Show me your RACK - Page 91 - AVS Forum | Home Theater Discussions And Reviews
 470Likes
post #2701 of 2839 Old 10-02-2016, 08:04 AM
Waterboy77's Avatar
Quoted: 562 Post(s)
Liked: 284
DIY Lacing Bars
Though I would share this from my build thread, as this thread inspired me for this idea
Originally Posted by Waterboy77 View Post
I love my rack but one of the things with a two post rack is the cable management out the back..... lacing bars are not an option
So I came up with a simple / cheap solution using heavy gauge wire that I had kicking around, a little black paint and Velcro straps
Really happy with how they turned out and I will probably make more as I get more organized
If anyone has suggestions to make them even better I'm interested....
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is offline
post #2702 of 2839 Old 10-02-2016, 02:59 PM
3rotor's Avatar
Liked: 3
Simple idea but very neat and tidy.
Excellent
Sent from my LG-H850 using Tapatalk
Waterboy77 likes this.
3rotor is offline
post #2703 of 2839 Old 10-03-2016, 12:04 AM
Jaurhead's Avatar
Quoted: 168 Post(s)
Liked: 120
This thread is great! Using a totally cheap option right now (it was only $5...) but would like to upgrade in the future. I have this tucked in a closet in the Fun Room.
Few things have changed since this photo, like moving the surge protector to the side of the rack instead of at the back, and adding the wireless router to one of the shelves. I need a power conditioner eventually...
WAY low tech compared everything else featured here...but us noobs usually pale in comparison while we're learning.
Mr. Pibb > Dr. Pepper > Everything Else
7.1.4 - Marantz SR6011 - LG B6 - HTD Level 3 - PSA S3000i
Oppo 203 - PS4 - Xbox One S - Roku Ultra
58 UHD and counting...
Jaurhead is offline
post #2704 of 2839 Old 10-03-2016, 11:46 AM
jjcook's Avatar
Quoted: 356 Post(s)
Liked: 150
I'm considering picking up my first rack (second hand) that is standard width of 19" but that is 23" deep instead of the usual 19". Any negatives in choosing a deeper rack besides footprint?
Σ Info: Δ 8.5' viewing distance AT screen fabrics comparison
Σ Builds:
Δ HT 2.0 renovation with acoustic coffered ceiling (in progress, 10% completed)
Δ Variable-aspect screen with motorized masking (on hold, have parts)
jjcook is offline
post #2705 of 2839 Old 10-03-2016, 01:04 PM
Quoted: 319 Post(s)
Liked: 54
My opinion: don't do it. I did it and it's the biggest PITA ever tying to reach stuff from the back. I hated having to do anything in that rack (even with the sides off). I was SO happy when I got rid of it.
Home Theater and Home Automation Enthusiast
MalevolentHamster is offline
post #2706 of 2839 Old 10-03-2016, 05:02 PM
bombertodd's Avatar
Quoted: 222 Post(s)
Liked: 134
Should be nice. 24 to 28 inches deep is ideal in my opinion.
Scylla likes this.
Klipsch RF-82II, RC-62II
2x Dayton Ultimax 12, Behringer iNUKE3000DSP
Denon 2113ci
New Theater Under Construction
bombertodd is offline
post #2707 of 2839 Old 10-03-2016, 05:15 PM
TMcG's Avatar
Quoted: 1181 Post(s)
Liked: 999
I would disagree with Hamster because most equipment of any scale will eat up all the depth a 19" rack has to offer very quickly. Add in the several inches for wire at the back plus a reasonable cable bending radius and 23" is really the minimum you should be considering....so I'd say jump on the deal.
TMcG is offline
post #2708 of 2839 Old 10-03-2016, 05:42 PM
3rotor's Avatar
Liked: 3
My rack is 23" deep. Means I can put stuff on both sides. Plus also my long server case fits etc..
The 19" is more than sufficient for most set ups. It all depends on what you think you'll need
3rotor is offline
post #2709 of 2839 Old 10-04-2016, 06:10 AM
rms8's Avatar
Quoted: 499 Post(s)
Liked: 326
GET IT !!!
But by the same token, don't discredit a 19" depth either. Just because someone else had a bad experience with a 19" depth does not mean they don't have their place.
