Big Red theater build 21' x 27' - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #91 of 550 Old 08-01-2007, 07:54 AM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
after a lot of listening tests i have decided what to do with speakers. for the fronts i will be doing a DIY design but using all active crossovers. i am building a variant of this design
http://htguide.com/forum/showpost.ph...&postcount=537
i am using the SEAS tweeter as it has a little more "air" to it. i am also building them in 2 pieces - one for the mtm and one for the 2 10". that is because for the center channel i will sit them side by side over the sub and for the right and left they will be stacked on the floor. The beauty of diy in this scenario is that i don't care what they look like. ugly old mdf is actually the best thing to build speakers out of but we make it harder by trying to cover that with nice veneers and such. since mine are behind the screen they will be flat black and UGLY.
for the surrounds i am using 2 axiom qs8 for each side
and 2 axiom m22s in the rear
greg
Big Red Cinema Build
indygreg is offline
post #92 of 550 Old 08-01-2007, 09:21 AM
swithey's Avatar
greg
Greg,
Do you plan to put those m22s in a rear wall cavity? If so, it would not be good since they are rear ported. The port will need a min of 3-4" behind it to breath.
I had the same issue and decided to make my own sealed 2-ways with the SEAS tweet and a 7" Dayton woof. MDF (and ugly) but perform extremely well. You can see more here. They can be built for about 1/2 the price of the m22s. I figured since you are building your fronts a few more would not add too much work fo you
NOTE: I actually used these as my front speakers for about a month while I built the front towers. They did VERY well.
swithey is offline
post #93 of 550 Old 08-01-2007, 10:00 AM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
steve - i really like your mains. the curved sides are really beautiful. i really want to do a curved piece like that someday. i watched you building them and that gave me the confidence to build mine.
the m22's have about 2" behind them. that wall is insanely thick plus 1" of sheetrock. with a double driver m22 i seem to be getting all that i need from it. sometimes i wonder if we overthink the surround channels. i had a set of very elaborate designs for building all the surrounds then decided to just spend a few extra dollars and buy the axioms. i have more than enough to do.
g
indygreg is offline
post #94 of 550 Old 08-01-2007, 10:09 AM
swithey's Avatar
g
If they are performing well then you hit a home run Buying is definitely a lot easier than building!
And thanks for the kind words on the speaker build -- glad I could push you in that direction It is really easy to do but does take a bit more time. I'm anxious to hear about your active XOs.
swithey is offline
post #95 of 550 Old 08-01-2007, 11:39 AM
ebr
ebr's Avatar
For rear surrounds you may never know the difference, but I would think having a rear-ported speaker in a cavity like that would tend to sound quite "boxy". Also, I don't remember if you are working with Bryan or anyone but you might consult someone on the potential boundary effect that will be created by having the front baffles basically even with the rear wall surface.
ebr is offline
post #96 of 550 Old 08-01-2007, 10:40 PM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
ebr - yeah i wondered about that but i fired them up in 2 channel mode and didn't notice anything obnoxious. it wouldn't do for reference listening or anything but it makes a serious rear channel.
thanks,
greg
indygreg is offline
post #97 of 550 Old 08-01-2007, 10:50 PM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
i got my LCR loaded up and running without the woofers. just the 7" and 1" drivers and i set the crossovers to run the 7" all the way down. it definitely needs the double 10" for my taste. vocals were thin and it seemed really obvious to me that there was a hole between the 7" midwoofs and the 15" ubbersub. i put the boxes for the 3 double 10's together today and will try to load them up tomorrow. i have one of the two ubbersubs running and i have to say it moves some air. the other one is on hold because i found i had a defect in one of my tc2000 drivers. i am happy to say that i called up tcsounds and they immediately offered to ship me a new driver. i would say they are first rate and kyle in tech support was very helpful. as soon as i get the fourth driver i will fire up the other sub.
btw, a trick question - what is the best interconnect you can use for the speaker wires where they go into the speakers?
this is a block diagram of the audio components.
greg
indygreg is offline
post #98 of 550 Old 08-02-2007, 08:34 AM
ebr
ebr's Avatar
A block diagram!? Oh, my. Your engineering background is showing...
