Best way to run speaker wire through a wall? - AVS Forum
post #1 of 5 Old 02-11-2007, 08:48 PM - Thread Starter
Nuclear Waste's Avatar
When running a speaker wire from one side of drywall to the other, what is the best way to do it?
Seems to me that using a connector of some sort would be a bad idea-- the less connections, the better, right? But a wire sticking out of the wall seems odd, too.
Nuclear Waste is offline
post #2 of 5 Old 02-12-2007, 05:53 AM
greg_mitch's Avatar
why not just use a binding post wall plate like....partsexpress
greg_mitch is offline
post #3 of 5 Old 02-12-2007, 05:55 AM
Quoted: 109 Post(s)
Liked: 508
You can also get a blank face plate for an inwall electrical box and cut a hole in the plate just the right size for the wire to stick out and minimize any extra connections.
post #4 of 5 Old 02-12-2007, 05:57 AM
judsonp's Avatar
I guess it depends on what your trying to accomplish.
Will the speaker wire be hidden behind a speaker or will it be out in the open?
You could take a low voltage box and a regular plate and run the wire straight through that way.
If it is in plain sight I would probably just break the wire and put a nice connection on it.
judsonp is offline
post #5 of 5 Old 02-12-2007, 08:17 AM
Winkelmann's Avatar
Mine drops from the ceiling (via 2" conduit) into the AV room.
Please visit The Cuban Underground
Winkelmann is offline
User Tag List
