Show me your RACK - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 444Likes
post #631 of 2793 Old 07-16-2009, 10:52 AM
andersa's Avatar
Quoted: 32 Post(s)
Liked: 32
Originally Posted by KingLeerUK View Post
It's very basic, using the patch panel as a simple pass-thru/routing system. The beauty is, that as with the CAT6 panels, I've overbuilt to allow for future expansion and routing options. If I ever do need to patch in additional gear, I have 5 dedicated runs to/from the rack, and the rest feed to keystones in panels throughout the house.
OK, thanks for the explanation.
andersa is online now
post #632 of 2793 Old 08-06-2009, 04:36 PM
jetski's Avatar
I searched all over, does anyone have a photo of the MA Slim 5 Rack with the skirted base???
jetski is offline
post #633 of 2793 Old 08-10-2009, 02:06 AM
Spizz's Avatar
Quoted: 194 Post(s)
Liked: 81
Should I use one of those MA Vent plates between 2 set top boxes (Satellite box and PTV Box), and also one above a Receiver?
Spizz is offline
post #634 of 2793 Old 08-10-2009, 04:36 AM
TomsHT's Avatar
I dont think its neccessary to put a vent between each & every component. On my rack, I have a single 2 shelf vent plate and the only reason thats there is to cover blank space for a future component.
I think the faceplates themselves already ensure there is enough room between components. If your having any further issues with overheating past that, then ya autta looking into an exhaust/fan system to be installed
TomsHT is offline
post #635 of 2793 Old 08-10-2009, 08:24 AM
Weasel9992's Avatar
I vent between power amps/pre amps...anything that generates a lot of heat.
Frank
Frank Oesterheld
Weasel9992 is offline
post #636 of 2793 Old 08-14-2009, 06:55 PM
jstdoit1112's Avatar
Originally Posted by UberDave View Post
This thread needs more pictures! I just completed my cabinet/rack install last week; here's how it turned out. I don't have much in the way of quality equipment but you have to start somewhere. This is my first dedicated theatre area so I'm pretty pumped that it's almost finished!
From this (ikea cabinet bought off kijiji; not my car in the background ):
To This:
WOW you still have and original xbox? mine died after eight months. lol jk
great idea on the ikea make-shift rack its great
jstdoit1112 is offline
post #637 of 2793 Old 08-16-2009, 09:54 AM
AVA-SF's Avatar
Location: I work in San Francisco & work in Oakland, Ca
Just thought I would show some photos of a clean up project we finished recently. The giant mess is the before photo.
AVA-SF is offline
post #638 of 2793 Old 08-16-2009, 11:47 AM
Weasel9992's Avatar
Nice job man.
Frank
Frank Oesterheld
post #639 of 2793 Old 08-17-2009, 07:55 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 144
Beautiful job - I'd love to see the before pics.
The extra fasteners make a big difference.
Some close-ups of the back would be useful.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #640 of 2793 Old 08-17-2009, 01:33 PM
ctbundy's Avatar
very nice rack hellerbrewing.
How wide is the opening to install your rack and where did you get it from. I have an opening in my wall that is 55" high X 19" Wide. I was going to construct my own face plates but those Middle Atlantic racks just look so Damn Hot!!
ctbundy is offline
post #641 of 2793 Old 08-18-2009, 09:45 AM
GPowers's Avatar
Quoted: 46 Post(s)
Liked: 59
I you want to see some over the top racks, check out the article attached to this thread
GPowers is online now
post #642 of 2793 Old 08-20-2009, 07:17 AM
Rmassey's Avatar
I have moved past Rackzilla and built myself a proper wiring closet.
Total size is 41 rack spaces
(1 wasted due to covering feet on my power amp, so 40 rack spaces total)
Yeah, I've been busy - take a look...
+ more rack parts are on order and more photos to come...
