Show us your screen walls - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 172Likes
post #691 of 1000 Old 01-31-2012, 03:58 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
Originally Posted by Stew4msu View Post
Looks level.
Originally Posted by GRBoomer View Post
Hanging the cables in a bag helps keep the bears away too.
I laughed out loud
Larry M is offline
post #692 of 1000 Old 01-31-2012, 11:37 AM
GoCaboNow's Avatar
Quoted: 893 Post(s)
Liked: 789
I had to redo my screen wall to fit some new speakers in -
bpassman likes this.
My Dedicated Home Theater Room
GoCaboNow is offline
post #693 of 1000 Old 02-04-2012, 04:35 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
Originally Posted by YW84U View Post
Okay, I'll play too - ~138" 16x9 DIY drywall screen with Behr SS..... room is 12.5x19, ceiling at 90 inches
stage is 2x6, with roofing felt between 3/4 and 1/2 in ply held together with 86lbs of screws. Sand in the decoupled speaker ends, fibreglass in the middle sections. DIY bass traps in both colums, as well as absorption to deaden the front wall as best I could.
Here is a pic I took as the screen system went in.
Originally Posted by snowkarver View Post
84" (96" diagonal) Da-Lite HCCV in a DIY frame:
Originally Posted by jamis View Post
Just finished ours this weekend. Too bad we don't have a projector for a few weeks.
It's a 129" viewable 2.37:1 SMX screen with a GOM wrapped panel below.
How does one achieve this type of lighting effect? I have a 120" wide screen and was planning 4 across but I don't know exactly which fixtures and bulbs to get
Larry M is offline
post #694 of 1000 Old 02-04-2012, 06:05 PM
GRBoomer's Avatar
The best choice is going to be a Low Voltage halogen light using an MR16 bulb. The MR16 series of bulbs have a wide range of beam angles and the reflectors create a very crisp edge which creates the scalloping effect you see on the screens.
Here are some Photometric calculations.
You should ask this in its own new thread so as not to stray this thread off topic.
GRBoomer is offline
post #695 of 1000 Old 02-11-2012, 06:15 PM
Sands_at_Pier147's Avatar
It appears my hypocrisy knows no bounds.
Brian
The Cinema Rouge Home Theater
Sands_at_Pier147 is offline
post #696 of 1000 Old 02-12-2012, 06:37 AM
Stew4msu's Avatar
Nice, and a Tombstone signature quote too.
Stew4msu is offline
post #697 of 1000 Old 02-12-2012, 07:10 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 192
Originally Posted by Sands_at_Pier147 View Post
nice i always wondered what soffits would look like in my room with the attic type ceiling like mine. They look real nice.
Good Job!
NicksHitachi is offline
post #698 of 1000 Old 02-12-2012, 09:47 AM
ADDUpstate's Avatar
Well, I *think* I'm about done upgrading. Can't go any bigger with the screen unless I move the walls. First was my original 106". Recently moved up to 137" AT EN4K screen. Third picture is off my phone, and before I raised the cross member to hold the screen.
ADDUpstate is offline
post #699 of 1000 Old 02-12-2012, 07:20 PM
SVonhof's Avatar
Quoted: 14 Post(s)
Originally Posted by ADDUpstate View Post
What kind of speakers are those? Home-made?
SVonhof is offline
post #700 of 1000 Old 02-13-2012, 05:34 AM
dc_pilgrim's Avatar
There is always masking. . . .
dc_pilgrim is offline
post #701 of 1000 Old 02-13-2012, 06:58 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
Cool! I think we have the same screen if you're talking diagonal size.
My 120" wide 16:9 (137.7" diagonal" EN4K screen came in last week. Masking panels are coming soon.
Now all I need to do it build a thater
Larry M is offline
post #702 of 1000 Old 02-13-2012, 11:35 AM
ADDUpstate's Avatar
Funny... I'm in the process of that right now.
post #703 of 1000 Old 02-13-2012, 11:39 AM
ADDUpstate's Avatar
Did you get the magnetic bar put in before the screen frame was shipped?
Can you post pictures of the panels?
