Show me your RACK - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 470Likes
post #451 of 2839 Old 12-15-2008, 01:02 PM
dhnjp1's Avatar
Originally Posted by jongig View Post
How did you make out with your fan?
I purchases a Nutone 100 CFM bathroom fan that was the quietest they sell at less than 1 sone and I can hear it and I hate hearing fans. I'm going to have to try something else. Seemed like such a nice idea.
The Panasonic FV-05VQ3 50cfm fan I got is very quiet (<0.3 sones) and seems to move plenty of air. I haven't installed it yet because I need to keep my theater intact for demos over the holidays. Should be ready by mid January.
The FV-05VK1 might be better, and is only $20 more. It can maintain 50cfm with a longer duct (but higher speed=more noise), or with a short duct it only uses 6 watts (<0.3 sones).
--Dan
dhnjp1 is offline
post #452 of 2839 Old 12-15-2008, 01:25 PM
akakillroy's Avatar
Updated my rack, simple and contains my projector:
+Peace be with you+
akakillroy is offline
post #453 of 2839 Old 12-21-2008, 01:39 PM
charcoal grey's Avatar
I like the idea of combining projector and equipment. Do you have any heat issues?
My DIY Screen Build
L/C/R Rockets RS1000
Side and Rear RS450's
Subs: (4) FI 18" IB
charcoal grey is offline
post #454 of 2839 Old 01-03-2009, 02:06 PM
RobertR's Avatar
Quoted: 494 Post(s)
Liked: 660
I can't take a far away enough picture to show the whole thing, but here are some:
I built it with Unistrut and custom-cut pieces of steel, to give it that custom Middle Atlantic look without the Middle Atlantic cost.
RobertR is offline
post #455 of 2839 Old 02-02-2009, 01:29 PM
krep's Avatar
Does MA offer a rack slide that I would be able to slide the rack to the right (sideways), enter a tiny equipment room, slide it back into place blocking the doorway, and then work on the rack from the back?
I have a slightly "oddly shaped" equipment room. It's in a corner and I currently have a cheapo walmart shelf holding my equipment and am debating going to a Mid Atlantic rack.
My room is about 7(w)x4(L)x3-5(h). The ceiling is diagonal, its about 5' at the doorway where you enter, decending to the wall 4' away to be only about 3' high. Current the equipment shelf is on caster, I roll it to the right, get inside the tiny room, then crawl behind the rack and make my mods, and then get back out (yes it is loads of fun).
Also I am out of "shelf" space, thus my preference to replace it with a rack.
krep is offline
post #456 of 2839 Old 02-02-2009, 02:25 PM
GPowers's Avatar
Quoted: 47 Post(s)
Liked: 64
Just add some wheels to the rack MA sells the wheels. when Compaq was selling racks they all came with wheels.
GPowers is offline
post #457 of 2839 Old 02-02-2009, 03:19 PM
krep's Avatar
I suppose that is the easiest solution huh? My current "shelf" doesn't roll very easy because the closet has carpet. I was worried by the time I got a fully stocked 48" rack it would be so heavy it would barely roll. I should probably just put down some hard surface over the carpet so it can be easily rolled...
krep is offline
post #458 of 2839 Old 02-02-2009, 04:51 PM
Tedd's Avatar
Quoted: 1098 Post(s)
Liked: 422
Why not just screw down some steel U track for the wheels. (Unistrut perhaps??) It would give an easy rolling surface and maintain rack alignment?
Any rolling rack would also need some sway bracing, as well as any heavy amplifiers mounted down low.
We need a picture of that av closet!
Tedd is offline
post #459 of 2839 Old 02-02-2009, 07:30 PM
04FLHRCI's Avatar
Putting the finishing touches on my diy rack; I need to install the smoked plexi in the doors, and subsequently, mount the doors. I'm attaching an initial 'quick' shot.
