The Zinema construction has started! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 387 Old 01-07-2007, 06:11 PM
mikeryan's Avatar
Originally Posted by Zinema View Post
Steve, at least someone is missing me here....
Mike, I bet there are many 10's of lurkers, like me, looking forward to your updates, for each guy, like Steve, who has something to contribute to the discussion. Just so you know, yours is one of my favorite threads to learn from and get ideas for my theater. As a matter of fact, I hope you'll take it as the sincerest of flattery if I copy your column design. Great stuff!
Best regards,
Mike
Mike
my construction thread (Coming Soon...)
mikeryan is offline
post #92 of 387 Old 01-08-2007, 03:23 AM - Thread Starter
Zinema's Avatar
Best regards,
Mike
Thanks Mike, feel free to use the column design - that's exactly the reason why we all spend hours of reading and writing in this forum here - share ideas!!
(If you need more details from the column design/building let me know)
Just a little update on the construction - finally I managed to cut all 7 rings for the spot light holes in the soffit. They are 1cm thick and will be used to mount the fabric around the openings. The 1cm thick strip for mounting on the wall side is still missing in this picture....
I did also start to work on the ceiling - using my CAD model of the room I found the areas of the 1st reflection from the LCR speaker, did this for the front and for the rear row. Just to make sure to cover enough area I made the zones 40cm (~16") wide at the full ceiling width. For the rest I mounted 1.8cm (~3/4") thick boards (of course with foam strips) as a framing to the ceiling.
Then I will mount 8mm (~1/4") thick particle boards to the framing to cover the whole front part of the room excluding the reflection areas and the rear part. There will be no insulation between the boards and the ceiling wall - air gap of 1.8cm!
Later I will add 3cm (~1") thick "Akustikfilz" (fibreglass mat) in the reflection zones to absorb the mids/highs there. The rest of the construction should reflect most of the mids/highs but absorb some of the low frequencies (around 30% up to ~300Hz).
I did not build this construction in the rear part of the room since I will loose to much room height (even it is just a few cm) where the riser for the second row is located. The whole ceiling will then be covered with 9 fabric covered frames - 3 in the rear part directly mounted on the ceiling and 6 in the front part.
Mike
Zinema construction thread
Wider is better - 2.40:1 CIH
Zinema is offline
post #93 of 387 Old 01-08-2007, 06:13 AM
SVonhof's Avatar
Quoted: 14 Post(s)
Mike, it is interesting to watch how you have to do things considering that your whole room is a concrete box. Good for sound insulation, bad for the hard surfaces. Obviously you are doing your best to take care of the hard surfaces though.
Keep up the good work!
SVonhof is offline
post #94 of 387 Old 01-08-2007, 07:02 AM
LewisCobb's Avatar
Good work Mike - There's people all over the globe keeping an eye on your progress I am sure....even one fellow from a small sparcely populated corner of Canada....
I have a question on the Cara program that you have been using to model the acoustics in your room. Are you able to modify the material/adsorption coefficients that come with the program or do you have to stay with what is supplied? Also - in the case that your speakers are not in the database, is the program still a useful tool to have ? I'm looking at getting this program for my HT planning in the next few weeks and thought I'd ask.
Best Regards,
Lewis
LewisCobb is offline
post #95 of 387 Old 01-08-2007, 07:15 AM - Thread Starter
Zinema's Avatar
Lewis
Thanks Lewis, I guess most of us (including myself) are more reading than writing...
Cara comes with a database of common materials - but you can add new ones and you can also modify existing ones. You do this by defining the absorption curve in very fine steps if you want. Same goes for the speakers - you have a selection of predefined speakers but you can also create new speakers by using the built in speaker editor. Of course when you add your own speaker the results are only as good as your provided information. The predefined speakers use measured data, the new ones will "only" use calculated parameter.
Hope that helped...
Mike
Zinema is offline
post #96 of 387 Old 01-15-2007, 05:30 AM - Thread Starter
Zinema's Avatar
Meanwhile I received my amp for the subwoofer - I didn't want put the amplifier module into the subwoofer case so I went the route of an external amp, running with speaker cables (bi-wiring) to the sub.
Here is a picture of the amp and the technical specs:
This together with my Yamaha should give me enough room to adjust the bass management!
I have finished also the plans for the TL. It will be made from 16mm MDF which is already ordered - hope to have time to build it this week...
Since it is going to be hidden behind the rear wall framing I will keep it plain MDF for now - it's going to be an ugly large box but should sound sweet!
continued in next post....
Mike
Zinema is offline
post #97 of 387 Old 01-15-2007, 05:33 AM - Thread Starter
Zinema's Avatar
...more pics
Making also a good progress on the room - basic framing is almost done and the carpet should go in this week....I am so excited!
Pictures of the room will follow later this week.
