What gage and brand of speaker wire did you use in your new construction - AVS Forum | Home Theater Discussions And Reviews
post #1 of 47 Old 03-20-2007, 04:26 PM - Thread Starter
kpd216's Avatar
I am curious what brand and gage people are using in their Home Theaters for speaker wire/cable and what recommendations you have. I will have a 7.1 system using a $2000 range amp and high end paradigm speakers. My longest run is 40 ft to the front and center speakers.
Thanks for your input.
kpd216 is offline
post #2 of 47 Old 03-20-2007, 04:45 PM
mmmkam's Avatar
12 gage. Just use the cheap stuff from the hardware store.
mmmkam is offline
post #3 of 47 Old 03-20-2007, 06:34 PM
Stew4msu's Avatar
12 gauge. Home depot brand.
Stew4msu is offline
post #4 of 47 Old 03-20-2007, 06:40 PM
BocaPimp's Avatar
I used 10 gauge Steren Python Ultra Flex High-Definition Speaker Wire from cablesforless.com, keep in mind that in longer runs you always wanna use thicker cable, to prevent loss or distortion from other devices around the wires.
BocaPimp is offline
post #5 of 47 Old 03-20-2007, 06:45 PM
T_trip's Avatar
Part # 100-742 12 GA 2 COND SPEAKER WIRE 500' from Parts Express. Finished wiring 2 weekends ago.
Tommy
T_trip is offline
post #6 of 47 Old 03-20-2007, 06:52 PM
johnson_sb's Avatar
12 gauge Carol brand from parts express.
-Steve
johnson_sb is offline
post #7 of 47 Old 03-20-2007, 06:55 PM
ifeliciano's Avatar
The census around here is that 14g or 12g from HD is fine. You don't need to go out and buy a set of Kimber Selects for 7K a pair in order to get good reproduction for HT or for two channel for that matter, but there are those that would argue.
Hell, Id argue too if I just spent 25K in speaker cables and don't have an orgasm after listening to them on my system.
Anyhow read --> The truth about speaker wire for an insight of an audio industry designer.
ifeliciano is offline
post #8 of 47 Old 03-20-2007, 06:57 PM
usualsuspects's Avatar
Quoted: 18 Post(s)
Liked: 30
14ga 4 conductor CL3 from parts express.
usualsuspects is offline
post #9 of 47 Old 03-20-2007, 07:02 PM
GlennR62's Avatar
If you're running the wires in the walls, make sure they are rated for in-wall use. You don't want to have issues with your insurance company in the event of a fire.
GlennR62 is offline
post #10 of 47 Old 03-20-2007, 07:50 PM
judsonp's Avatar
Actually, I learned something on this topic as well. Here is a good article from Bluejeanscable.com describing in wall rated cable.
Link
I used the BJC Belden 5000ue 12ga.
judsonp is offline
post #11 of 47 Old 03-21-2007, 04:12 AM
miltimj's Avatar
12 AWG from an online wholesaler like Westlake Electronic or Liberty Wire & Cable
miltimj is offline
post #12 of 47 Old 03-21-2007, 09:22 AM - Thread Starter
kpd216's Avatar
Thanks for the great response from everybody and keep them coming! This really helps. I'm leaning towards 12 ga cl3 in wall speaker wire. I will be starting my construction thread very soon.
Thanks, Robin
kpd216 is offline
post #13 of 47 Old 03-21-2007, 09:27 AM - Thread Starter
kpd216's Avatar
Also, has any body used COAX RG6 for a subwoofer cable and did it work for you?? I have a 45 ft run, Thanks
kpd216 is offline
post #14 of 47 Old 03-21-2007, 09:41 AM
John Martin's Avatar
I used Blue Jeans 12ga. speaker and had them make me a 40' subwoofer ($54). Start wiring this weekend.
John
John Martin is offline
post #15 of 47 Old 03-21-2007, 10:18 AM
bucky8687's Avatar
12 ga. CL3 from Westlake Electronic for me.
bucky8687 is offline
post #16 of 47 Old 03-21-2007, 10:36 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
I used RG6 to make 40ft Component and RCA runs with RCA compression connectors. Also made a 15ft Subwoofer cable for my buddy with the same RCA connectors. No problems.
