Jamis' theater thread! - Page 32 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #931 of 963 Old 10-09-2012, 03:19 PM
Spaces's Avatar
Hi, The theater looks great! Would you be interested in having it featured on the Youtube Channel SpacesTV?
I'm a researcher/producer for a new show on SpacesTV called Digital Architects. The show will consist of profiles of hobbyists/builders/designers/architects who use technology in creative ways to improve spaces. I think your theater would be a great fit. If you're interested feel free to contact me directly at billsilvaredd@gmail.com
Spaces is offline
post #932 of 963 Old 12-03-2012, 12:47 PM - Thread Starter
jamis's Avatar
UPDATE!!
With well over 4000 hours of use over 4 years, we are retiring the Panasonic AE3000 projector from active duty. The new Panasonic AE8000 should be arriving this week! The AE3000 may either go up on ebay/craigslist/videogon or be reserved for outdoor use come next summer.
(Sam Adams Octoberfest is currently on tap, though I've mostly just been drinking my stock of Founders Breakfast Stout).
jamis is offline
post #933 of 963 Old 12-03-2012, 03:30 PM
stitch1's Avatar
Quoted: 323 Post(s)
Liked: 265
Congrats, I'm interested in hearing your impressions of the 8000.
stitch1 is offline
post #934 of 963 Old 12-03-2012, 04:35 PM
mn_hokie's Avatar
mn_hokie is offline
post #935 of 963 Old 12-03-2012, 06:21 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Yea! He is back. I have been waiting an awful long time for a keg update. Thanks! Looking forward to seeing what your impressions are of the new PJ.
RTROSE
RTROSE is offline
post #936 of 963 Old 12-05-2012, 03:12 PM
kjlewie's Avatar
Quoted: 83 Post(s)
Liked: 109
Congrats on the new addition. Any early impressions?
Audio: Marantz AV7702mkII / Marantz MM8077 / Emotiva UPA-7 for 7.2.4 Atmos/DTS:X
Video: Sony VPL-VW600ES & SI Black Diamond 133" 2.35:1 CIH for 4K UHD
Sources: Oppo BDP-103D, Mede8er 600d with Synology ds716 NAS (28tb), PS4, DirecTV
7. Paradigm Studio 20 v5 (L, R, FW), CC-590 v5 (C), Sonance VP63 (SS); 2. DIYSG DA HO 18" (4); PSA S3000i (3); 4! Infinity Entra One (FH), Sonance VP65R (TR)
kjlewie is offline
post #937 of 963 Old 12-06-2012, 04:33 AM - Thread Starter
jamis's Avatar
It's coming today. Hopefully I can set it up tonight and have some feedback by the weekend. smile.gif
Anyone interested in a well loved AE3000 assuming the new addition is a keeper? biggrin.gif
jamis is offline
post #938 of 963 Old 12-06-2012, 02:13 PM
mn_hokie's Avatar
mn_hokie is offline
post #939 of 963 Old 12-06-2012, 06:32 PM - Thread Starter
jamis's Avatar
First indication is that this projector.... is AWESOME. Had a scare when the video would keep cutting out... turns out that it was either my cable box or receiver, and things were OK after unplugging and plugging each of them back in.
For now, I am using NORMAL mode with the lamp set for ECO. Besides turning up the sharpness a little, I have not adjusted any of the other color, contrast, or brightness settings.
As for the projector, compared to the AE3000, I can immediately say:
The good (so far):
  • It's much brighter, even in ECO mode. That said, I am comparing this to a bulb with 2300+ hours on it.
  • Excellent picture out of the box. Good color, good clarity...
  • Much deeper blacks. I put a bit of LoTR on and those dark scenes looked fantastic.
  • The Lens memory, oh yes, this is how it should have been from the start
    • It is MUCH faster when switching between saved settings.
    • Auto switch works perfectly (so far). I had it in 2.35 mode on a Bluray, switched to TV and it automatically adjusted to 16:9.
    • You can turn off the 'Processing' box for a much cleaner transition.
    • It will be interesting to see how the Batman movies are handled. That will be the true test. Between the increased speed and the lack of the processing dialog box popping up, I think it will be pretty good.
The neutral (so far):
  • The frame interpolation seems more aggressive. The AE3000 has three modes, OFF/MODE1/MODE2. We used OFF for video games, MODE1 for TV and movies, and MODE2 for sports. The AE8000 has OFF/MODE1/MODE2/MODE3 and MODE1 on the AE8000 is 'smoother' than MODE1 on the AE3000. It might take a little getting used to.
The bad (so far):
  • The frame adjust joystick kind of sucks. I much prefer the two dials (vertical and horizontal) on the AE3000 which were much more precise.
  • The lens of the projector is offset to the side instead of centered like the AE3000. I had to do some creative adjustments to my universal mount to get it as close to centered as possible so I wouldn't have to unbolt the top ceiling mounted plate. It's not perfectly centered, but I would say that it's 'good enough'.
