Jamis' theater thread! - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #331 of 963 Old 11-19-2008, 07:04 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Originally Posted by jamis View Post
Nerdy, perhaps... lazy, definitely.
Do you own damn index, slacker.
Can blame a guy for trying thougt you might get excited and run with it...
oman321 is offline
post #332 of 963 Old 11-19-2008, 07:08 AM
mn_hokie's Avatar
Liked: 27
I am double dog daring him to do it now!
Yea, that's right.. I said it...
mn_hokie is offline
post #333 of 963 Old 11-30-2008, 11:53 AM
will1383's Avatar
I would probably say an absolute minimum of 36" from the front edge of the bar to the wall. And even there, if you have more than 3 stools, and people sitting at the ends, the middle stools will probably be inaccessible.
That's exactly what I am doing.
will1383 is offline
post #334 of 963 Old 11-30-2008, 04:59 PM - Thread Starter
jamis's Avatar
So a few thoughts and upcoming projects...
1. I am thinking about ditching the large DVD storage shelf in the back of the theater for a large binder to store the DVDs and Blurays.
2. Instead of the shelf in back as mentioned previously, I am thinking of a low console or end-table type piece and a couple of club chairs with small ottomans for foot rests/additional seating. Basically make a small lounge/seating area in the back of the room.
3. I will be looking into some desk/piano lamp options for the bar. Due to a lack of lights directly overhead, we have found a need for some additional lighting at times.
4. I am still eventually going to invest in a few more acoustic panels and possibly some additional sound treatments behind the screen (linacoustic, bass traps, etc).
5. Under cabinet lighting for the kitchenette.
jamis is offline
post #335 of 963 Old 11-30-2008, 06:22 PM - Thread Starter
jamis's Avatar
To my last post above, can anyone suggest some lighting ideas for the bar?
Some basic requirements:
1. Reasonable size for both height and the base. I don't want these to obstruct the view of the screen. If I did a more traditional lamp style, I'd probably put them on the ends of the bar.
2. A clip-on style would be nice though not required.
3. Preferably black, antique bronze, brushed nickel/steel.
4. I'd probably buy 2-4 lamps, depending on size and style.
5. LED lights are OK as long as they aren't that cold bluish light so often associated with cheap LED lighting.
Some possible candidates:
Any ideas out there?
jamis is offline
post #336 of 963 Old 11-30-2008, 06:34 PM
kezug's Avatar
I can only recommend the lights that Greg used on his "Big Red Cinema Build"...here is a link to his pics and info on the lights themselves:
Big Red Cineme Build - Post showing his Littlite's
kezug is offline
post #337 of 963 Old 11-30-2008, 08:48 PM
mn_hokie's Avatar
Liked: 27
I like the last light or something more of a banker style. It's probably too late at this point, but some pendant lighting would have been sweet.
mn_hokie is offline
post #338 of 963 Old 11-30-2008, 09:00 PM
queendvd2's Avatar
Looking awesome Jamis. I actually like the second to last one, and even better if you could get in black.
queendvd2 is offline
post #339 of 963 Old 12-01-2008, 05:22 AM - Thread Starter
jamis's Avatar
Holy crap there are a lot of options on those lights. Unfortunately I wont have the finished look of the Big Red Cinema, but I can still mount them behind the counter and have the lights snake up from behind.
jamis is offline
post #340 of 963 Old 12-01-2008, 05:24 AM - Thread Starter
jamis's Avatar
Yeah... much too late. Plus the bay above the bar has the sewer pipes in there so my lighting options were (and are) VERY limited there.
We were saying how an extra set of can lights would have been perfect the other day.
jamis is offline
post #341 of 963 Old 12-01-2008, 05:25 AM - Thread Starter
jamis's Avatar
I'm thinking about going with the LittleLites that kezug linked to. Very similar.
jamis is offline
post #342 of 963 Old 12-01-2008, 05:54 AM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
If I'm looking at the LittleLites correctly it appears that Greg had mounted them directly to his counter top. I would think you could apply the same principal and mount them to either the side or the front (towards the screen side) of the bar and they would work better than the other lighting options. I would think you could purchase a length of the LittleLites that would fit your particular situation. I checked their site and there are several options you could work with. Check it out here. http://www.littlite.com/index.php
If you go with a more "traditional" option then I pick number two.
RTROSE
RTROSE is online now
post #343 of 963 Old 12-01-2008, 08:27 AM - Thread Starter
jamis's Avatar
I'm definitely thinking the Littlites...
I may go for the RWB (weighted base) and use them like desk lamps instead of mounting them to the bar (at least initially).
My biggest question is how to tie the Littlites into the outlet I use for my bar light which is on an incandescent dimmer (Grafik eye which can dim LV, though the rope light is incandescent). What kind of transformer(s) or other hardware would I need to let me use the same dimmer for the Littlites (of any type).
I sent the company an email, but haven't heard back yet.
jamis is offline
post #344 of 963 Old 12-01-2008, 11:23 AM
dyslexic's Avatar
I can't wait! My projector (the AE3000) was supposed to be here on Friday, but it looks like today or tomorrow. The store here oversold by 10 units, but I am #4 on the list so I'm all good. I'll be doing the 2.37 ...this build helped, thanks.
dyslexic is offline
post #345 of 963 Old 12-01-2008, 01:01 PM - Thread Starter
jamis's Avatar
I'm still loving my AE3000.... great picture and I absolutely love the zoom/focus memory feature.