Before picture - using RackZilla to hold HT gear
Open space with wires home run
Framing wiring closet
Drywall is up / Door is hung
Drywall is done
Finish work is done
Started loading HT gear
I have a 4u rack drawer, another shelf and some blank panels on order to finish things up. I am debating if I want a monitor in the top of the rack or save the space for future expansion.
updates - 8-26-09
Finished Rack
Wide view showing side door
Gear (Top to bottom) -
Furman Pwr / HD-Tivo(S3) + 1 TB eSata HD / Mag DVD-R / Oppo 983 / Panamax 5100 / Velo- SMS-1 / Integra 9.8 Pre / Sherbourn 7/2100
Rear view / Wire mess - I'm working on it...
I have one more slotted panel coming to put below the pre for better air flow, Quiet Panny fan is also on my TODO list.
Rmassey is offline
post #643 of 2793 Old 08-20-2009, 07:52 AM
hellerbrewing's Avatar
Thanks! I am not sure of the exact dimensions of the opening but middle atlantic has the dimensions of the racks here.
Here's a link to my post again.
When we put it in, we made the opening just a little bit larger than the rack. I put a few blank panels in the rack as well as the one that came with it and then we shimmed it in tight and screwed the rack to the framing through the shims. When we trimmed it out we just butted the trim right up to the faceplates to give them a nice tight fit. Only thing I should have done differently was that we framed it the same height of the empty door frame that we put in next to it. We probably shold have installed the door jamb first so that we could have framed the rack to the same height of the door jamb. We did not think about the width of the jamb and how it would make the trim a different height. We ended up using oak door stop for trim on the rack so it would be a little different and the height difference would not be as noticeable. I think it looks pretty good this way and I don't think anyone really notices the difference now.
hellerbrewing is offline
post #644 of 2793 Old 08-20-2009, 07:56 AM
Nice rack!
post #645 of 2793 Old 08-20-2009, 08:10 AM
andersa's Avatar
Quoted: 32 Post(s)
Liked: 32
Nice looking Rmassey!
Question: how is the closet vented?
/Anders
post #646 of 2793 Old 08-20-2009, 09:07 AM
Rmassey's Avatar
Yes, venting is on my TODO list. I am looking into a quiet Panasonic fan to mount in the ceiling. My space is limited because in the ceiling/soffet just above the closet is HVAC, but I think I have ~ 10" to work with. I was going to finish up the rack and get the front panels and check the temp/airflow.
Panny Fan:
http://www.panasonic.com/business/bu...sper-green.asp
Also, I want to add a permanent overhead light + switch, so that's two electrical items on my TODO list.
Rmassey is offline
post #647 of 2793 Old 08-20-2009, 02:51 PM
Weasel9992's Avatar
Wow...nice job man.
Frank
Frank Oesterheld
post #648 of 2793 Old 08-26-2009, 05:17 PM
wordgasm's Avatar
Hi,
I'm starting to do the cable management and connections for my rack and I have a couple questions.
1.) A lot of the racks I see pictures of, the A/V connections coming from the theater (Speaker wires, HDMI, Subwoofer) are going into a patch panel or wall jacks, then to the gear. Is there a compeling reason for this? I would think the least amount of connections the better. (I can leave a loop of spare cable under the house or in the attic if I had to move the gear.)
2.) Network connections for gear "in the rack". Should I run directly to the network switch or run them thru a patch panel. I can see both sides for this one?
3.) Is there a need for patch panel connections (A/V, RG6, etc) inbetween the gear "in the rack"?
4.) Can I run the ""IR" Eye/Jack cords on the same side of the rack as the power or could there be interference?
5.) If I'm using 22AWG HDMI cables to Display and other gear, should I use port savers at the gear AV receiver, HTPC, etc for sure?
6.) I've heard, my Digital OTA antenna (UHF/VHF) will pick up HD radio also, is this true? (Don't have a HD Radio receiver yet)
Note: My 45 space rack will be full and all the gear is placed for usability and access (visual and physical) usage, and heat mangement, so I don't see the individual gear units getting moved much.