Mike
Zinema is offline
post #98 of 387 Old 01-15-2007, 06:52 AM
LewisCobb's Avatar
Looking good Mike - you're really making productive use of SketchUp - I find that the use of SketchUp to conceptualize things really helps make the design and decision process go much faster. My wife however is convinced that I have lost my mind and I will never really "build" anything - just draw it on the computer.....
post #99 of 387 Old 01-15-2007, 07:42 AM
swithey's Avatar
That sub box is impressive. Is this similar in design to the "innards" of the Danley DTS-20?
swithey is offline
post #100 of 387 Old 01-15-2007, 07:53 AM - Thread Starter
Zinema's Avatar
Steve,
I do not know the Danley sub in detail - but I guess it has also 2 drivers. So looking at this picture lets me believe it is also a build as a dual Transmission Line...
Do you have specs of the Danley?
Mike
Zinema is offline
post #101 of 387 Old 01-15-2007, 08:38 AM
swithey's Avatar
Nope -- no details, sorry.. but I think it only has a single 12" woof and can do 20Hz at 124db
I am not familiar with your sub design either but am very curious about how it sounds compared to a normal box sealed/ported sub. I've been very happy with my IB setup but it does transmit bass into the house a bit more. My wife reminded me of that yesterday when I was demoing some material
swithey is offline
post #102 of 387 Old 01-15-2007, 08:52 AM - Thread Starter
Zinema's Avatar
Found the specs of the DTS-20 on the net...very nice!
It uses a single 12" driver - so it is has a single TL.
The dimensions are similar to my design but I am using one 8" and one 10" long excursion driver together in one case (each TL tuned for the specific driver) which should move even more air as a single 12" driver...
Need to build this monster this week, get an SPL meter and run some tests - just waiting for the MDF to be ready to pickup!!!
Mike
Zinema is offline
post #103 of 387 Old 01-15-2007, 10:28 AM - Thread Starter
Zinema's Avatar
UPS just delivered my ordered screen fabric!
It's a 1.0 gain 3 layer screen material, white front layer, a very thin fibre glass middle support layer and a black back layer.
It's called Cinetec 1.30 - manufactured in Germany.
Size of fabric - 300 cm x 150 cm
Outside frame dimensions - 296 cm x 128,5 cm
Frame 8 cm wide covered with deep black velvet
Viewing size with frame attached - 270 cm x 112,5 cm - AR 2.40:1
This is going to be a very busy week!
Mike
Zinema is offline
post #104 of 387 Old 01-22-2007, 01:44 PM - Thread Starter
Zinema's Avatar
Yesterday I finished the case for my TL-Sub - it's massive!
Here are some pictures of the construction - first a look at the MDF - 4.5m² for a single sub..
I started with the rear, bottom and left side. All glued and screwed together.
Then I built the inner part including the support pieces to give the whole construction enough stiffness.
In the next step I combined the two parts - looking like something interesting already.
Here a closed up of the 180° turn of the line for the 10 driver. The little box on the bottom left side is unused, there I will place the connection terminal.
And here I present the final housing - next I will place this monster on the rear wall behind the framing, add the connection terminal and drivers. I guess I will need a strong helping hand to move this thing - it has around 90kg, 215cm wide, 47cm high and 26cm deep.
I am not going to make it look nice since it is going to be hidden behind the rear wall framing anyway - the only target I have is to make it sound great!!
Next: Finish rear wall framing and add the wooden trim on the riser edges.
Mike
Zinema is offline
post #105 of 387 Old 01-22-2007, 08:52 PM
Craigo87's Avatar
Mike,
I just found your thread today and am fascinated with the work you've done. Especially interested in your subwoofer design. It got me thinking, why not turn a riser platform into a subwoofer? Couldn't a person use the large volume inside a riser for a subwoofer? Have the speakers mounted under the seats so that they're conceiled and even put some grates over them to protect them. Do you think it could be done with some success? What would be the down side?
On a related topic. Where did you come up with the design for your subwoofer? It looks pretty cool.
thanks,
Craigo
Remember... no matter where you go, there you are.
Craigo87 is offline
post #106 of 387 Old 01-23-2007, 04:19 PM - Thread Starter
Zinema's Avatar
Craigo,
thank you - in fact when I started with my cinema design I had also the idea to integrate the subwoofer in the riser....
I wanted to build the Transmission Line inside the riser (like I did in my case now) but decided not to do it. Don't ask me for the exact reason for this discission, but I guess I did not feel too good to have the sub combined with the riser platform. It is more flexible like I have it now and if I have to change the subwoofer case for some reason after testing I do not have to rip apart the whole riser...
Well to build a subwoofer as an TL is not my idea....there are also some different ways to design a Transmission Line. The company producing the drivers provides also plans for building speakers - from there I had the original idea. But I had to redesign the plans since I used different drivers and adapted the sub for my room - so there is not much left from the original plan.
I hope to find time this week to continue working in the HT, I'm really wanting to test drive this baby!
Mike
Zinema is offline
post #107 of 387 Old 01-26-2007, 02:05 PM - Thread Starter
Zinema's Avatar
Just finished the real wall framing after placing the sub along the wall.