Larry
04FLHRCI is offline
post #460 of 2839 Old 02-03-2009, 06:51 AM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
Larry
holy crap - glad I'm not your neighbor.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #461 of 2839 Old 02-03-2009, 11:57 AM
krep's Avatar
When its finished you can see some pictures of the OUTSIDE - but hopefully no one but me will ever see the inside! LOL
As for Unistrut, good idea but, I think when I attached the wheels (the shelf was originally intended to be temporary) I didn't bother with such silly things as "symmetry".
I am thinking about just attaching some rack rails to the shelf, a bit of extra bracing, one of those clear under-desk rolly-chair mats, and calling it good. Heck, when it's flush with the door, I guess no one but me would know the difference!
krep is offline
post #462 of 2839 Old 02-03-2009, 07:51 PM
Beemer533's Avatar
I just moved into my house, so everything is still in progress.....
I have a closet in the corner of the family room that is housing the AV rack, I have no access to the rear so I had to be able to slide the rack out. I was originally going to get some slide rails, but it started to get too complicated so I made a rail system from Uni-strut (I love that stuff) and 2" C channel from HD. I bolted angle to the sides of the rack and added wheels.... works pretty well.
I've been concentrating on the wiring, so the rack isn't populated yet.
Kevin4730 likes this.
Whiskey Tango Foxtrot, Over.....
Beemer533 is offline
post #463 of 2839 Old 02-04-2009, 09:12 AM
GPowers's Avatar
Quoted: 47 Post(s)
Liked: 64
What is photos 402 all about. Is that your DIY power filter/conditioner?
GPowers is offline
post #464 of 2839 Old 02-04-2009, 09:20 AM
platinum_ht's Avatar
It's not wall mounted but here's mine.
http://www.avsforum.com/avs-vb/vbcla...?do=ad&id=8933
platinum_ht is offline
post #465 of 2839 Old 02-04-2009, 09:27 AM
GPowers's Avatar
Quoted: 47 Post(s)
Liked: 64
That is over the top. What a place to show off all your hardware. Very cool...
GPowers is offline
post #466 of 2839 Old 02-04-2009, 01:05 PM
Beemer533's Avatar
@ Gpowers
I guess I should have put in a description....!
That is my relay/delay box. When my Marantz turns on, the 12v triggers one of the relays which immediately turns on my crossovers, feedback destroyer, etc. It also starts the timer (the small PCB in the box) so 10 seconds later all the amps get turned on. I based it on my Adcom unit which basically does the same thing, but didn't have the capacity for the extra A500s I will be adding. Each relay switches a 20A circuit.
post #467 of 2839 Old 02-04-2009, 01:35 PM
GPowers's Avatar
Quoted: 47 Post(s)
Liked: 64
Thanks for clearing that up.
GPowers is offline
post #468 of 2839 Old 02-06-2009, 11:28 PM
CollinViegas's Avatar
Wall racks are coming this week for the DVD's and Blurays
CollinViegas is offline
post #469 of 2839 Old 02-07-2009, 08:13 AM
John H's Avatar
I just finished the closet and loaded up the equipment Wednesday. I haven't had time to route the cables.
John
John H is offline
post #470 of 2839 Old 02-07-2009, 08:15 AM
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
Wow John,
That is amazing...all DIY??
How about some build pics??
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
post #471 of 2839 Old 02-07-2009, 08:29 AM
John H's Avatar
Originally Posted by kevin g. View Post
Wow John,
I don't have to many build photos.
John
Randall.White likes this.
John H is offline
post #472 of 2839 Old 02-07-2009, 05:19 PM
hellerbrewing's Avatar
Mine is still in progress, I am adding pieces as I can afford them or find them on ebay. at least the theater is up an running and sounding good!
hellerbrewing is offline
post #473 of 2839 Old 02-22-2009, 05:20 AM
guamguam's Avatar
Not as glamorous as most, but it only cost me about $60 in materials and is very functional.
