my front inwall speakers too close to wall?... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 39 Old 02-28-2007, 07:59 PM - Thread Starter
bwhitmore's Avatar
are my left and right speakers too close to the wall?...
they are Triad Silver inwalls
there is about 112" between them to accomodate a screen
i plan on using acoustic treatments on the side walls for sure to help
it wouldnt be too tough to move the speaker in around 6" from the wall on each side if needed
thanks
brad
bwhitmore is offline
post #2 of 39 Old 02-28-2007, 08:01 PM - Thread Starter
bwhitmore's Avatar
here is another pic...the side walls i'm speaking of are two rooms located in the front of the theater....the room does open up more in the back
post #3 of 39 Old 02-28-2007, 09:10 PM
Anthony A.'s Avatar
i think they are too close to the wall and you should move them closer together as much as you can. if you leave them as is, i can guarantee you that you will regret it later. push them closer together!!!
Anthony A. is offline
post #4 of 39 Old 03-01-2007, 07:11 AM - Thread Starter
bwhitmore's Avatar
i have included a crude drawing of my entire basement....i am somewhat limited by the design on what i can do with the front three speakers
i do think moving the left and right in about 6" is probably a good idea...
thanks again!
post #5 of 39 Old 03-01-2007, 07:28 AM
mmoeller's Avatar
I would consider building a screen wall out a couple of feet and using a Acoustic Transparent screen, and placing the speakers behind it. You do not seem to be lacking in depth of the room. The 6" doesn't seem like enough to remove the corner effects. You'll be able to have a wider screen too, and you'll also be able to place center right behind the screen.
Look up the SMX screen material the Ruben is helping everyone with. Very inexpensive.
mmoeller is offline
post #6 of 39 Old 03-01-2007, 09:27 AM - Thread Starter
bwhitmore's Avatar
i suppose this is still an option for me (building out the wall) but i had kind of decided i didn't want to do my center behind the screen for fear that i would give up some video quality for the convienance of not seeing a center speaker...to me, thats just not worth it
but maybe i was mis-informed...are the newer acoustic transparent screens that good?
post #7 of 39 Old 03-01-2007, 09:45 AM
phisch's Avatar
Quoted: 58 Post(s)
Liked: 41
Before modifying your design, I would suggest you contact the manufacturer of the speakers that you are using and get their opnion. Some speaker designs can be placed quite close to the wall.
phisch is offline
post #8 of 39 Old 03-01-2007, 11:39 AM - Thread Starter
bwhitmore's Avatar
hey mike
that's great advice
i sent a note off to Paul Scarpelli from Triad on this very subject...i'm sure he will get back to me soon
post #9 of 39 Old 03-01-2007, 01:41 PM
mdputnam's Avatar
If you can't move them I would angel them inward. You could frame out your corners then cover the frame with drywall and insert your in-wall speakers in the newly chamfered corner.
Human perception is not a direct consequence of reality, but rather an act of imagination. - Michael Faraday
mdputnam is offline
post #10 of 39 Old 03-01-2007, 04:02 PM
Paul Scarpelli's Avatar
Liked: 54
I responded in a post here yesterday, but I sure don't see it.
Yes, the left and right are too close to the wall. Not only will you have a smear from the first reflections, but the left and right speakers will act like horns in those corners, and you'll have an elevated frequency response in the bass and lower midrange. If you can move them in 6", that will help a great deal, but you'll need fairly thick acoustical padding to kill first reflections.
Angling them in is not an option because the speaker mounts flush to the wall, and it needs the full 4" stud depth.
What I would have done is have all three speakers at the same height (tweeters at 40" - 44" off the floor), firing through an acoustically transparent screen, with the left and right also behind the screen, and 18" from the side walls. That's the right way to do it.
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
post #11 of 39 Old 03-01-2007, 09:09 PM - Thread Starter
bwhitmore's Avatar
Paul
i think i will revisit the acoustic screen option...it will be really easy for me to move the left and right speakers in and get them 18" from the wall
any recomendations on screens to match up with the Triads?
thanks again
brad
post #12 of 39 Old 03-01-2007, 09:15 PM
westcott's Avatar
I agree. In wall speakers are a severe compromise and impossible to setup properly because one can not test their performance and how they will interact with the room.
westcott is offline
post #13 of 39 Old 03-02-2007, 06:10 AM
Liked: 54
Originally Posted by bwhitmore View Post
Paul
thanks again
brad
I've been a fan of Stewart Filmscreen for years, but I use Screen Research in my theater. It's not perforated; it's a weave. Pixels on top of perforations can produce artifacts. Expect to pay a lot for a Screen Research screen, but expect unadulterated audio and a superb picture.
Paul Scarpelli
aka TRIAD DUDE
post #14 of 39 Old 03-02-2007, 08:11 AM - Thread Starter
bwhitmore's Avatar
hey Paul
i will check out both screen companies
it's so nice to have a guy like you that works "in the business" at our disposal here on the forums...i hope you know it's much appreciated
thanks again
brad
post #15 of 39 Old 03-02-2007, 08:28 AM
mmoeller's Avatar
hey Paul
thanks again
brad
Good idea Brad. Be an informed consumer. That Stewart screen will be $$$. The SMX material is also not "perforated" its a weave. Not to seem like too much of a fan boy, the SMX stuff just is sooo much more affordable. If your a DIY'r type, I'd give it a whirl.
