Show us your screen walls - Page 31 - AVS | Home Theater Discussions And Reviews
 50Likes
post #901 of 923 Old 01-31-2015, 05:32 PM
ellisr63's Avatar
Quoted: 343 Post(s)
Liked: 284
Originally Posted by LeBon View Post
That is great to hear. I am building mine with the front row at 12 ft. from a 12 ft. wide 2.35:1 screen, and have worried about being too close to the screen.
If you go like I did and go as big as you can... You can test it out for yourself and see how big of a screen you are happy with and then mask the screen if you want it smaller.
Denon 4520ci, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, (3) MiniDSP 2x4s, (4) Klipsch HIPs,  PS3, XBox 360, (3) Intel NUCs, Redmere, Monster HTPS7000, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diagonal) scope screen, Darbee Darcet, Yamaha P7000s, (2) Yamaha P2500s, & (3) Topping 25wpch T chip amps.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #902 of 923 Old 01-31-2015, 05:38 PM
Jeff in Canada's Avatar
Quoted: 142 Post(s)
Liked: 54
Here is my screen wall now that it is done. 11' 6" SMX acoustically transparent screen. Speakers are behind the screen and the doors on the side (behind the FR701)
Name:	Jan 2015 Front Angle.jpg
ID:	515409   Click image for larger version
Name:	Jan 2015 Front.jpg
ellisr63, Jonny5nz, Djoel and 4 others like this.
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #903 of 923 Old 01-31-2015, 06:33 PM
dlbeck's Avatar
Quoted: 227 Post(s)
Liked: 280
SevmourAV XD 2.37:1 148" wide screen with JTR speakers behind
ID:	515457   Click image for larger version
ellisr63 likes this.
dlbeck is online now
post #904 of 923 Old 02-01-2015, 12:17 AM
jbrown15's Avatar
Quoted: 1975 Post(s)
Liked: 1499
Jeff the room turned out really nice!
jbrown15 is online now
post #905 of 923 Old 02-01-2015, 06:34 AM
Quoted: 142 Post(s)
Liked: 54
Thanks JBrown.
Theater Build
post #906 of 923 Old 02-01-2015, 06:06 PM
LowellG's Avatar
Quoted: 294 Post(s)
Liked: 148
Here it is.
groundtrac and thrillcat like this.
Lowell
The MARVELous Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is offline
post #907 of 923 Old 02-02-2015, 08:48 AM
nathan_h's Avatar
Quoted: 196 Post(s)
Liked: 111
updated
____________________
Build thread & current gear: "Nathan's Theater in Search of....".
nathan_h is offline
post #908 of 923 Old 02-02-2015, 11:27 AM
hanesian's Avatar
Liked: 50
Some really nice rooms here!
One Old Fart request to consider: it would really help if you could embed full size photos rather than using the postage stamp size "attachments."
I know you can click on them, but the easier you make on on people (especially us old dogs), the more views and feedback you're likely to get.
The Un-Theater Un-Build
hanesian is offline
post #909 of 923 Old 02-02-2015, 05:03 PM
Jonny5nz's Avatar
Quoted: 29 Post(s)
Liked: 89
Jonny5nz is offline
post #910 of 923 Old 03-20-2015, 05:23 AM
g_bartman's Avatar
Quoted: 65 Post(s)
Liked: 74
g_bartman is offline
post #911 of 923 Old 03-25-2015, 06:33 AM
fuj32's Avatar
130 inch 16:9
Name:	2015-02-19 11.38.24.jpg
ID:	623889   Click image for larger version
Name:	2015-02-21 18.49.35.jpg
ID:	623905   Click image for larger version
Name:	2015-02-22 19.43.50.jpg
Receiver - Denon x4000 // LCR - DIYSG Tempest Fusion 12s // Surrounds - DIYSG Vibe 6 // Subs - Cinema F-20 (2) w/ iNUKE3000dsp // Screen - 130in 16:9 Spandex // Projector - BenQ w1080st // Bluray - Oppo BDP103 // Bass Shakers (4)
fuj32 is offline
post #912 of 923 Old 03-25-2015, 06:57 AM
BllDo's Avatar
Quoted: 204 Post(s)
Liked: 150
Originally Posted by fuj32 View Post
130 inch 16:9
I like that a lot. Well done. Do you have any construction photos of the screen wall or basement? I assume your subs are behind the screen wall as well? How do they perform behind the solid surfaces?
Is it solipsistic in here, or is it just me?
BllDo is offline
post #913 of 923 Old 03-25-2015, 07:55 AM
fuj32's Avatar
Thanks...I have to give the credit to my Dad. I came up with the design and he figured out how to build it all. In some of the pics below you can see how my subs are oriented back there. We just threw up some plywood as a finishing piece so I wouldn't have to dress up the subs, add panel molding to them etc. They perform fine. They are firing back towards the wall, about 8 inches off the wall. I read somewhere that the F20 should be around 18in off or so, however mine sound pretty good so far and shake the whole basement (approx. 1000sqft). Still have some calibrating to do. The Velvet border is permanent, as we wrapped 4 separate pieces of MDF and then nailed in place. The screen is wrapped around a wood frame as you can see in the pic (that is showing the back side of the screen obviously). The screen sits right in place.
