Show me your RACK - Page 78 - AVS | Home Theater Discussions And Reviews
 80Likes
post #2311 of 2320 Old 03-17-2015, 06:00 PM
Sir Meili's Avatar
Originally Posted by mercracing View Post
Hey guys quick question while I am running my cables with the new lacing bars I got. I am aware you should try and run high voltage and low voltage separate. It would seem that nothing I have would work with this theory. Would I be hurting anything if I were to run power, HDMI, and ethernet all together? I am not a high end audio or video guy, I just have a normal(not too expensive) setup.
I ran mine on separate sides and only let them cross on the lacing bars.
Sent from my XT1053 using Tapatalk
Sir Meili is offline
post #2312 of 2320 Old 03-17-2015, 06:07 PM
Quoted: 27 Post(s)
Liked: 0
Do you run one lacing bar per piece of equipment? Any pictures?
mercracing is offline
post #2313 of 2320 Old 03-17-2015, 07:33 PM
Neurorad's Avatar
Quoted: 25 Post(s)
Liked: 89
You can use 1-5 lacing bars per piece of equipment - depends on how obsessive and rich you are.
Most of my power cords come out of the back on 1 side. I chose that side to run power vertically, in the rack. All power cords run off to that side. I used 2 lacing bars when the power cord came off the other side, but you most probably won't notice any difference if power and LV share a lacing bar. I bought a few 10-packs of lacing bars, of different offsets, so I had plenty to go nuts.
Neurorad is offline
post #2314 of 2320 Old 03-18-2015, 05:42 AM
Swancoat's Avatar
Quoted: 28 Post(s)
After buying and populating a rack, I'm probably rich enough to spring for 5 lacing bars for each piece
I ended up going with 1 bar for most, 2 for the AVR. In some instances, yeah a power cord travels across the same bar as signal. So far, no issues though.
Swancoat is offline
post #2315 of 2320 Old 03-18-2015, 06:40 AM
Sir Meili's Avatar
It depended on the piece of equipment. I have a deep rack that I have equipment on both sides. I've since created vertical lacing bars that go up each side in the middle of the rack that allow me to run lacing bars from the front to the back of the rack. Most of my cables now run up these "center" vertical lacing bars because of my equipment. The great thing about the Middle Atlantic Shelves is that they have cable management built in, so most of mine don't actually use lacing bars, but use that. For my Receiver I did at one point have 2-3 lacing bars feeding it, but I've changed that and just use the cable management on the self.
Either way, I would suggest, depeing on the amount of power, split your cables (at least analog audio cables). When facing the back of my receive I keep my A/V, Data, etc lines on teh left and run all my power on the right. Like I said they do have to cross at the device depending on the equipment.
I don't have too many great pictures, but you can check out my build thread for my equipment closet. There are some older pictures in there (I've redone the rack a few times since then...LOL)
My Home Theater Rack and Equipment room
post #2316 of 2320 Old 03-18-2015, 06:50 AM
kbarnes701's Avatar
Quoted: 3653 Post(s)
Liked: 2858
It's a bad idea to have mains and signal cables running alongside each other. Are you sure it is impossible to avoid in your setup? Do you have some photos of the rack and the gear so others can give their ideas?
Here is the back of my rack and as you can see, the power cables run down the right side, the speaker cables and HDMI cables down the left side and the interconnects down the middle, as far as is possible. and at that time I was using no cable management hardware (since rectified).
kbarnes701 is offline
post #2317 of 2320 Old 03-18-2015, 07:29 AM
Quoted: 27 Post(s)
Liked: 0
Show me your RACK
I only have two crapy iPhone pictures. Please remember this is temporary. I will prolly buy two more lacing bars so I have one per equipment. The main power cord to the power conditioner is very short. I was thinking about taking it apart some day and replacing the whole power cable with a longer one.
From the top down. OTA cable box, modem, and wireless on top. Power conditioner. Receiver. Switch. Bluray. Xbox 360.
post #2318 of 2320 Old 03-18-2015, 07:49 AM
kbarnes701's Avatar
Liked: 2858
Attachment 610361
Attachment 610369
Looking at the pictures I'd have thought it was possible to keep the power separate from the others, with some creative use of the lacing bars and cable routing. I made custom power cables for most of my gear, with the cable length the right length to route around the rack out of the way of the signal and speaker cables. It does take a little time, but the cost isn't much so it's worthwhile. In fact, in my cable box, I had pretty much all the cables I needed anyway - just had to modify the lengths bu shortening some.
post #2319 of 2320 Old 03-18-2015, 08:06 AM
Quoted: 27 Post(s)
Liked: 0
Most power cords are decent length. The main one is the short one. That's what I might try and lengthen.
post #2320 of 2320 Unread Today, 12:32 AM
Liked: 0
You can visit racksupplier.co.uk .The best website to find the variety of rack cabinets.We provide the best and posses the widest range of rack cabinets.The prices are also affordable and you will find all the racks at one place.We even supply all kinds of accessories used for racks.For more information you can visit the website and have a great experience.
racksupplier1 is online now
