Big Mouth In DC's beautiful black/grey theater - Page 55 - AVS Forum
 7Likes
Old 05-16-2014, 10:30 AM
Cleveland Plasma's Avatar
Quoted: 584 Post(s)
Liked: 740
Originally Posted by dc_pilgrim View Post
Big your a good artist and craftsman. Nice to see talent at work.
Ya just to draw that on a whim on a napkin, LOL
Cleveland Plasma is online now
Old 06-05-2014, 05:26 PM
ellisr63's Avatar
Quoted: 237 Post(s)
Liked: 257
I posted some of this information over on the CIH forum but I thought I would bring a summary of it into my thread so that I always know where it is.
When I rebuilt my screen wall I found a fabric at Hancock Fabrics that resembled the SMX ProPanels so I decided to use it for the panels surrounding the screen frame.
Here are two pictures comparing the Micro velvet to GOM FR701 (AKA the burlap)
First no flash:
With flash:
I don't have any test equipment to test for Acoustical transparency but I can do a blow through and shine through test. Here is the shine through results draping the fabric over my monitor:
GOM FR701:
Micro velvet:
I've been very happy using the Micro velvet. It is darker and a little "classier" than the burlap. It matches the screen frame and masking panels perfectly and makes the screen look almost like it is floating in mid air. With only the sub behind the fabric I can't detect any difference in the audio.
The fabric is this one.
http://www.hancockfabrics.com/Micro-...VVviewprod.htm
Hancock Fabric Item# 128157
Hancock will honor competitor coupons and I used a JoAnne's 50% off any one item coupon successfully at the store.
Comparison of SMX screen, Pro Panel, Frame, Micro Velvet, GOM Crystal blue. Left to right.
Notes: the micro velvet is at an angle to the camera. the Pro Panel is showing some reflection back from the screen. Under different lighting conditions the Pro panel actually looks darker than a swatch of the Micro velvet so I am now convinced that they are only nearly identical.
This picture really surprised me because I can not see a difference with the naked eye but when I look at the LCD viewfinder I see this difference:
Would you suggest using this for wrapping the screen frame too?
Denon 4520ci, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, MiniDSP 2x4s, (4) Klipsch HIPs,  PS3, XBox 360, (3) Intel NUCs, Redmere, Monster HTPS7000, 2 HTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diagonal) scope screen, Darbee Darcet, Yamaha P7000s, (2) Yamaha P2500s, & (3) Topping 25wpch T chip amps.
http://www.avsforum.com/forum/19-ded...t-theater.html
ellisr63 is online now
Old 06-05-2014, 05:31 PM
Quoted: 693 Post(s)
Liked: 786
the go to fabric for screen frames is Fidelio black velvet. That Hancock fabric was discontinued.
ellisr63 and dabsabre like this.
BIGmouthinDC is online now
Old 06-05-2014, 06:28 PM
ellisr63's Avatar
Quoted: 237 Post(s)
Liked: 257
Do you know any place that sells 6" wide strips... I would like to go with one strip per side. I need (2) 16', and (2) 7' long.
Old 06-05-2014, 08:30 PM
Quoted: 693 Post(s)
Liked: 786
Old 07-12-2014, 04:38 PM
ReTrO's Avatar
Great build, some good inspiration in there! I also don't have a practical back wall on which to mount surround back speakers so am going to rehouse a pair of Linn Trikan speakers Triad style to fit in ceiling. I'm just wondering about how to attach a grille at the moment.
I've already made some 4" deep housing to convert 3 other Trikans into slim hang on the wall speakers for the surround and centre channels.
Richard Wilson
Custom Installer
ReTrO is offline
Old 07-12-2014, 04:55 PM
Quoted: 693 Post(s)
Liked: 786
I just stapled fabric to the ceiling and covered the staples with molding.
ReTrO likes this.
Old 07-12-2014, 06:36 PM
TMcG's Avatar
Quoted: 455 Post(s)
Liked: 368
BIG - are you thinking of retrofitting ceiling speakers into your theater for the new object-based audio formats?
