Wall mountable stereo cabinet? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-01-2007, 04:07 PM - Thread Starter
John_Galt's Avatar
Does anyone know of any component cabinets I could buy that could be mounted to the walls in the corner of my room? I am looking for something wood based that I could paint so that it would match the rest of the room. My sub is going to be right under the components so a floor standing unit isn't an option. Any ideas?
John_Galt is offline
post #2 of 5 Old 02-01-2007, 06:52 PM
Quoted: 3256 Post(s)
Liked: 2743
http://www.ikea.com/webapp/wcs/store...umber=00045560
Although if my math is correct each cubbie is too small for standard AV gear.
post #3 of 5 Old 02-02-2007, 07:08 AM
sivartk's Avatar
Even hung horizontally, you would probably only have about 16" width per "cubbie." I think most of my equipment is about 18-20" wide.
At no point in your rambling, incoherent post were you even close to anything that could be considered a rational thought. Everyone in this forum is now dumber for having read it.
My Little Theater
sivartk is online now
post #4 of 5 Old 02-02-2007, 09:39 AM
Monty Williams's Avatar
It's not made of wood, and I don't know if Middle Atlantic's wood side panels work with it, but MA does offer a wall mounted 19" equipment rack:
http://www.middleatlantic.com/enclosure/wall/dwr.htm
Monty Williams is offline
post #5 of 5 Old 02-02-2007, 11:36 AM
Skippard's Avatar
Not wood but it is a wall mounted rack that makes your components appear to float.
http://www.peerlessindustries.com/dy...categoryID/196
I have seen this rack much cheaper at other online vendos. The above link is the manufacturer's site.
I just ordered 3 of these for use at work next to wall mounted Plasmas (VTC Conf rooms)
Skipp
Skippard is offline
