Wolf's Lair Home Theater-Construction/Pics - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 741 Old 04-13-2007, 10:45 AM - Thread Starter
mbgonzomd's Avatar
Liked: 29
...or how hard it is to hang drywall since I am only 2'8".
Gonzo
My Home Theater Odyssey
PSN: mule-tool
mbgonzomd is offline
post #182 of 741 Old 04-15-2007, 11:13 AM - Thread Starter
mbgonzomd's Avatar
Liked: 29
Been working on trim work and finishing the garage. Here are some pics.
I installed a louvered door for the closet that houses the upstairs HVAC unit. I am not a big fan of louvered doors, but I either had to use one or put a few vents between the closet and the outside world...that whole combustable air requirement thing.
Here is the almost finished garage.
Gonzo
PSN: mule-tool
post #183 of 741 Old 04-16-2007, 05:08 PM - Thread Starter
mbgonzomd's Avatar
Liked: 29
Green glue ordered. Let the fun begin!
Gonzo
PSN: mule-tool
post #184 of 741 Old 04-20-2007, 10:16 AM - Thread Starter
mbgonzomd's Avatar
Liked: 29
The eagle has landed...
Gonzo
PSN: mule-tool
post #185 of 741 Old 04-20-2007, 11:35 AM
Cathan's Avatar
It looks like you're closely following the approved Green Glue random application pattern. Keep up the good work!
Cathan is offline
post #186 of 741 Old 04-20-2007, 03:05 PM
BritInVA's Avatar
Does not look so random - looks like he traced from the example they have on their site
Cheers,
Mark
BritInVA is offline
post #187 of 741 Old 04-22-2007, 02:08 PM - Thread Starter
mbgonzomd's Avatar
Liked: 29
Gonzo
PSN: mule-tool
post #188 of 741 Old 04-25-2007, 04:05 PM - Thread Starter
mbgonzomd's Avatar
Liked: 29
Finally done with the second layer of drywall. Man, seemed like a lot more work that the first layer. I will spare you guys the pictures, as it looks striking similar to the first layer of drywall. Now, on to taping and mudding. The fun never ends
Gonzo
PSN: mule-tool
post #189 of 741 Old 04-25-2007, 11:36 PM
Zinema's Avatar
The most important part is that you have made a good progress - even if we would not see a difference with new pictures!
I believe you have to experience the amount of work involved yourself before you can honor the work of others doing almost the same.
Mike
Zinema construction thread
Wider is better - 2.40:1 CIH
Zinema is offline
post #190 of 741 Old 04-26-2007, 10:18 AM
Cathan's Avatar
LOL at the GG photo.
Good luck with the sanding!!
Cathan is offline
post #191 of 741 Old 04-28-2007, 10:13 AM - Thread Starter
mbgonzomd's Avatar
Liked: 29
I ordered my projector today. The panasonic ae1000u. They currently are running a $1000 rebate (must buy by the end of the month...or so they say). I bought it from projector people (a proud sponsor or AVS). It also came with a free oppo 1080p upconverting DVD player. I am not sure if the oppo is any good, but they are going for about $150 on ebay, so worse case scenario is I pawn it off. Ultimately I will go with HD-DVD or Blueray, but I am still sitting on the sidelines for this purchase. I want to get it mounted and see some images before I completely decide on my proscenium and stage set up.
As for the room. The second coat or mud is up. I am just going to caulk the corners of the ceiling/soffit, because crown molding will cover this.
screen wall:
back wall:
Gonzo
PSN: mule-tool
post #192 of 741 Old 04-28-2007, 10:53 AM
calv1n's Avatar
Its coming along great Gonzo I sure don't envy that sanding you have coming your way though.
Good luck.
calv1n is offline
post #193 of 741 Old 04-28-2007, 08:03 PM
dc_pilgrim's Avatar
We were painting in our basement today. We had the radio at the normal listening level in the HT. There is one door at the entrance to the basement - we couldn't here it in the kitchen directly above. My theater has RSIC + GG. There isn't much LFE on the soft rock station which is the only thing we could get. I cranked it later, and my wife said it was clearly audible, but not disturbing. The GG has only cured 4-5 days of the 30 - and there are a ton of flanking paths (including at that time an open bulkhead). I am encouraged. I think it will be worth the sore back.
Looking good, BTW
dc_pilgrim is offline
post #194 of 741 Old 05-02-2007, 03:09 PM - Thread Starter
mbgonzomd's Avatar
Liked: 29
Thanks Calv1n and Dave.
Received a little "daddy present" today. I put her up on the ceiling to help determine screen size and proscenium layout. It looks like I will be going with 105" diagonal 16:9 screen. Most likely DIY of some sort. What do you guys think of SMX screen material if being acoustically transparent doesn't matter? Does everyone like it because it is a good screen material AND acoustically transparent, or is it just a good screen material all around.
I am really excited now. This is going to be sweet when it is done. This is my first projector and I am now a big fan! The family sat there and watched a large portion of The Incredibles without any audio. My daughter was mesmerized. Here are a couple lame attempts at a screen shots, and I use the term screen very loosely. Apparently I have some sort of hand tremor that I was unaware of.
Gonzo
PSN: mule-tool
post #195 of 741 Old 05-02-2007, 03:19 PM
BritInVA's Avatar
Oh no....biggest mistake (Perl) in any HT build.......get that projector down. If you need a fix every now and then use it in the yard.
Looking Good.