TMcG is offline
Old 07-12-2014, 10:24 PM
Quoted: 693 Post(s)
Liked: 786
no but I have a design modification of the Volt series that I need to get down on paper and post over in the DIY speaker section. I think it would solve many of the challenges of implementing Atmos.
Mfusick and willmo like this.
Old 07-13-2014, 07:25 AM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
Like button. I clicked it.
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
Old 07-14-2014, 06:17 AM
ClemsonJeeper's Avatar
Quoted: 128 Post(s)
Liked: 50
Would love to see that.
My Home Theater Build: The Vortex Theater Build
ClemsonJeeper is online now
Old 07-14-2014, 06:39 AM
Quoted: 693 Post(s)
Liked: 786
Very simple, add a layer of 5/8 DW with GG to the back and sides of the speaker.
Make a second front baffle with a one inch overhang (past the DW) all around. Attach with GG and screws
Cut hole in ceiling, Glue/screw/caulk the speaker with it's own "backer box" to the double layers of DW
Fashion a fabric frame that sits flush with the ceiling hiding the flange and speaker.
Result a backer box mounted speaker protruding no more than an inch from the ceiling. Use a coordinated fabric color.
Plan where these go in advance to make sure you have clearance between joists.
Old 07-14-2014, 07:47 AM
Quoted: 128 Post(s)
Liked: 50
Would these need to be aimed (tilted) a bit toward the LP? Or is downward firing going to be sufficient for Atmos (I know a lot of questions and not a lot of answers with respect to Atmos).
Old 07-14-2014, 08:59 AM
J_P_A's Avatar
Quoted: 295 Post(s)
Liked: 276
I know very little about this, but adding another layer to the speaker baffle may require a change to the crossover. If there is a demand for them, they may be able to build them with a larger baffle just for this type installation.
The Plains Theater Has Begun
J_P_A is offline
Old 07-14-2014, 04:28 PM
Quoted: 693 Post(s)
Liked: 786
Good point, there would be two factors at play. First pulling the woofer forward 3/4 inch would increase the internal box volume by about 5%. There are obvious ways around that by just substituting a bigger front baffle, or adding a block of wood inside the speaker. But maybe larger is a good thing? Second mounting the speaker in ceiling (or wall) will result in some speaker boundary issues than may need crossover modifications. Maybe the DIY SG design team can address that.
Old 07-15-2014, 05:20 PM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
5% change in box volume isn't much to sweat...
Old 07-15-2014, 06:27 PM
J_P_A's Avatar
Quoted: 295 Post(s)
Liked: 276
Speaker position in the baffle is what I was thinking of.
J_P_A is offline
Old 09-19-2014, 10:21 AM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
Are you mounting yours in a baffle wall ?
Old 10-28-2014, 09:49 AM
InfiniteReality's Avatar
I'll revive this from a slumber. That bar is awesome. What font did you use for the name?
InfiniteReality is offline
Old 10-28-2014, 11:53 AM
Quoted: 693 Post(s)
Liked: 786
Old 10-28-2014, 12:50 PM
Originally Posted by bigmouthindc View Post
anastasia
thank you!
Optoma HD141X Projector With 110” Elite Screen
Yamaha RX-V775WA A/V Receiver
4 Polk Audio TL250 Surround Speakers
2 Polk Audio RC85i In-Wall Speakers
1 Polk Audio TL2 Center & PSW505 Subwoofer
Berkline 12003 Leather/Power, Straight Row Of 3
Old 12-13-2014, 11:09 PM
seantos's Avatar
So is this not the same thing then? http://hancockfabrics.com/micro-blac...et-128157.html
I just did a search on hancock for "micro velvet" and that was what came up. I am looking at making a trip down to the US in the spring and I am looking into different materials to possibly pick up since the selection and prices in Canada (at least were I am) aren't that great. What is your current go to black material for acoustic panels or around a false wall for a screen these days if not the hancock micro velvet?
seantos is offline
Old 12-14-2014, 04:27 AM
Quoted: 693 Post(s)
Liked: 786
That could very well be OK, but I haven't seen it in person, I've had good luck with JoAnnes fabric Royalty 3 black velvet. always look for a coupon. I've used the black Fidelio $$. I would check out the Hancock in person but they've closed my local store.