I'll take a stab at your "trick" question.
Answer: None. Run the speaker wire straight through the cabinet .
But, assuming that's not really practical, I guess 5-way binding posts are probably the way to go. BTW - why are they called 5-way? Basically, it looks to me like there are two ways to connect to them (screwing in the wires or using banannas)...
ebr is offline
post #99 of 550 Old 08-02-2007, 08:57 AM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
ebr!!!
10 awg wire out of the wall and into the sub. i am not moving that sub without a crane since i built it in place.
indygreg is offline
post #100 of 550 Old 08-02-2007, 05:47 PM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
i went with active crossovers on my diy speakers for several reasons but one was that i like the control if gives. i have a friend with EASE who can bring his computer and reference microphone over and we can dial in the crossover, eq and any time delays that might be needed (i doubt). in case you have not worked with one a pa processor is a pretty handy piece of kit. in the olden days (when i used to own sound systems) you carried a house EQ, a few parametric EQ's for trouble spots, an electronic crossover for each channel and sometimes we inserted a compressor or time delay into the mains. now you get one giz called a pa processor which takes in several channels of sound and does an A-D conversion then does all the things i descrived above digitally. you can soft configure the components you want on each channel. i have used dbx driverack processors in the past but for the theater i decided to try these behringer units. they are cheap (around $300) and they have a nice RS232 interface that lets you configure them from your pc. you can even daisy chain them together so they only take on rs232 port. so far i am pretty happy with them. i should say that behringer is kind of a controversial company as they are known for taking the designs of popular products to china and having knock-offs built for less.
here is what the configuration utility looks like to set up the audio path. here i have the first input (red) routed to 3 outputs after passing through crossover, eq, etc. that is my center channel. i have the second input (yellow) going to the 4th output after passing through processing. this is my sub. here i will set the limiter at just below clipping so that if i ever do drive my subs beyond their limits the limiter will not allow the amplifier to clip.
this is another screenshot which shows the crossover setup.
http://www.behringer.com/DCX2496/index.cfm?lang=eng
greg
indygreg is offline
post #101 of 550 Old 08-04-2007, 01:53 AM
Spizz's Avatar
Quoted: 166 Post(s)
Liked: 71
Greg- It is coming together. I love your projector/Equipement room. Do you have an actual picture of how this turned out-
I liked the idea there.
Spizz is online now
post #102 of 550 Old 08-04-2007, 02:13 PM
ebr
ebr's Avatar
Yeah, and the multiple copies of the original van Gogh really make the space .
ebr is offline
post #103 of 550 Old 08-04-2007, 04:25 PM
Tedd's Avatar
Quoted: 922 Post(s)
Liked: 339
Re: Five way binding posts
Spade Lug
Round Lug
Banana Jack
Pin style
bare wire
bare wire
Tedd is offline
post #104 of 550 Old 08-04-2007, 09:40 PM
Spizz's Avatar
Quoted: 166 Post(s)
Liked: 71
I would like something similar for my cinema with backlit movie posters.
Spizz is online now
post #105 of 550 Old 08-04-2007, 10:25 PM
Jesse S's Avatar
You can plug the ports on the rear M22's if they sound "bad". They'll lose some extension but who cares, they are surrounds running small...right?
Jesse S is offline
post #106 of 550 Old 08-08-2007, 09:19 AM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
hi spizz. the lobby is not done but here is the current state. i will do the colomns around the door at the same time i do the rest of the columns. the movie one sheet frames are working but not fully loaded yet. my dad got these out of a theater that closed down and i had the contractor frame them into the wall. the bar/candy case is on the to do list but i have not had much time for building things lately.
greg
indygreg is offline
post #107 of 550 Old 08-08-2007, 11:50 PM
Spizz's Avatar
Quoted: 166 Post(s)
Liked: 71
Greg that looks fantastic. Would love to encorporate that into my entrance.
Spizz is online now
post #108 of 550 Old 08-08-2007, 11:50 PM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
i have the cherry soffits in and ready to be stained. the white part of the ceiling will be a starfield. i know i will anger the soffit gods by not making mine out of fabric and treating them but ...
i really laugh at the fact that every incomplete theater in this forum has materials and tools spread around but in the middle of the room is always "the chair". like all the others, mine has had a definite productivity impact.
greg
indygreg is offline
post #109 of 550 Old 08-09-2007, 07:42 AM
ebr
ebr's Avatar
Ooh, those soffits are gonna be puurty.... .