  • Upgraditis is probably going to set in soon, requiring me to upgrade the Bluray player and/or receiver to models that support 3D. At the very least, I will need to run a high speed HDMI cable to the projector (thankfully I have my conduit) which I have already purchased.
fgsouza likes this.
jamis is offline
post #940 of 963 Old 12-06-2012, 08:55 PM
kjlewie's Avatar
Quoted: 83 Post(s)
Liked: 109
Thanks for that summary. Is the 8000 supposed to auto switch ratios during a movie? If so, then the batman testing will be interesting indeed.
kjlewie is offline
post #941 of 963 Old 12-07-2012, 04:11 AM - Thread Starter
jamis's Avatar
It's supposed to change whenever it detects a format change. You basically assign a lens memory to when the projector detects something in 16:9 and another for 2.35:1.
jamis is offline
post #942 of 963 Old 12-10-2012, 05:58 AM - Thread Starter
jamis's Avatar
Did some more adjustments this weekend (mostly to get the alignment better), watched a couple of blurays (Abe Lincoln: Vampire Hunter, Fellowship of the Ring Extended Edition) , and some HDTV.
I am definitely impressed with this projector. The picture quality is fantastic out of the box to me.
I continue to be impressed with the lens memory speed and auto switching, though it can get a little annoying while watching TV and having it zooming in and out when movie trailers or matted commercials come on. It usually takes 5-10 seconds for the projector to detect the aspect change, so it's really the delay that gets me. The switch is quite fast, however.
My only wish is that the MODE1 frame interpolation was less aggressive (more similar to the MODE1 on the AE3000). I loved the motion of MODE1 on the old AE3000; just enough smoothing to take some of the jitter out, but absolutely no 'soap opera' effect at all... but it's just a bit too much for me on the AE8000. I'll probably never use MODE2 or 3 on this projector.
jamis is offline
post #943 of 963 Old 12-10-2012, 11:17 AM
HMenke's Avatar
Liked: 54
Originally Posted by jamis View Post
[*] Upgraditis is probably going to set in soon, requiring me to upgrade the Bluray player and/or receiver to models that support 3D. At the very least, I will need to run a high speed HDMI cable to the projector (thankfully I have my conduit) which I have already purchased.
[/LIST]
I know the feeling. Ordered in a Panny DMP-BDT310 for 3D because of the dual HDMI outputs. Lets you keep your non-3D compliant AVR for audio (send HDMI audio to receiver and send HDMI video to the 8000 over a second HDMI cable).
HMenke is offline
post #944 of 963 Old 12-10-2012, 11:19 AM
HMenke's Avatar
Liked: 54
Might have to just keep the auto lens feature disabled as a general rule, and only engage it for movies with mixed aspect ratio content like The Dark Knight.
HMenke is offline
post #945 of 963 Old 12-10-2012, 12:09 PM
carboranadum's Avatar
Quoted: 22 Post(s)
Liked: 26
Oh, I watched that this weekend with my Panny 4000 and 142" 2.39 screen. The projector kept shifting back and forth! I got so darn mad that I turned it off and left it on 16:9. I'll never watch something like that again!
carboranadum is offline
post #946 of 963 Old 12-10-2012, 12:15 PM
tony123's Avatar
Liked: 38
I've had that feature turned off on my 4000 for the last 2 years. It's got a cool factor, but reality is that the transition takes longer than most of the scenes (i.e. batman, commercials).
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #947 of 963 Old 12-10-2012, 12:29 PM
HMenke's Avatar
Liked: 54
One concern I would have is wearing out the auto lens mechanism...I would rather use it sparingly and have it available when I really need it.
HMenke is offline
post #948 of 963 Old 12-11-2012, 06:00 AM - Thread Starter
jamis's Avatar
Yeah, wearing it out would be my primary concern at this point.
The switch between aspect ratios itself (not counting the delay for detection) seems like it takes less than 2 seconds total to zoom and focus. It's VERY fast compared to the AE3000.
My in-laws didn't even notice it happen when we put on LoTR this weekend. Whereas with the AE3000, it's almost a feature watching the screen zoom to fill the screen (kind of like when I dim the lights by remote at the beginning and then gently raise them when the credits come on). smile.gif
jamis is offline
post #949 of 963 Old 12-11-2012, 06:07 AM
tony123's Avatar
Liked: 38
Glad to hear they made it faster!
Construction Thread
tony123 is offline
post #950 of 963 Old 12-11-2012, 06:14 AM
HMenke's Avatar
Liked: 54
True! I also had a 3000. The other "process" occurred when saving a lens setting. The 8000 just saves the setting and doesn't go through the physical process like the 3000 would do.
