Shallow projector mount recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-31-2006, 06:11 PM - Thread Starter
HendersonD's Avatar
The ceiling height in my almost completed theater is 6' 11". For this reason I have decided on the Infocus IN76 projector which has a small offset. For the width of my screen (96") the offset is about 8.4". In other words, the top of my screen needs to be at least 8.4" below the center of the lens. Whatever additional distance the mount moves the projector down needs to be added to the 8.4". I would like to find a mount, whether commercially available or homemade, that is shallow. Preferably I would like to find a mounting solution that only takes up about 2". This puts my screen 10.4" from the ceiling.
Any recommendations?
HendersonD is offline
post #2 of 3 Old 12-31-2006, 06:37 PM
Davinleeds's Avatar
http://www.mountdirect.com/PhotoGall...=4#largerphoto This is as tight as it might get otherwise a shelf type setup but you don't want to restrict airflow.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #3 of 3 Old 01-01-2007, 06:34 PM
scaesare's Avatar
The Chief RPA series mounts are about 2-5/8" when used in a flush-mount configuration.
-Steve
scaesare is offline