My rack is 19" deep. I love it. It fits my space IDEALLY, which is key. Having a back ground in equipment install (several years in an E&I unit in USAF) helps with cramped quarters too.
All this is moot however since you have an opportunity to grab a 23" deep rack. My point is simply not to discredit one vs. the other unless the installed location is considered.
Good luck with the install !!!!
rms8 is offline
post #2710 of 2839 Old 10-05-2016, 02:14 PM
jjcook's Avatar
Quoted: 356 Post(s)
Liked: 150
Thanks for the feedback @MalevolentHamster @bombertodd @3rotor @rms8 -- I picked up the pair of 23" deep MA SRSR-X-20 slide out rotating racks for my ~26" deep closet with no rear access. I'll post pics when installed, though I doubt it will be as clean as @rms8 's
rms8 likes this.
Σ Builds:
jjcook is offline
post #2711 of 2839 Old 10-07-2016, 10:33 PM
Quoted: 21 Post(s)
Liked: 2
Originally Posted by auburnu008 View Post
Thanks! The racks are Middle Atlantic ERK-4420's. I hide the slack in the sides. There are about 2 inches on each side of the shelves that allow wiring to be hid.
Sorry if this has been asked here before, but is this for a home? If so, how could you possibly need that many networking cables? How is your network?
And third... If you don't mind me asking, what do you do for a living? That's inspiring.
Seeko is offline
post #2712 of 2839 Old 10-08-2016, 04:34 PM
dhendriksen's Avatar
Quoted: 25 Post(s)
Liked: 31
Show me your RACK
Here's a shot of the front of mine. It's across the hall from the theater. It's a DIY job and a rush one at that.
dhendriksen is offline
post #2713 of 2839 Old 10-09-2016, 09:32 AM
bombertodd's Avatar
Quoted: 222 Post(s)
Liked: 134
Obviously I'm not auburn008, but if you build a new home and you add Ethernet to every device that could need it TV's, appliances, wall jacks, IP cameras, and so on. It adds up real quick. I recall reading he is in real estate (someone correct me if I'm wrong).
If you haven't don so yet, check out his build thread. It is a great read. White Oaks Cinema House and Theater Build
Denon 2113ci
post #2714 of 2839 Old 10-11-2016, 08:51 PM
towercontrol's Avatar
Quoted: 13 Post(s)
23" deep rack
Ive got a full height 23" deep rack. It was definitely 3rd hand to me. Mine, in it's past life before me was an RCMP surveillance rack at one time. Ended up in one of the homes of the staff after it was retired, and then I got my hands on it. It's great having the extra space to mount to in the back. We all have converters boxes, or switches, or other electronic boxes that don't fit on the shelf or don't fit on the walls. This one fits it all no problem. Its worth it if you have the extra space.
jjcook likes this.
Tower Control; B&W, KEF, Onkyo, Pioneer, Sony, Toshiba and more A mix, But it works. !
towercontrol is offline
post #2715 of 2839 Old 10-11-2016, 09:05 PM
Quoted: 13 Post(s)
Originally Posted by rms8 View Post
GET IT !!!
Hey, I like set up you got there. What do you have for Equipment in there? I see some vertical units in the bottom and what looks like a pro guitar tuner in the middle?
Beautiful set up! Far fancier then mine.
post #2716 of 2839 Old 10-12-2016, 04:59 AM
rms8's Avatar
Quoted: 499 Post(s)
Liked: 326
I have a detailed list with embedded links to the equipment's web site in the first post of my build thread.
Thanks !!
rms8 is offline
post #2717 of 2839 Old 11-08-2016, 07:43 AM
hatlesschimp's Avatar
Quoted: 482 Post(s)
Liked: 507
Im renting lol
JudgeSmails and azz7686 like this.
hatlesschimp is offline
post #2718 of 2839 Old 11-10-2016, 05:57 PM
thrillcat's Avatar
Quoted: 212 Post(s)
Liked: 258
Just picked up a couple of these 16u racks with 3 shelves each for 130/each. Pretty pleased for the price.
My theater rack (pretty basic)
And my office rack, aka the rack of misfit av toys. I keep these decks around for loading footage into my edit system.
I love my iPhone, but it will never replace my turntable.