Front:
Back:
My build thread:
The Maple Street Theater
guamguam is offline
post #474 of 2839 Old 02-22-2009, 07:17 AM
Sokoloff's Avatar
Where did you get that many big shelf brackets for under $60? (I don't need them for AV, but I need them for my pantry... )
Sokoloff is offline
post #475 of 2839 Old 02-22-2009, 07:26 AM
guamguam's Avatar
I got all of my stuff at Menards. I think the brackets were about $3.50 a pair and the rails to attach them to were about $8 a piece.
My build thread:
guamguam is offline
post #476 of 2839 Old 02-22-2009, 08:26 AM
corejonp1's Avatar
Let me first state, that this thread is nothing but pure unadulterated rack porn.
I just ordered a pair of Middle Atlantic RRF 12u rack rails (although now I think I should have gotten the 14u rails instead). I am going to be modifying an entertainment center, one of those huge 4 piece ones that takes up and finishes a huge chunk of wall. In my case it is 110 inches wide. well the two towers have at their bases 18 7/8 inch wide doors with plenty of room behind them, so I am going to do two 12 (probably 14..that whole measure twice thing) small racks, built in to the furniture. It is going to require some modifications to fit exact, so I am going to mount two pieces of wood inside the cabinet just slightly wider than the door opening, and mount the rails to that. And for anyone wondering how that would work for a piece of hardware with a face say 1/8" to wide, you simply angle the unit a smidge to clear one side first (works in my mind anyway). That said, the 2 things I have now that are rack mountable are 18 7/8" wide and will fit with pretty much zero gap - in fact I might need to keep a mallet on hand. (oh it will fit)
-Corey
Equipment list:
The tv is a 50" Sony A2020 SXRD 1080p
Right Rack:
HD Cable box
PS3 - 60gb
XBox 360 Elite
Yamaha HTR-5960 (short list to upgrade)
Monster Power PRO 3500 (got it for cheap)
Left Rack:
PS3 - 60GB
XBox 360 (black face plate)
Denon, 3808ci
Monster Power HTS 3500 MK2 (got this for cheap too)
Network Gear:
Linksys CM100 Cable Modem
Apple Airport Extreme 802.11n wireless router
HP Procurve 1800 8G 8 port gigabit switch
Apple Airport Express 802.11n bridge for the kitchen -
extends wireless range, and adds a wireless kitchen audio zone for use with
I-Tunes air tunes. Works awesome in my tests.
Current speakers in the main room are Yamaha NS Series, triple 5 fronts, with triple 3 center and triple 4 surrounds. The speakers and receiver are all planned to be upgraded after I get back from Flight Engineering school. My brothers bedroom set up has a 40 inch Samsung 6 series touch of color and JBL Studio-L's and will be run from the left rack, the wires will be run through the wall.
We move in sometime in April around the 20th so pictures will be added.
.."wouldn't you like to be a pepper too?"
corejonp1 is offline
post #477 of 2839 Old 02-27-2009, 01:28 PM
vdubturbo's Avatar
Well, I've been waiting a long time to be able to post in this thread... and leave it to me to post on a Friday when there's probably no one looking. But, here is finally is. Comments suggestions welcome! Thanks for all the motivation!
vdubturbo is offline
post #478 of 2839 Old 02-27-2009, 01:46 PM
md1953's Avatar
vdubturbo,
Very nice and clean install.
A couple of things, what's the top unit in your rack aside from a downlight? Also, get rid of the stickers on the Denon
md1953 is offline
post #479 of 2839 Old 02-27-2009, 04:41 PM
Mr_Mike_P's Avatar
Any build pictures? looks like what im trying to do!
Mr_Mike_P is offline
post #480 of 2839 Old 02-27-2009, 05:28 PM
GPowers's Avatar
Quoted: 47 Post(s)
Liked: 64
We look at the forum on our time over the weekend and works time during the week.
GPowers is offline