If you have the material use it, if not you can get a decent subwoofer cable from monoprice for less than 15 bucks.
oman321 is offline
post #17 of 47 Old 03-21-2007, 11:17 AM
strange_brew's Avatar
Chalk me up for the HD 12 ga. in-wall (2 runs to the front mains for bi-wire)
Craig
ReedZone Theater Thread
strange_brew is offline
post #18 of 47 Old 03-21-2007, 11:34 AM
umdivx's Avatar
i did 10ga. 4 conductor for my mains (bi-wire setup) and 12ga. for the front satalites, surrounds, and rears, purchased all from Westlake.
- Josh
umdivx is offline
post #19 of 47 Old 03-21-2007, 05:43 PM
Mark Lem's Avatar
12 ga cl3 for 30 ft runs
Mark Lem is offline
post #20 of 47 Old 03-21-2007, 06:19 PM
Cwwrig's Avatar
I bought some wire off Ebay that was rated for in wall use. Tributaries CL-3 Inwall 16/4 Speaker Wire. It worked out well. My advice is not to skimp on the CL-3 pulling the wire through pre-drilled holes will ensure the wire does not get damaged because of the strong insulation.
Cwwrig is offline
post #21 of 47 Old 03-21-2007, 06:33 PM
phisch's Avatar
Quoted: 59 Post(s)
Liked: 42
I used 14 gauge 4 conductor Monster brand in-wall wire. The only reason I got the Monster brand was because I got it for half price.
phisch is offline
post #22 of 47 Old 03-21-2007, 06:44 PM
patrickjherbert's Avatar
Ever look inside a speaker cabinet and see the 24GA wire they use for the connections in there? Having said that, I used 12GA from HD and Monoprice (where speaker wire was out of stock for a couple of months recently.) Works perfectly well.
Anyone who claims that you have to be violated by the likes of Monster and the boutique cables companies to get audiophile-ish sound, probably also labors under the illusion that women find expensive speaker cable irresistably sexy.
YMMV of course, and I may just prefer expensive Scotch to expensive copper. Scotch works better on the ladies too!
patrickjherbert is offline
post #23 of 47 Old 03-21-2007, 07:14 PM
crackyflipside's Avatar
12AWG romex for speakers
10AWG romex for IB
crackyflipside is offline
post #24 of 47 Old 03-22-2007, 10:47 AM
I hear that
not to mention what it does to their looks...
Craig
post #25 of 47 Old 03-22-2007, 11:34 AM
Cathan's Avatar
Did someone mention Scotch?!? Good single malt is the only thing keeping me from not foaming at the mouth while wait to get started on my build.
Cathan is offline
post #26 of 47 Old 03-22-2007, 03:44 PM
HTScotty's Avatar
Tommy
Yup!~... same here!
HTScotty is offline
post #27 of 47 Old 03-22-2007, 04:05 PM
eskay's Avatar
Belden 5000up: 12AWG, inwall rated, high stand count, pretty green color.
eskay is offline
post #28 of 47 Old 03-22-2007, 06:54 PM
QueueCumber's Avatar
Quoted: 70 Post(s)
Liked: 38
I would also wire XLR or single ended cables into the walls at the same time. In case you ever switch to digital speakers later on down the road (which is where everything is heading IMO). It is always smart to future proof. XLRs (Balanced cables) are the better choice IMO, as they allow any anomalies introduced into the signal via EMI to be cancelled out at the receiving end.
QueueCumber is offline
post #29 of 47 Old 03-22-2007, 09:10 PM
miltimj's Avatar
10AWG romex for IB
Solid core for low voltage speaker wire? There's much less surface area to carry (a majority of) the signal than stranded speaker wire.. Was this because you already had it installed, or did you choose this for some reason?
miltimj is offline
post #30 of 47 Old 03-22-2007, 09:20 PM
Plenty of leftovers from rest of house construction.