Nice work.
ebr is offline
post #110 of 550 Old 08-09-2007, 11:49 AM
accts4mjs's Avatar
Greg,
Wow! I just read your thread start to finish and I must say I absolutely love it I think my favorite part is the lobby. I would love a lobby to my theater but it's upstairs and I think I'm pressing my luck already by planning for a "Theatre" sign above the door and a faux ticket booth on the door outside the room. Ah well, nice to know someone else can build your dream
Your hard work is paying off and I can't wait to see the finished results. Well done!
Mike
accts4mjs is offline
post #111 of 550 Old 08-09-2007, 05:41 PM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
thanks mike. ibtw, i LOVE your sconces.
greg
indygreg is offline
post #112 of 550 Old 08-09-2007, 05:47 PM
Cathan's Avatar
greg
You know when you're on AVS when men can talk freely about the feng shui of lighting fixtures and not have it seem odd.
And yes I agree that the soffit will look absolutely amazing when done and Mike does have good taste in sconces.
Cathan is offline
post #113 of 550 Old 08-09-2007, 09:06 PM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Is that a beer fridge covered up by a tarp
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #114 of 550 Old 08-09-2007, 10:21 PM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
good eyes w00lly. we will refer to that as the subtemperate refreshment dispenser. it goes in the little room right behind the theater next to the microwave.
greg
indygreg is offline
post #115 of 550 Old 08-09-2007, 11:30 PM
accts4mjs's Avatar
thanks mike. btw, i LOVE your sconces.
Originally Posted by cathan View Post
You know you're on AVS when men can talk freely about the feng shui of lighting fixtures and not have it seem odd.
LOL! This is what I love about the forum I showed this conversation to my wife and she chuckled, shook her head and said, "You guys are funny." (Then went back to her book.) Well, I thought it was pretty funny
Mike
post #116 of 550 Old 08-09-2007, 11:38 PM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
yeah my wife thinks i'm having an affair with the UPS delivery lady since she shows up every day.
g
indygreg is offline
post #117 of 550 Old 08-10-2007, 06:17 AM
swithey's Avatar
g
Let's hope she doesn't look like THIS, or I'd be a little worried
swithey is offline
post #118 of 550 Old 08-10-2007, 06:37 AM
mbgonzomd's Avatar
It seems Fedex delivers most I my stuff. I am now going to start requesting UPS
Soffits look fantastic...and I am glad the that is not the final location for the beverage dispenser. That would really mess up the feng shui.
Gonzo
My Home Theater Odyssey
PSN: mule-tool
mbgonzomd is offline
post #119 of 550 Old 08-10-2007, 11:24 AM
Dean Roddey's Avatar
Quoted: 388 Post(s)
Liked: 293
Never wouldn't thunk I'd hear one guy say that to another guy. Not that there's anything wrong with that! :-)
Dean Roddey
Chairman/CTO, Charmed Quark Systems, Ltd
www.charmedquark.com
Dean Roddey is offline
post #120 of 550 Old 08-11-2007, 01:33 PM - Thread Starter
indygreg's Avatar
Quoted: 112 Post(s)
Liked: 87
i now have sound coming out of all channels. i am still missing a sub from tc sounds to replace the defective one i got but i have one channel of the subwoofer up running 2 of the 15" drivers. the front mains are triamped and i dialed in the levels by ear (which means they are not even close ) coincidently WOTW was on directv last night so i recorded it. 20 min ago i gave it the first test. the dog pee'd. my wife almost pee'd. windows upstairs were rattling. the granite island was moving and pans were shaking in the cabinets. the low freq went through 2 sheets of drywall like they were not there. my wife went outside because she was concerned for the house (she is a little dramatic but i have to say it was pretty unreal). i ran pro sound for many years and have stood in front of 100K watt PA's that really kicked hard but i have never felt subsonic energy like that before.
all in all the test was a huge success. i can't wait to get the other sub running.
indygreg is offline