I know a lot of people use a French cleat system to hang their screen, however I went a different route. As you can see in some of the pictures, we used small pieces of wood in each corner as stoppers so the screen would sit at a specific depth. Then used magnets to keep everything level and as an extra measure of security, even tho it is a very tight fit. Just makes me feel better when the magnets clip and I hear everything go together.
Name:	2014-11-09 18.03.52.jpg
ID:	624289   Click image for larger version
Name:	2014-11-16 12.07.59.jpg
ID:	624297   Click image for larger version
Name:	2014-11-30 12.55.49.jpg
ID:	624305   Click image for larger version
Name:	2014-12-08 19.10.03.jpg
ID:	624313   Click image for larger version
Name:	2015-02-21 13.40.26.jpg
Name:	2015-02-21 13.40.37.jpg
ID:	624329   Click image for larger version
Name:	2015-02-21 16.59.11.jpg
ID:	624337   Click image for larger version
Name:	2014-11-17 20.37.51.jpg
nathan_h and JasonBrown like this.
fuj32 is offline
post #914 of 923 Old 04-12-2015, 05:25 AM
Brian Fineberg's Avatar
Quoted: 1518 Post(s)
Liked: 1385
Dan Hitchman likes this.
Panasonic 65VT30 | Panasonic AE8000 HD PJ | Emotiva XMC-1 | Emotiva XPA-5 gen | PSA MT110 x 3 FL/C/FR | PSA MT110sur surrounds | 3 - PSA XS30 (1 SE) | OPPO 103 |
the SadieMax HT build thread - my first build
Brian Fineberg is online now
post #915 of 923 Old 04-12-2015, 11:51 AM
jbrown15's Avatar
Liked: 1499
Originally Posted by Brian Fineberg View Post
Looks good Brian, did you figure out what you're going to do for trim work on the columns?
post #916 of 923 Old 04-12-2015, 12:31 PM
Liked: 1385
Not yet no. But that will be v 1.1
post #917 of 923 Old 04-15-2015, 12:03 PM
gnolivos's Avatar
Quoted: 24 Post(s)
I searched but couldnt find any thread on this..so I thought to start one or perhaps someone could point me to the original one...<br><br>
But how about posting pics of your screen walls...thanks. No pics of projected images please.
I looked at countless of these wonderful front wall builds... very nice. Question: Why is it not common to build a false wall simply using curtains? I have an AT screen, so the speakers will be behind the screen itself... I was planning on dropping 2 black curtains on the sides of the screen, and similar treatment on the bottom. The top would have a valance of sorts running horizontally...
The Moderno Theatre! Slideshow (here, and here!)
Pixar screenplay slideshows here!
gnolivos is online now
post #918 of 923 Old 04-15-2015, 02:01 PM
Lindy0026's Avatar
Quoted: 25 Post(s)
Lindy0026 is offline
post #919 of 923 Old 04-17-2015, 02:05 AM
xzener's Avatar
Quoted: 28 Post(s)
Liked: 37
Lindy0026,
How is the experience with the Kinect being so high?? Do you have it pointed down quite a bit for floor mapping?? Do you have any issues wit it up there?
xzener is offline
post #920 of 923 Old 05-21-2015, 10:04 AM
drjay71's Avatar
Quoted: 14 Post(s)
My 2.35 setup
Screen Innovations 2.35:1 pure white screen 133" diagonal
JVC X500R projector 4K e-shift 1080p projector
Jamo THX LCR speakers
Paradigm AMS 150R-30 surround speakers.
Oppo 103D Blu-Ray player
Lumagen Radiance Mini 3D
Apple TV
Verizon Fios DVR
Control 4 HC800
Onkyo TXNR-636 AVR
ID:	728834   Click image for larger version
drjay71 is online now
post #921 of 923 Old 05-21-2015, 10:56 AM
ssavsguy's Avatar
Liked: 0
Here's my completed screen wall.
Screen: 16x9 125" EluneVision Reference Studio 4K
Speakers & Sub: Paradigm Monitor Series
Media Cabinet: IKEA Cut hole in the wall, mounted cabinet, surrounded by Home Depot trim. All components now accessible via furnace room behind.
I will posting some close-ups and a summary of the install in another thread; I just need to take some more photos first
Cheers!
Safi
ssavsguy is offline
post #922 of 923 Old 05-21-2015, 12:58 PM
majek 60's Avatar
Quoted: 58 Post(s)
Liked: 73
108" EluneVision Reference Studio 4K with PSA MTM-210'S.
majek 60 is offline
post #923 of 923 Unread Today, 05:10 PM
gcolby's Avatar
115" Seymour XD
gcolby is online now
