Show me your wood columns/pillars! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #91 of 98 Old 02-26-2015, 10:40 PM
JohnstownFlood's Avatar
Quoted: 185 Post(s)
Liked: 141
Regarding columns, is there strong reasoning behind not framing it out with 2x2s and 2x4 and covering with Sheetrock? I can see the advantages of using MDF, especially in terms of mass, but I'm just not familiar enough with using it. Thanks!
Brian Fineberg likes this.
JohnstownFlood is offline
post #92 of 98 Old 03-01-2015, 05:52 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
Should columns be build before or after drywall? Note: my room is not isolated soundproofed
Brian Fineberg is offline
post #93 of 98 Old 03-01-2015, 06:38 AM
KanosWRX's Avatar
Quoted: 175 Post(s)
Liked: 53
If its not sound proofed you could build it before. If it is, the recommendation is after.
KanosWRX is offline
post #94 of 98 Old 03-01-2015, 08:54 AM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
Why use Sheetrock? Frame it, stuff with insulation and use fabric would be an alternative. Access to speakers, hiding wire etc would allow for simple, easy access by using fabric to cover columns.
Why not look for 4 X 8 sheets of veneered hardwood plywood? If you are patient, can find extreme values depending on wood products market...........besides, wood looks so much better than MDF and is much easier to work with. Working with MDF is brutal!
Yes, you could cover with Sheetrock, and it's been done..............
doublewing11 is offline
post #95 of 98 Old 03-01-2015, 02:02 PM
Quoted: 185 Post(s)
Liked: 141
Thank you for the reply. No fabric because I'm looking to copy the Rawlinsway theater, and with a 2-year old running around I need them to be sturdy!
I think I'm finally catching the hint that MDF is just not worth it for something like this. I just need to get off of my butt and head to the wood shop to start mocking this up.
post #96 of 98 Old 03-01-2015, 02:38 PM
Quoted: 229 Post(s)
Liked: 938
Good call! I'm not a fan of MDF.........after a few years, scuff marks and other issues show up.
3/4" Hardwood species of your choice plywood works great!
post #97 of 98 Old 04-09-2015, 11:28 AM
ROB_IN_MN's Avatar
this old thread that was recently bumped has some nice details on column construction.
Speaker in Column Plans?
ROB_IN_MN is offline
post #98 of 98 Old 02-09-2016, 07:17 PM
kmhvball's Avatar
Quoted: 496 Post(s)
Liked: 275
Here are some photo's of my columns... They are fairly shallow a little less than 5" deep, and contain my "In Wall" speakers.
I extended the front edges past the sides, and put some 1/4" round on the back of the front, and then installed LED lighting behind the edge of the columns.
LED Lights are controlled in 4 'sets' of columns, color, brightness, on/off, can all be done differently.
kmhvball is online now