The Cinema 1858 Remodel Thread
thrillcat is offline
post #2719 of 2839 Old 11-22-2016, 10:46 AM
pdasterly's Avatar
Quoted: 169 Post(s)
Liked: 55
any pics of 2 post racks?
i dont have room for a full size rack, tried to search google but most people are using 4 post/ full size racks
pdasterly is offline
post #2720 of 2839 Old 11-22-2016, 11:05 AM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
The Middle Atlantic Slim5 is 20" deep. That is only slightly deeper than most standard receivers. How much room do you have to work with?
SMHarman likes this.
BllDo is offline
post #2721 of 2839 Old 11-22-2016, 01:12 PM
sbarnesvta's Avatar
Quoted: 17 Post(s)
Here is my current rack.
It is a basic AV/IT Rack. Network, 2 zone video system, 8 zone audio system with RTI and Crestron control (in the process of converting everything over to Crestron). This also seconds as my test/demo rack for programming so there is a ton of random stuff thrown in.
sbarnesvta is offline
post #2722 of 2839 Old 11-22-2016, 04:48 PM
pdasterly's Avatar
Quoted: 169 Post(s)
Liked: 55
room is 20x12x8, office/media room.
Was thinking 2 post rack and build small cabinet around it
post #2723 of 2839 Old 01-19-2017, 05:12 AM
Surfdrifter's Avatar
Quoted: 114 Post(s)
Liked: 54
I'm currently building my rack (a Middle Atlantic One) and I want to add on a 3U rackspace some wall switches to control the projector lift, the screen and some blackout blinds. Is there any specific blanking plate that has holes to accomodate those switches? I would prefer EU sized wall switches.
Any ideas?
Surfdrifter is offline
post #2724 of 2839 Old 01-19-2017, 05:20 AM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
Any ideas?
Maybe Middle Atlantic has something, in their modular UCP system?
http://www.middleatlantic.com/produc...el-system.aspx
If any of those switches are line voltage, you may want to consider surface mount boxes.
Surfdrifter likes this.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #2725 of 2839 Old 01-19-2017, 05:31 AM
SMHarman's Avatar
Quoted: 357 Post(s)
Liked: 118
Any ideas?
Can't you use relays in the controller instead of wall switches?
SMHarman is online now
post #2726 of 2839 Old 01-19-2017, 05:37 AM
Quoted: 114 Post(s)
Liked: 54
Ehhh... I could...probably? I don't know what these are. I'm looking though for a temp/cheap solution, since my blinds/screen/lift don't have any triggers, so I would I either have to install 4 triggers for the 4 devices in the future.
{DISCLAIMER: I'm a total noob regarding these relays and or wall switches.)
I will look into the relays, but other than that, is there a solution for what I asked? Thanks
EDIT: Just saw Neurorad's reply! Thank you!
post #2727 of 2839 Old 01-19-2017, 05:55 AM
Tedd's Avatar
Quoted: 1100 Post(s)
Liked: 422
You could actually cut openings in a blank panel. Tape off the faceplate, and use a jigsaw. Or you could
simply make your own panel.
Tedd is online now
post #2728 of 2839 Old 01-19-2017, 06:05 AM
Quoted: 114 Post(s)
Liked: 54
Yes, probably that is what I will do. Thank you!
post #2729 of 2839 Old 01-19-2017, 06:09 AM
Tedd's Avatar
Liked: 422
If those are line voltages and not low voltage relays, then you need to consider using armoured cable and suitable boxes behind the
face plate for safety.
bombertodd likes this.
Tedd is online now
post #2730 of 2839 Old 01-19-2017, 07:02 AM
SMHarman's Avatar
Quoted: 357 Post(s)
Liked: 118
Not sure how you are controlling all your devices. Multiple remotes, Creston, Control4, something in the middle?
You want to keep your own creations of High voltage outside the rack. Mess that up and you have a highly charged rack.
So, nearer the high voltage for the screen and anyway why not a 12/24v motor for the screen you have a relay to control the high voltage. It is triggered by a low voltage switch on the controlling hardware on the rack.
Even most AVR and projector have a 12v trigger that can do this job. Turn on the projector or AVR and the trigger sends a current to the relay to drop the screen.
