Acoustic Properties of Thick Velvet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-11-2007, 06:06 AM - Thread Starter
500hp's Avatar
I am finishing the tape and mud of my HT. Currently I am thinking through acoustic treatments for the room.
I know where & how most recommend acoustic treatments with linacoustic, bass traps, first reflections, etc. My question however has a slight twist....
Rather than using acoustic panels wrapped in acoustically transparent material up to ear height on the side walls, I am considering hollow panels wrapped in HEAVY velvet material. This material did not pass the "blown air" test. I am assuming this will perform well for the absoption of highs and mids and I would still need to address the bass traps seperately.
Why am I considering this? I have a sliding glass door in the rear of the room that has this velvet as a curtain with black-out cloth sewn onto it. I would like to maintain the use of it throughout the room rather than a GOM selection that might not maintain the same look.
Thoughts?
Thanks in advance.
500hp is offline
post #2 of 9 Old 02-11-2007, 06:59 AM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 43
I don't think the velvet will allow for enough absorption of high frequencies.
My Theater Room JVC RS4910, Panamorph UH480, 148 in. 2.40:1 Dalite HD Pro 1.3, Klipsch THX Ultra II's x 7, Quad JTR Captivator S1 subs
My Previous Non-Dedicated space
RobZ is offline
post #3 of 9 Old 02-11-2007, 07:25 AM - Thread Starter
500hp's Avatar
That's a response I expected which leads to this question which has me perplexed..and ultimately might contradict my opening statement that I understand what I am talking about
If the velvet won't absorb the highs but acoustic panels can be wrapped in acoustically transparent material, then the non-acoustically transparent material (velvet in this example) must be doing something? Otherwise, there wouldn't be an SOP for wrapping panels (or whatever) in something like GOM. No?
500hp is offline
post #4 of 9 Old 02-11-2007, 08:00 AM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 43
It may reflect highs as well as allowing some to pass thru.
RobZ is offline
post #5 of 9 Old 02-11-2007, 08:05 AM - Thread Starter
500hp's Avatar
If I understand correctly, the undesirable behavior of this velvet would be the reflection of highs. So...if I wrapped acoustic panels with it, instead of GOM by example, I could still suffer from those reflected highs?
500hp is offline
post #6 of 9 Old 02-11-2007, 08:19 AM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 43
It would likely not be as effective as GOM, cotton, etc.
RobZ is offline
post #7 of 9 Old 02-11-2007, 08:32 AM
Terry Montlick's Avatar
Location: State of Rhode Island and Providence Plantations
There are exactly three possibilities for sound energy interacting with a particular object: reflection, absorption, and transmission. Note that diffusion can be considered simply a special case of reflection and/or transmission.
The standard "reverberation room" method for measuring absorption coefficients gives you sound absorption only. It cannot distinguish between sound which is reflected from the material and sound which passes right through it. This sound is 1 minus the absorption coefficient. That is, if the absorption coefficient (energy which is absorbed) over a particular frequency range is 0.35, then 0.65 of the sound energy is being reflected, transmitted, or some combination of the two.
Here are absorption coefficients for 18 ounce (the really heavy stuff!) velour, hung flat with no folds or draping, measured at octave bands from 125 Hz to 4 kHz. Source is the book "Acoustics" by Leo Beranek, McGraw-Hill. 1954.
0.05 0.12 0.35 0.48 0.38 0.36
- Terry
Terry Montlick Laboratories
Home Theater Acoustics
Critical Listening Rooms
Design, Evaluation, Alpha Certification®
www.tmlaboratories.com
Terry Montlick is offline
post #8 of 9 Old 02-11-2007, 08:43 AM - Thread Starter
500hp's Avatar
- Terry
Thanks Terry....that is exactly what I needed.
500hp is offline
post #9 of 9 Old 10-28-2013, 10:43 AM
KJ McC's Avatar
Hi there!
I would love to know if you decided to use the velour, and if so what the outcome was?
KJ McC is offline
