.
Let me know if you need anything else.
Cheers,
Mark
BritInVA is offline
post #1322 of 1333 Old 01-22-2013, 08:06 AM
ArthurVandelay's Avatar
Yeah, yours is very close to what I'm doing so really appreciate it. I'm planning on putting the sub in the middle section though but I'll tinker and see. Since I have towers up front, doesn't seem like it would be a great idea to have them on a shelf like that although that would let me tuck the sub underneath. I did try it with the sub over there and the tower on top of it for a goof and the sub right on the wall was giving that wall a run for it's money, lol. Maybe won't be an issue once I have my paneling up but so far the bass seems to work best when my sub is just a little left of that front right tower.
ArthurVandelay is offline
post #1323 of 1333 Old 01-22-2013, 02:05 PM - Thread Starter
BritInVA's Avatar
If you are able to put sub under screen I'd do that, I didn't have enough height to do so.
JikkJack had same speakers/sub as me and LFE was better not being in the corner.
BritInVA is offline
post #1324 of 1333 Old 04-08-2013, 09:43 AM
Kurt Gross's Avatar
I am in the process of building a stage that is similar in design to yours. The stage has a 1/2 gap between the walls and I was also planning to have a separate sand filled "decoupled" area on each side of the stage for the speakers. The center compartments would be filled with insulation as you did. Now, prior to filling the stage and putting on the decking, I am having second thoughts. I am concerned with having the speaker bays "floating" in the stage. By cutting through the decking so that they are fully decoupled, I am wondering if they stay in place or eventually shift to touch the rest of the stage. I didn't want to haul 10 times as much sand down to fill the whole thing like Bacon Race did but now I don't know. I have tried to attach pictures so that you can see what I am talking about.
After doing it the way that you did it, have you had any regrets?
Kurt Gross is offline
post #1325 of 1333 Old 04-08-2013, 12:30 PM - Thread Starter
BritInVA's Avatar
Yes, I do regret doing it this way..... Not that its has shifted or think its impacted on sound but more I am limited in my sub placement to the corners which is not ideal.
If I was to do it again I would build a strip 18" to 24" wide across the wall, fill that with sand. Then build the rest with just insulation.
Good Luck.
Mark
BritInVA is offline
post #1326 of 1333 Old 04-08-2013, 02:18 PM
Kurt Gross's Avatar
When you say 18-24" strip, are you talking across the back wall and leave the front insulation? Did you ever move the speakers to the "insulation" area just to try it and notice a difference ? Do you think that the sand area needs to be decoupled from the insulation area or is just decoupling from the floor and walls enough?
post #1327 of 1333 Old 04-08-2013, 04:11 PM - Thread Starter
BritInVA's Avatar
Yes
Did you ever move the speakers to the "insulation" area just to try it and notice a difference?
No because my proscenium design did not allow for moving along wall bur another builder with same speakers/sub had better LFE with sub a 1/3 way along wall
I'm no expert but would think either will work providing decoupled from the walls.
BritInVA is offline
post #1328 of 1333 Old 04-08-2013, 04:13 PM - Thread Starter
BritInVA's Avatar
Yes
No because my proscenium design did not allow for moving along wall but another builder with same speakers/sub had better LFE with sub a 1/3 way along wall
BritInVA is offline
post #1329 of 1333 Old 01-15-2017, 11:22 AM - Thread Starter
BritInVA's Avatar
After all these years after changing a couple of bulbs my Insteon setup has decided not to work.
Zone 1: Sconces - 8 Button Keypad Dimmer - Still working
Zone 2: Rear Bar - SwitchLinc Dimmer - now just slowly comes on to full brightness then goes of
Zone 3: Front Bar - SwitchLinc Dimmer - Completely Not working
Zone 4: Rope Light - SwitchLinc Dimmer - Completely Not working
Zone 5: Stage Light - SwitchLinc Dimmer - Completely Not working
Zone 6: Star Ceiling - Toggle On/Off - Still Working
All I did was change bulbs in 2 & 3 then everything went pear shaped.
I have tries resetting to factory defaults and no joy, they are way out of warranty so that routes not an option........... and changing them for new Insteons will cost at lea $200.
So thought worth checking what others are doing.
Zone 1 is master switch in Theatre...... Zones 2 - 6 are wired to Equipment closet.
Thanks in advance for any suggestions.
BritInVA is offline
post #1330 of 1333 Old 01-15-2017, 01:03 PM
Quoted: 3257 Post(s)
Liked: 2743
I know that a short will kill an Insteon dimmer, Unfortunately I learned that the hard way. Not sure what you could have done to kill so many. Sorry for your loss.
texpilot likes this.
post #1331 of 1333 Old 01-15-2017, 02:25 PM - Thread Starter
BritInVA's Avatar
I've changed Zones 2 to 5 with basic on/off switches......... and all lights working so no short. Max load on each circuit is 150W and these Insteons all rated at 600W
Going to test each Insteon on a regular light see if can get any working - hopefully some will else means replacing up to 4 so $200
BritInVA is offline
post #1332 of 1333 Old 01-15-2017, 03:28 PM - Thread Starter
BritInVA's Avatar
Tested each on separate circuit and all bad
Will see what Smarthome says
BritInVA is offline
post #1333 of 1333 Old 02-03-2017, 08:35 AM - Thread Starter
BritInVA's Avatar
Great customer service from Smarthome..... 25% discount on replacements. Seeing as were 8yrs old was not expecting that!
BritInVA is offline