Glad to be of service.
jamis is offline
post #346 of 963 Old 12-01-2008, 01:10 PM - Thread Starter
jamis's Avatar
So I went ahead and ordered four of these:
http://www.littlite.com/product.php?id=25
I will attempt to mount the base under the front lip of the bar and plug them into the same outlet as my under-bar rope light.
According to Littlite, you can't dim these as they use a switching power supply. They are checking to see if the 'fading' that I currently do with my rope light with the Grafik Eye will be a problem. If it is, I will change that zone to be off/on only which isn't a big deal since I always keep the bar/riser rope lights on high. I'll just lose out on the nifty fade on/off.
jamis is offline
post #347 of 963 Old 12-02-2008, 01:49 AM
VetteRacer's Avatar
Jamis, just a note.
We have a dozen or so of those around where I work, a few rack mount versions, a few custom setups, etc.. Just a word of caution, the aluminum around the bulb is a giant heat sink, have burned myself a few times on it.. So if kids are going to be sitting at the bar area I would think about getting something different...
They are great little lights though. And they do have dimable versions. One of the recent ones we got that has dimmer looks like the one you posted, not sure on model # though..
I wish California had more basements, seeing your theatre, and others on here, is making me want to do that so bad!
Matt
VetteRacer is offline
post #348 of 963 Old 12-02-2008, 03:25 AM - Thread Starter
jamis's Avatar
Originally Posted by VetteRacer View Post
Jamis, just a note.
Matt
Thanks for the heads up...
Thankfully no kids around here, though is worst comes to worst, I can dim them to try and cut down on the heat. This probably would have been a good reason to go with the low intensity ones though I was worried that they wouldn't be bright enough.
jamis is offline
post #349 of 963 Old 12-02-2008, 06:08 PM - Thread Starter
jamis's Avatar
Talk about fast shipping!
I got my 12" Littlites today and had a chance to install them! They are currently hooked into the riser rope light circuit, though if we decide to turn them off unless they are being used, I may put them on the same circuit as the Berklines since I had to do some creative work with the extension cord.
We decided we liked them best mounted under the lip of the counter. In retrospect, I kind of wish I got the 18" lamps but it's not worth changing at this point.
You can really see the browns in the bar counter with some direct light. Without the lights, it looks near black.
jamis is offline
post #350 of 963 Old 12-02-2008, 07:26 PM
queendvd2's Avatar
Wow, YOU are fast! Nice work. Looking great and yes, the lights really do bring out the color in the granite, which looked black in the previous pics.
post #351 of 963 Old 12-02-2008, 08:53 PM
mn_hokie's Avatar
Liked: 27
Wow, YOU are fast!
"That's what she said"
- Michael Scott, Dunder Mifflin
mn_hokie is offline
post #352 of 963 Old 12-02-2008, 08:57 PM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
jamis,
I heard a sonic boom today and looked up but there was not anything there. Guess I should have looked East to see what had made the boom. It was you installing your LittleLites! Slow down Man! Your killing me!
Actually I wanted to comment on how beautiful your counter top is absolutely awesome! The LittleLites were a great addition. Kudos.
RTROSE
post #353 of 963 Old 12-02-2008, 08:58 PM
mn_hokie's Avatar
Liked: 27
He told me he was jogging through the canyon with his top down.. hmmmmmmmmmmm
mn_hokie is offline
post #354 of 963 Old 12-02-2008, 09:00 PM
will1383's Avatar
Nice! Looks good. I gotta check out where you got those bar stools. They look real comfy.
will1383 is offline
post #355 of 963 Old 12-02-2008, 09:31 PM
queendvd2's Avatar
I suppose I walked right into that one!
post #356 of 963 Old 12-02-2008, 09:34 PM
mn_hokie's Avatar
Liked: 27
That's what she said!
DUDe?????? TWICE?!?!?!?!?!!?
mn_hokie is offline
post #357 of 963 Old 12-03-2008, 03:22 AM - Thread Starter
jamis's Avatar
I give credit to the seller of the Littlites... shipped same day and from NY which is 1 day to MA for UPS ground. I was not expecting to get the lights until later in the week, in all honesty.
I couldn't let such fast shipping go to waste. They were also very easy to install.
jamis is offline
post #358 of 963 Old 12-03-2008, 03:25 AM - Thread Starter
jamis's Avatar
http://www.allbarstools.com/Alston-4214-XV1103.html
jamis is offline
post #359 of 963 Old 12-03-2008, 05:31 AM
kezug's Avatar
Jamis,
I am so glad those littllites worked out for you...I cant believe from my posting on 12/1 that you had them installed yesterday....Wow.
They sure do look nice. If I ever plan on doing a back bar like yours, I am definetely referencing your build.
Job well done!
Doug
kezug is offline
post #360 of 963 Old 12-03-2008, 05:48 AM - Thread Starter
jamis's Avatar
Jamis,
Job well done!
Doug
And thanks for the link! I knew I had seen something like it before.. I just couldn't remember where.
On a side note... when the lights are dimmed, the hoods are only warm to the touch. On high, they do get very hot.
jamis is offline