I put the sub on a 1cm thick hard foam mat (used normally for camping beneath the sleeping bag) to avoid vibrations and to decouple it a little bit from the riser.
The sub case just fits with a 1cm gap in the front and in the back behind the rear wall framing. To avoid that the case is moving and touching the frame or the wall a placed also small strips of the foam to keep it in place.
Here a view of the left side where the 2 TL openings are located
Next: Tomorrow I will start with the wooden trim on the riser edges.
Mike
Zinema is offline
post #108 of 387 Old 01-26-2007, 02:37 PM
swithey's Avatar
The people in the back are really going to "feel" that bass I like it
swithey is offline
post #109 of 387 Old 01-26-2007, 05:53 PM
SVonhof's Avatar
Quoted: 14 Post(s)
Keep going Mike. Interesting stuff here!
SVonhof is offline
post #110 of 387 Old 01-27-2007, 12:28 PM - Thread Starter
Zinema's Avatar
Today I started on the wooden trim on the edges of the riser platform. Cut all pieces and glued them on the riser using a special extra strong glue. Now I will let it harden and tomorrow I'm going to round the outside corners, sand the joints and fill the gaps with liquid wood. Then I will sand it again completely to get a very smooth surface ready to paint.
Close up of the right step. After the wood is painted I will install carpet on the top of the riser, on the 2 steps and on all vertical surfaces. The top surface of the wooden trim and the carpet will be on the same level - so the wood should nicely outline the carpet once finished.
Mike
Zinema is offline
post #111 of 387 Old 01-27-2007, 05:06 PM
mbgonzomd's Avatar
Liked: 29
Mike,
Is the trim on the riser sitting on top of the OSB (I think that is OSB ) or did you cut the OSB short to allow for the trim to butt up against it? I am planning on doing the same thing, but will be staining the edge instead of painting. Thanks.
Edit: Never mind, I can tell in the previous pictures how you did it. 2 layers, one cut shorter to leave a groove to put the trim, right?
Gonzo
My Home Theater Odyssey
PSN: mule-tool
mbgonzomd is offline
post #112 of 387 Old 01-27-2007, 06:37 PM - Thread Starter
Zinema's Avatar
Correct!
I will use 2 layers of a wax based varnish which will give a semi gloss finish when polished - so there will be some structure of the wood visible after painting.
Mike
Zinema is offline
post #113 of 387 Old 01-27-2007, 09:15 PM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Mike
I must say your wood working skillz are impressive
I just registered to AVS and from the few hours of lurking I have found a ton of useful info for my HT room.
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #114 of 387 Old 01-28-2007, 12:31 AM - Thread Starter
Zinema's Avatar
Thanks W00lly,
welcome to the forum - the world of Thousand and One Ideas
Mike
Zinema is offline
post #115 of 387 Old 01-28-2007, 11:56 PM - Thread Starter
Zinema's Avatar
Yesterday was a very important day for me - psychologically wise...
Carried the four columns in the garage and sanded them 2 times - didn't want to have the dusty mess in the HT!
Sanded also the wooden trim on the riser.
BUT the most important tasks yesterday: Removed all tools from the HT room and cleaned everything with the vac - took me an hour to do it right. Good that we have a central vac installed in the house (this is not very common in Europe btw) so all the dust was really leaving the room/house!
Today I'm going to close all the small gaps of the columns and riser border with liquid wood and sand it again once hardened.
Next steps: Paint columns and riser edge - then INSTALL THE CARPET!!
Mike
Zinema is offline
post #116 of 387 Old 01-29-2007, 05:52 AM
BritInVA's Avatar
Just don't put the PJ up too soon - that seems to be the one thing that slows progress.
Look forward to seeing the progress pics.
Cheers,
Mark
BritInVA is offline
post #117 of 387 Old 01-29-2007, 06:02 AM - Thread Starter
Zinema's Avatar
I know that and I believe you are absolutely right....but I fear I can not resist!!
Mike
Zinema is offline
post #118 of 387 Old 01-29-2007, 06:14 AM
jikkjack's Avatar
WOW. Mike - I just read through your thread and I am definitely impressed. You are doing a fantastic job. Everything looks great, house, home theater, attention to detail. Will be following along.
jikkjack is offline
post #119 of 387 Old 01-29-2007, 06:19 AM - Thread Starter
Zinema's Avatar
Thanks Jason - we are all a big happy family here!
Mike
Zinema is offline
post #120 of 387 Old 01-30-2007, 02:42 PM - Thread Starter
Zinema's Avatar
Today I finished filling the gaps with liquid wood and sanding the columns and the riser trim. Of course I had to fill the bigger gaps with several layers of liquid wood and sand it also several times - so it took longer than expected, but is done now!
All my four columns ready to paint:
And here the detail of the right step of the riser, also ready to paint:
Next: Apply first layer of varnish
Mike
Zinema is offline
