Show me your RACK - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 158Likes
post #2431 of 2432 Unread Yesterday, 10:13 AM
Cokeswigga's Avatar
Finally got around to posting pictures of my rack install:
My living room had two cubby holes where an old CRT used to live. Since that TV died, and I replaced it with a LCD-TV, it was time to use up the useless cubby hole space... Behind the cubby holes is my office. So this made a logical place to put the rack (with all the AV stuff and my computers.)
ID:	923026   Click image for larger version
ID:	923034   Click image for larger version
ID:	923042   Click image for larger version
ID:	923050   Click image for larger version
ID:	923066   Click image for larger version
ID:	923074   Click image for larger version
ID:	923082   Click image for larger version
ID:	923090   Click image for larger version
ID:	923130   Click image for larger version
ID:	923138   Click image for larger version
ID:	923146   Click image for larger version
ID:	923154   Click image for larger version
ID:	923170   Click image for larger version
ID:	923178   Click image for larger version
ID:	923186   Click image for larger version
ID:	923194   Click image for larger version
Cokeswigga is offline
post #2432 of 2432 Unread Yesterday, 07:33 PM
jhughy2010's Avatar
Quoted: 623 Post(s)
Liked: 209
Originally Posted by Neurorad View Post
RU, Rack Units
I would prefer a black powder coated metal rack, to the black laminate, but I saved a couple hundred dollars with this BRK. This is a somewhat temporary setup, in my FR, hoping to move the equipment to another room in a year or 2. Hard to justify the cost of a nicer metal rack.
Metal racks from various manufacturers run 16-40" deep, MA laminate racks 16-28".
Middle Atlantic has some nice(r) enclosures to be used for conference rooms, with laminate tops, that you could consider. Another option is to drop a piece of granite or wood on the top, or put a 4-post rack inside a wood cabinet.
http://www.middleatlantic.com/produc...re-system.aspx
Step 1, I think you need to determine what depth your server chassis will be, or if you want a server in your living space. The server fan noise may be an issue, unless it's just a PC 'serving' movies.
Thanks for your help. Yes a black powder coated metal rack would be ideal but at this point I'm trying to keep costs down. The conference room racks are beautiful, however, way out of my price range.
The server chassis would have to be under the 22" if I were to go with the BRK20-22 correct? I think a 4U server chassis with 8-10 drive bays would suffice. I could replace the server chassis fans with some after-market fans that are quieter. There shouldn't be a lot of excess heat as long as I get a pretty big CPU cooler for it. The server is just for movies and streaming (so some transcoding but nothing crazy to create excess heat).
So in all the rack would have a Marantz (future) pre/pro, (2) Crown XLS amps, 4U server chassis and a rackmount power strip like this one. If I could throw a shelf in there near the top for a router and modem that would be cool too. Also might need an Ethernet hub but we'll see.
Pioneer VSX-1124-K, NHT Classic Three (L/R), Classic Two (rear) TwoC (center), PSA V1500 (x2)
HTPC/server (Emby)
OTA Winegard HD7698P
Sharp LC-60SQ15U
My DIY subwoofer build
jhughy2010 is online now