Thanks for your time
Jeff
wordgasm is offline
post #649 of 2793 Old 08-26-2009, 05:32 PM
Originally Posted by wordgasm View Post
Hi,
I put patch panels in the rack primarily for organizational purposes. I didn't want to put another termination in the speaker wires so I stripped the outer sheath off my monster XPHPCI and ran each individual wire through the speaker terminal keystone jack and terminated the end. It also saved from having to buy more banana plugs. I did terminate the HDMI and coax in the patch panel though.
For the RJ45 I terminated all of the runs from the rest of the house in a patch panel that was right above the 24 port netgear switch. I plan on running cat5e down the side of the rack and terminating to length right at the switch. Would not really matter if you did it either way, I just thought it was a good way to keep things seperate.
I would like to know about the HD radio thing as well. Interesting question
post #650 of 2793 Old 08-26-2009, 06:49 PM
wordgasm's Avatar
To me its scary...... Ive got 12 network connections in just the rack (well with a couple futures)..... I have a 24 port switch also .... but Im sure thats enough .. everything is in the rack and then wireless
Jeff
wordgasm is offline
post #651 of 2793 Old 08-26-2009, 08:16 PM
Rmassey's Avatar
FYI - I updated my photos above in post #642, check it out
Rmassey is offline
post #652 of 2793 Old 08-27-2009, 07:01 AM
whiskey alpha's Avatar
Nice work.. It looks like you next project should be some built in shelving for the dvd's
whiskey alpha is offline
post #653 of 2793 Old 08-27-2009, 08:18 AM
Weasel9992's Avatar
Nice. Those are the shiniest rack drawers I've ever seen.
Frank
Frank Oesterheld
post #654 of 2793 Old 08-27-2009, 10:52 AM
Rmassey's Avatar
Thanks, prob due to the camera flash, but I did wipe all the fingerprints off before I took the photo
nah, I keep telling myself to stop buying media... problem is I don't listen
Funny story.... my wife paid me the ultimate compliment and said
"Looks good... they should just build these into all houses" - I love it.
Rmassey is offline
post #655 of 2793 Old 08-27-2009, 12:22 PM
Good for you. When I mentioned to my wife that I was running out space to store my blu-ray, she said maybe I should stop buying them. While that is grounds for divorce in some states, I decided to just built this. Plenty of room now.
post #656 of 2793 Old 08-27-2009, 03:46 PM
Spizz's Avatar
Quoted: 194 Post(s)
Liked: 81
Very nicely setup.
Spizz is offline
post #657 of 2793 Old 08-27-2009, 04:25 PM
wordgasm's Avatar
Hi,
Jeff
Is there another thread or forum that any of you know of to get questions answered that are rack specific?
Jeff
wordgasm is offline
post #658 of 2793 Old 09-07-2009, 04:38 PM
wordgasm's Avatar
Well, I made some progress this weekend. Learned some things. Know things I would do different. But overall happy. 3/4's of the rack done and happy.
Not totally happy with connections and "connection loops" but that's another weekend, year, never! (Don't know if I could do better unless I did it daily, but I'll try, I'm sure!)
The SMC (white panel to the left, is going away, I found a better way)
Anyone want to trade some MA 1u lacing rails for some 2u? (Hey I'm new, I didn't knnow better!), see photos you'll understand.
Hope you enjoy! Still a way to go....
Jeff
wordgasm is offline
post #659 of 2793 Old 09-07-2009, 09:34 PM
GPowers's Avatar
Quoted: 46 Post(s)
Liked: 59
I found that just a simple lacing bar works great, they allow easy access to the back of your equpment, as they are simply a bar.
post #660 of 2793 Old 09-07-2009, 09:44 PM
Scopeguy's Avatar
I agree with GPowers, the lacing bars seem to work great.
Greg
Scopeguy is offline