I didn't know that the magnets needed to be put in the frame until after it was already ordered, so I'm thinking of ordering the friction ones from Seymour, because I can't get anything to fit properly since, as you probably have found out, the screen material is so tight to the frame that it is hard to get anything in between without risking the material, and the frame is tapered, so friction fit is tough.
post #704 of 1000 Old 02-13-2012, 11:47 AM
ADDUpstate's Avatar
Not home made. KEF TDM Series from back in the 90s. Sealed, THX certified, (if you care about that), and they were all "free", except for the second sub. (They came with the house) I bought and rehabbed the second sub off eBay.
They really are awesome for their age...
http://kef.com/html/en/explore/about...s_T/index.html
post #705 of 1000 Old 02-13-2012, 04:09 PM
SVonhof's Avatar
Quoted: 14 Post(s)
Interesting. I knew KEF made the drivers that shape, but had never seen any with the driver at an angle like that.
SVonhof is offline
post #706 of 1000 Old 02-13-2012, 05:19 PM
ADDUpstate's Avatar
They're usually behind a PITA-to-remove speaker sock, which I took off since I was going to an AT screen.
post #707 of 1000 Old 03-04-2012, 06:17 PM
ebay_bob's Avatar
AddUpstate...I tried to send you an email but I'm new to posting, so couldn't until I hit 5 posts..lol. I know this is an old post, but can you help me out to build something similar to your screen wall? It looks very professional and nicely put together. What kind of material is around the screen (black materiel)? At first I assumed your speakers were behind it. Is there a reason they are not? I have my room about done, except the wall for the screen, so any help you could provide would be greatly appreciated. Thanks in advance.
ebay_bob is offline
post #708 of 1000 Old 03-26-2012, 11:43 PM
tsiroadkill's Avatar
Here's mine finally almost done.
tsiroadkill is offline
post #709 of 1000 Old 05-12-2012, 01:08 PM
Gatmix's Avatar
Attachment 246367
Here is mine although I still have work to do on the trim and touchups.
I also just finished adding led's in the area that the screen lowers from. Its a 100" electric Favi screen. I hope to finish the basement soon.
Gatmix is offline
post #710 of 1000 Old 05-12-2012, 01:10 PM
Gatmix's Avatar
Gatmix is offline
post #711 of 1000 Old 05-31-2012, 02:29 PM
filetandrelease's Avatar
120"x 60" DIY Seymore AT Screen-
filetandrelease is offline
post #712 of 1000 Old 05-31-2012, 09:15 PM
jdanforth's Avatar
Liked: 25
Very clean! We also appear to have similar carpet although mine is a smidge greyer.
jdanforth is offline
post #713 of 1000 Old 06-01-2012, 10:03 AM
THat is a martha stewart from Lowes- nice pattern for $2 a sq/ft.
post #714 of 1000 Old 06-01-2012, 05:28 PM
IGO2XS's Avatar
140" SMX Pro Line 16:9 Cineweave
ryanblumenow likes this.
IGO2XS is offline
post #715 of 1000 Old 06-01-2012, 08:26 PM
nickbuol's Avatar
Quoted: 671 Post(s)
Liked: 709
IGO2XS, there is a "screen wall" in that room? I can't see it past the whole room's AWESOMENESS!
Seriously though, outstanding room (and wall).
nickbuol is offline
post #716 of 1000 Old 06-03-2012, 06:15 PM
IGO2XS's Avatar
thank you!! every night is movie night at our house
IGO2XS is offline
post #717 of 1000 Old 06-03-2012, 09:22 PM
Shift's Avatar
Quoted: 94 Post(s)
Liked: 65
Wow!!! Now that's nice!!!!! We have a winner!!!
Preponderance
1: a superiority in weight, power, importance, or strength
2a : a superiority or excess in number or quantity
2b : majority
Shift is offline
post #718 of 1000 Old 06-04-2012, 12:16 AM
rumpeli's Avatar
the screen walls changed over the years. Today there are three active studio monitors behind the curved at screen.
rumpeli is offline
post #719 of 1000 Old 06-04-2012, 03:47 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
Cool Metamorphosis
GetGray is offline
post #720 of 1000 Old 06-23-2012, 05:54 PM
popalock's Avatar
Quoted: 1317 Post(s)
Liked: 1814
Stunning...
Here is a pic of my 130" 2.35:1 Focupix screen. Cost me $268 out the door. I'm a but OCD when it comes to symmetry, but my setup us going to have to remain as is for a few more weeks until I can complete my dual LMS build...
popalock is offline