Mark
BritInVA is offline
post #196 of 741 Old 05-02-2007, 03:19 PM
NeoOiler's Avatar
Are you putting crown molding under the soffet? I havent decided if I am going to do that or not yet. It looks like we are pretty much at the same stage so I will keep an eye on your thread with great interest.
Ryan
IM FINALLY FINISHED...(WELL ALMOST)
THE PITT CONSTRUCTION THREAD
NeoOiler is offline
post #197 of 741 Old 05-03-2007, 06:39 AM - Thread Starter
mbgonzomd's Avatar
Liked: 29
Looking Good.
Mark
Already down, my man. Must finish theater, must finish theater, must finish theater.
Gonzo
PSN: mule-tool
post #198 of 741 Old 05-03-2007, 06:40 AM - Thread Starter
mbgonzomd's Avatar
Liked: 29
Ryan
Yes, I am planning on crown at the ceiling/soffit border and the wall/soffit border. Your theater is looking really good also.
Gonzo
PSN: mule-tool
post #199 of 741 Old 05-03-2007, 07:16 AM
Zinema's Avatar
Well done!
I kept it in place and thought I will be able to handle the dark force.....
In fact I am almost able to keep my fingers of it, if there wouldn't be my wife asking me 3 to 4 times a week to watch a movie or TV!
Finish the room first!
Mike
Zinema is offline
post #200 of 741 Old 05-05-2007, 05:20 PM - Thread Starter
mbgonzomd's Avatar
Liked: 29
Sanding is done!!! Primer is up!!! Ceiling is painted!!!
(2 coats of primer on the front wall. Just in case I want to project something on there )
Ceiling was done in a brushed suede finish. Pictures don't capture the color or texture very well.
Should look pretty cool when the crown molding and blue rope light are installed.
Gonzo
PSN: mule-tool
post #201 of 741 Old 05-06-2007, 04:41 PM - Thread Starter
mbgonzomd's Avatar
Liked: 29
More accomplished today. First a humorous story. I went to Lowes and picked up 4 sheets of plywood and 400 pounds of play sand. I was driving my wifes Honda Pilot, which I have learned that I can pack pretty full of stuff. Because of the plywood, the tail gate had to be bunjeed (sp?) shut. On the way home I came to an intersection where about 3 cops were directing traffic. Apparently there was a bike race that was coming through the intersection. So, I sat there and waited patiently until the cop waved me to move on. He is doing this in between a break in the bikers. There is only a small window before the next set of bikers get to the intersection. I press the gas a little, then a little more. The cop looks at me as if to say, "buddy, you better hurry or the Tour de Small Town North Carolina is going to hit your side panel." So, I give it some more gas and...crash. Yep, you guessed it. 400 pounds of play sand and a sheet of plywood are laying in the intersection. It was amazing the sand was sitting nicely stacked on the plywood in the middle of the road, no damage done. One of the cops helped me load it all back. I felt like an idiot, but what else is new
The sand:
The middle portion of the stage:
Don't even think about it!
More green glue:
Right side partially finished:
Gonzo
PSN: mule-tool
post #202 of 741 Old 05-09-2007, 03:10 PM - Thread Starter
mbgonzomd's Avatar
Liked: 29
The stage is finished. I am in the process of adding a 2 pieces of quarter round to create a lip for the carpet to wrap around. Why is the quarter round stained ebony you might ask. Well I actually bought it to be used on the baseboards elsewhere within the basement. I stained it and added poly. Then I started to put it down and realized quarter round is not what I wanted. I wanted "shoe molding" which is a little smaller and thinner. Well, at least I found a use for the nicely stained quarter round
I have not decided as to whether to work on the riser (for the second time) or the proscenium next. It will probably be the riser.
Gonzo
PSN: mule-tool
post #203 of 741 Old 05-10-2007, 09:57 AM
Chiahead's Avatar
the stain is like a step saftey feature. When steps are hard to see due to materials being the same on top and bottom, people add a colored edge to make the step edge stand out. Looks like OSHA would be proud.
Michael
PSN: Chiahead
Chiahead's Man Cave - Indexed
Loganed on 8/29/2008
Chiahead is offline
post #204 of 741 Old 05-10-2007, 10:13 AM
dc_pilgrim's Avatar
That's great. I am thinking the stage, briefly will be my daughter's first sandbox. Then sealed up.
post #205 of 741 Old 05-13-2007, 05:27 PM - Thread Starter
mbgonzomd's Avatar
Liked: 29
I was talking to my mother today and she said I needed to update my thread. So, since its mothers day, this one is for you mom:
A partially completed riser!!!
I am confident that I am still your favorite child after this generous gesture
Gonzo
PSN: mule-tool
post #206 of 741 Old 05-14-2007, 11:04 AM
ggonzalez's Avatar
Considering that I took mom out to brunch yesterday, I doubt it
PSN/XBL: GonzoDad
ggonzalez is offline
post #207 of 741 Old 05-14-2007, 11:18 AM
Cathan's Avatar
Oh SNAP!!
Cathan is offline
post #208 of 741 Old 05-14-2007, 12:03 PM
calv1n's Avatar
Oh damn, Now gonzo just turned it into the family feud
Pics look great (I'm sure your mom agrees )
calv1n is offline
post #209 of 741 Old 05-14-2007, 12:43 PM
BritInVA's Avatar
Next year you will have to do a custom slide show of all your mums favorite moments with her favorite son.....you can cut out any mention of other siblings
BritInVA is offline
post #210 of 741 Old 05-15-2007, 05:07 AM - Thread Starter
mbgonzomd's Avatar
Liked: 29
LOL
Touche, brother.
Gonzo
PSN: mule-tool