HMenke is offline
post #951 of 963 Old 12-11-2012, 06:40 AM
amb1s1's Avatar
What is your 1/2 bath dimensions?
amb1s1 is offline
post #952 of 963 Old 12-11-2012, 09:31 AM - Thread Starter
jamis's Avatar
Inside dimensions are approximately 5' x 5'6"
jamis is offline
post #953 of 963 Old 04-04-2013, 05:22 AM - Thread Starter
jamis's Avatar
Update:
Retired the Denon 3808ci receiver and Sony N460 bluray player.
New additions include a Pioneer SC-1522-K 9.2 receiver and Sony S5100 bluray. Costco is currently selling this receiver at an amazing price. I also ran a new HDMI 1.4 cable from the closet to the projector. Score one for the 2.5" PVC conduit!
My transition to 3D support is complete. Not that I have any 3D media yet. My two free pairs of glasses arrived several weeks ago from Panasonic (mail in rebate with the AE8000).
Keg update: Weihenstephaner Original is currently on tap, though I've been stocking up on Founder's Breakfast Stout in bottles as well as other good stouts (mostly imperials).
jamis is offline
post #954 of 963 Old 04-04-2013, 05:58 AM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Ah the prodigal son returns! Glad to see your still around these here parts. Nice score on the receiver. I am not a Cosco member (Sam's here locally) but even I was aware of the stellar deal on the Pioneer.
Good to hear from you, and get a keg update to boot.
Take care, and don't be such a stranger!
RTROSE
RTROSE is offline
post #955 of 963 Old 04-04-2013, 06:33 AM - Thread Starter
jamis's Avatar
RTROSE
The deal was good enough that I signed up just to get the receiver.
More than likely, I'll never make it back to a Costco this year.
jamis is offline
post #956 of 963 Old 04-04-2013, 08:49 AM
Schlemstar's Avatar
Quoted: 28 Post(s)
Liked: 24
Jamis,
Can you give me the specifics on your LED rope lighting, if you like it, and how the Grafik Eye handles it?
I am looking at OrangeTreeTrade's soft white LED rope, and I have a GRX-3106. I will have two 18-foot strands on one zone, and a 10 foot on another zone, and I want to make sure that will be enough load to dim properly with the GE.
-Schlemstar
Schlemstar is offline
post #957 of 963 Old 04-04-2013, 01:28 PM - Thread Starter
jamis's Avatar
Originally Posted by Schlemstar View Post
Jamis,
-Schlemstar
It's actually not LED rope... it's 1/2" incandescent which means the graphik eye handles it perfectly. smile.gif
jamis is offline
post #958 of 963 Old 11-18-2013, 05:33 AM - Thread Starter
jamis's Avatar
Stumbled across a PS4 while out shopping this weekend, so I bought it. Going to have to wait to get the PS4 eye camera since they don't have an extension cable for it and it's a proprietary port (unless I want to do some cable surgery).
Also, finally got a chance to check out the PT8000's 3D functionality and I would say that it's decidedly mixed. With some tweaking (dynamic, normal lamp mode), it was watchable but still very dim compared to normal viewing. I probably won't go out of my way to get 3D vs. 2D media.
My plan for this winter is to rebuild my media rack. I'd like to get some new rails (cage nuts instead of pre-tapped holes) and update my custom shelves.
Keg update: Ommegang Abbey Ale, though I will be ordering something new this week.
jamis is offline
post #959 of 963 Old 09-11-2014, 08:19 PM
Gnaw em Gophs's Avatar
$40 for a diamond skil saw blade, 3/4" and 1/2" grey PVC conduit, PVC cement, 40lbs of quickcrete, a cold chisel...
A few hours and some sore knuckles later... future electric and LFE hookups for the riser. A jackhammer would have gone much quicker than the chisel and 3lb sledge, but the rental place was closing soon and I was too impatient to wait a day. I also saved $90. A local cutting company wanted $600 (ha!).
All in all, it went fairly well. I made three cuts with the skil saw (one on each side and one down the middle), and just went to town with the chisel. I kept the area wet as I cut and the shop vac nozzle inches from the saw.
Bringing this great thread back from the dead. Jamis, just read through your entire build (yep). Great looking room. I have almost the exact same dimensions (a godsend to find your thread) except my kitchen area will be off the back wall backwards rather than to the side. I am looking to do the same thing as above for electrical for the riser. Any tips you can remember (if you're still on AVS)? What sch pvc? thwn wiring? buttkicker wiring? Thanks
Gnaw em Gophs is offline
post #960 of 963 Old 05-06-2015, 05:58 AM - Thread Starter
jamis's Avatar
Very infrequent visits these days.... still enjoying the theater though! I find the less I visit AVS, the less upgraditis sets in.
I just ran typical grey PVC (making sure to cement the joints/bends). I believe it was 3/4" for the electrical and 1/2" for the butt kicker wiring. I ran two wires (front and back row) for the butt kickers, and two wires for the electrical (one for the lighting running to two outlets fromthe grafikeye, and one for the general purpose outlets).
This pic kind of shows how it all branches out into the riser.
jamis is offline