It also depends greatly on your seating distance. The closer you are the more you might see the openings in the weave. Just have to make sure your seating distances are ok. I forget the estimation for distance 1-1.5x screen width or is it diagonal. eh... something like that anyway.
I'm sure you'll see alot of testamonials about the SMX screen here.
mmoeller is offline
post #16 of 39 Old 03-02-2007, 08:46 AM - Thread Starter
bwhitmore's Avatar
i think i will look into the SMX...i am a bit of a DIY'r so it might be a great option...i seem to remember that when i looked into acoustic trans screens in the past they were $3000-$5000...not sure what the SMX will cost but it might be worth a try
my seating distance will be about 15' from the screen
post #17 of 39 Old 03-02-2007, 10:46 AM
Liked: 54
I can see the weave on my Screen Research screen if I'm about 6' away, but I never sit that close unless I want Nemo to scare the crapola outta me...
BTW, there are hardly any manufacturers left on this forum. I think they may have been chased off either by a rough crowd, or because they were shameless shills. I'm just a hobbyist like the rest of you, and I won't promote my brand unless someone asks about it, and even then, not at the expense of our (grossly inferior!) rivals.
Paul Scarpelli
aka TRIAD DUDE
post #18 of 39 Old 03-02-2007, 11:39 AM - Thread Starter
bwhitmore's Avatar
well, all i know is i read great things in a lot of places about TRIAD, but having your help really pushed me over the edge to pull the trigger on a full TRIAD system
now, hopefully it will sound good...
post #19 of 39 Old 03-02-2007, 01:02 PM
Liked: 54
As long as your left and right fronts aren't stuffed into the corners, it will sound excellent. Let me know how things progress. Thanks for the great suggestions and comments from my Forum Bruthahs, too.
Paul Scarpelli
aka TRIAD DUDE
post #20 of 39 Old 03-04-2007, 03:34 PM - Thread Starter
bwhitmore's Avatar
well, it looks like i'm gonna go with an acoustically transparent screen
i am in the process of moving those left and right speakers in and moving the center up...
a 110" screen is about 99" wide
if i do the speakers 32" apart (on center) will that be OK?...this way all three speakers would be about 80" total left to right
or should i space them out a bit more to get to around 90" total?...i can do this but it will involve some more framing...if you look at my pics you'll see what i mean....i hope...
post #21 of 39 Old 03-04-2007, 04:15 PM
westcott's Avatar
Move them around until you get a flat frequency response. A cheap SPL meter will get you close. Measurement obviously should be from the final seating position which, as a general rule, should be about two thirds of the room length.
westcott is offline
post #22 of 39 Old 03-04-2007, 04:24 PM - Thread Starter
bwhitmore's Avatar
i can't really do that as i'm going with TRIAD inwalls and this is all new construction...
maybe i need to decide exactly what screen i'm going with (or at least what size) and add the speakers accordingly...??
i guess my main question is if i put them on 32" centers will this now be too close together?...if i do spread them out it wont be by much (maybe 6" further apart?)because i have to fit them behind that screen that is about 99" wide
post #23 of 39 Old 03-04-2007, 07:46 PM - Thread Starter
bwhitmore's Avatar
here's the newest pic with the adjustments i made today...
there is now 36" from the left and right speakers to each side wall
there is 18" between each speaker
all three speakers total about 78"
(the length of the wall is 12' 6" total)
a 100" screen is 90" wide
a 110" screen is 99" wide
again, if i have to i can do some framing adjustments and move them out a bit more...maybe now they're too close!?...
post #24 of 39 Old 03-04-2007, 08:07 PM
ed_robyn's Avatar
Can you share what screen you ended up with and the approx price?
ed_robyn is offline
post #25 of 39 Old 03-05-2007, 06:43 AM - Thread Starter
bwhitmore's Avatar
i haven't decided yet...
i need to speak to my HT guy and do some more research, but i think the good acoustically transparent screens can get pretty pricey
i guess it will also depend on which FP i go with...
post #26 of 39 Old 03-05-2007, 07:00 AM
Liked: 54
Don't discount the importance of a good screen. My screen retails for double what my projector retails, but it enables me to place the front speakers correctly.
Paul Scarpelli
aka TRIAD DUDE
post #27 of 39 Old 03-05-2007, 07:06 AM - Thread Starter
bwhitmore's Avatar
hey Paul
so what do you think of the speaker placement now?...
will this work for just about any screen i decide to go with?...
thanks again
brad
post #28 of 39 Old 03-05-2007, 07:10 AM
Liked: 54
Looking at your picture again, you should have moved the left and right brackets into the adjacent stud spaces. From your description, you moved them over TWO spaces. They will be too close together, although it will work better than your original placement next to the wall.
Paul Scarpelli
aka TRIAD DUDE
post #29 of 39 Old 03-05-2007, 07:15 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
It's easy to be magnanimous when the forum is full of satisfied customers that spread the word for you. Take a job with Bose, come back here, then we'll see if your attitude changes.
CPanther95 is offline
post #30 of 39 Old 03-05-2007, 07:19 AM - Thread Starter
bwhitmore's Avatar
i originally was going to move them over one space...but if i do that the total of all three speakers will be approx 110"
from looking around it seems that a 100" diag screen is 90" wide and a 110" is 99" wide
see what i mean?...maybe i should move the left and right out about 6"-8" each and just plan on going with a 110" screen (or larger)
this would make my three speaker total about 90"-94"
