*free* software to help determine your first reflection points - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #241 of 253 Old 11-21-2012, 07:52 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Is this dead?
NicksHitachi is offline
post #242 of 253 Old 11-21-2012, 08:24 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
define dead.
Gary J is offline
post #243 of 253 Old 11-21-2012, 09:07 AM
Quoted: 182 Post(s)
Liked: 189
Hi Gary,
Can one still acquire the software?
post #244 of 253 Old 11-21-2012, 09:16 AM
Willie's Avatar
Quoted: 75 Post(s)
Liked: 106
See post #215
Willie is offline
post #245 of 253 Old 11-24-2012, 05:48 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Originally Posted by 1 Infinite Loop View Post
Too bad this doesn't work any more.
Tried to run the DirectX patch, no luck.
Should have been written for the Mac. That way it would actually work.
Originally Posted by MitchSchaft View Post
I got it to work by right clicking on first102.exe, going to the compatability tab and choosing windows2000. Now it loads up fine for some reason. Wish the author didnt fall off the map
I'm running XP sp3.
I'm trying to get the 1.02c version to run on my computer, I kept getting this error "missing D3DX9_32.DLL", so afte reading here
http://pcsupport.about.com/od/fixtheproblem/ht/restoredx9dll.htm
downloading the below now.
http://www.microsoft.com/en-us/download/details.aspx?id=10990
The December 2006 SDK includes D3DX9_32.DLL. This DLL includes the Direct3D 10 HLSL compiler enabled for Direct3D 9 targets (shader models 2.0 and later). The new compiler has no support for 1.x pixel shader targets. This new compiler is the default for Direct3D 9. As a result, all developers are encouraged to author their shaders in HLSL and use shader models 2.0 and higher. The legacy compiler is available using the /LD switch.
mtbdudex is offline
post #246 of 253 Old 11-24-2012, 06:07 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
UPDATE!
The above works, and I'm doing this on my iMac27" under VMWARE emulation running WinXP!
I'm using it for my front height speakers now......
download software via post 215
Originally Posted by reaper View Post
Huh? I downloaded the .rar from that web page you just posted... no problem.
frv1.02.rar.zip 172k .zip file
mtbdudex is offline
post #247 of 253 Old 12-30-2013, 01:38 PM
Schuyler Bain's Avatar
Quoted: 33 Post(s)
Does each cube represent 1 square foot? it appears that it does, but I entered the height of my front L/R at 36in from ground (plus speaker height 10") and it graphs them at about 30 - 40" in height from ground against the front wall - according to the cubed grid. I would think the L/R's would show 36-46" precisely against the front wall grid
My room height is 6.5ft.....not sure if that's throwing it off a little.
Just want to be sure that the height of the refection points on the side walls are an accurate representation. Thanks
Schuyler Bain is offline
post #248 of 253 Old 01-07-2014, 09:55 AM
Al Evenson's Avatar
Just DL and clicked on the app. Works perfect in Win7 64bit. Thanks a million.
dRwOOD73 likes this.
Al Evenson is offline
post #249 of 253 Old 07-26-2014, 04:34 PM
Terrell78's Avatar
Quoted: 25 Post(s)
The download links are dead, does anyone still have the zip or rar file to share?
Terrell78 is offline
post #250 of 253 Old 07-26-2014, 04:44 PM
MitchSchaft's Avatar
There's a link a few posts back that works.
MitchSchaft is offline
post #251 of 253 Old 07-10-2015, 09:31 AM
Gary Lightfoot's Avatar
Quoted: 591 Post(s)
Liked: 345
Links to the zip and rar files in the first post appear to be broken.
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #252 of 253 Old 07-10-2015, 01:20 PM
yngdiego's Avatar
Quoted: 37 Post(s)
Gary
Download in post #246 works. Getting it to actually run is entirely a different matter.
Edit: I also installed the Direct-X package mentioned up a few posts on Windows 7 x64, and now the app launches.
yngdiego is offline
post #253 of 253 Old 07-11-2015, 12:32 PM
Yamahalic's Avatar
Great Program
I got the .rar file to open using Unpacker (found in Windows store as a freebie) in Windows 8.1. File still works fine using inches and feet as units of measure. Superimposed grids on walls, ceiling and floor assumed as one square foot in order to better locate your reflection points. Now on to the mid to high frequency trap builds. Good program...Very easy to use and understand. Side note: I always knew the reflection points described by this program would be problematic in my home theater: Now with this program I can visually see their locations - given my input data - to better deal with them using DIY acoustical traps. Thank you!!
Yamahalic is offline
