Minimalist Approach to Screen Wall - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 102Likes
Old 05-02-2013, 10:52 AM
Spec4's Avatar
Liked: 24
Originally Posted by nickbuol View Post
I looked high and low through these forums to find a black material that wasn't GOM to use around my Seymour XD screen for my false wall. I don't recall the product, but it was found at a local fabric store. It is super thin and airy. Looks like velvet of sorts on the outside, but I wasn't fully convinced until I had a local guy with some nice AV monitoring and calibration equipment do a favor and just measure the difference of sound with a full range speaker with and without the fabric in front of it. His equipment is pretty high quality, and it DID detect differences, but very minimally. He was impressed that it did so well for a cheaper material. I didn' think it was THAT cheap until I used a Jo Ann Fabrics 50% off coupon, then it got "cheap".
I really wish I remember what the stuff was....
Was it this suiting fabric?
Spec4 is offline
Old 05-02-2013, 12:21 PM
NGiovas's Avatar
Liked: 43
I was looking through this thread to get ideas for my screen wall and have a question.  I plan to go with just the two vertical and one horizontal post, but my screen is curved.  I am looking for ideas for integrating the upper, lower and side panels since the screen will curve away from the wall.  What have others done?  My theater entrance is near the front.  With the screen curved away from the wall, you will be able to see behind it if the surrounding panels are flat.
Looking for some ideas.
Nick
NGiovas is offline
Old 05-02-2013, 12:50 PM - Thread Starter
Quoted: 3364 Post(s)
Liked: 2839
Curve Frenzy had a curved screen (Seymour) the brackets that ship with that screen are designed to attach to a flat wall/frame. For their frames you attach the top with a special curved french cleat affair and the bottom reguires two L brackets to keep the screen from pulling away from the wall. those attach just below the screen edge.
For that project I just made four standard fabric panels and it wasn't a problem as the edge of the screen was so close to the wall you couldn't see around the edge. For a wider room you could just make the side panels wider so they tuck behind the screen or you could fasten some curved affair.
Old 05-02-2013, 01:13 PM
NGiovas's Avatar
Liked: 43
Thanks BIG.  I think my screen is the exact same size as his (140"), so it may not be as much of an issue as I was thinking it would be.  I will take another look at that thread.  I also plan to build the frame without the fabric to take some measurements, so that will give me a better idea of how far it will stick out.
I'm thinking four flat panels will be the best solution.
NGiovas is offline
Old 05-02-2013, 01:49 PM
nickbuol's Avatar
Quoted: 574 Post(s)
Liked: 620
Sorry, but no it wasn't. I don't recall the word "suiting" anywhere in the name.
I should have kept better notes.
nickbuol is offline
Old 05-02-2013, 05:39 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
I purchased some velveteen material from JoAnn that is perfect for a screen wall. It was as dark or darker than the velvet on my Jamestown frame. It was pricey, but a 50% coupon made it more palatable.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
Old 05-03-2013, 09:20 AM
Brad Horstkotte's Avatar
Liked: 68
Also check out syfabrics.com triple velvet, I use it on my screen wall panels, and it matches the Seymour screen frame velvet frame very well - and sucks up light very well.
Brad Horstkotte is offline
Old 05-03-2013, 09:30 PM
matthewa's Avatar
Quoted: 17 Post(s)
I am about to start on my screen wall, and trying to get this straight in my mind. Do the "football" posts sit at the edge of the screen frame? Do you put some blocking timber on the outside walls to have the fabric panels sit against?
matthewa is offline
Old 05-04-2013, 06:37 AM
foraye's Avatar
Liked: 34
The
Originally Posted by matthewa View Post
I am about to start on my screen wall, and trying to get this straight in my mind. Do the "football" posts sit at the edge of the screen frame? Do you put some blocking timber on the outside walls to have the fabric panels sit against?[/quote
The screen frame hangs from the goal posts.
foraye is offline
Old 05-04-2013, 06:47 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 142
The goal posts are centered on the edge of your screen frame (so the frame sits against one half of the post and the fabric panel sits against the other half). Additional blocking may be required on the side wall to secure the other edge of the fabric panel.
Spaceman is offline
Old 05-22-2013, 07:11 PM
bondslex's Avatar
Quoted: 13 Post(s)
Greetings all! Time to revamp my theater. As you can tell from the pic it is greatly outdated. I do have decent equipment though. I just need some advice. I want to do the screen wall but as you see I have the angled walls. Any advice on how to proceed? current theater.JPG 307k .JPG file
Name:	current theater.JPG
bondslex is offline
Old 05-22-2013, 07:25 PM - Thread Starter
Liked: 2839
Just build a screen wall to match the angles of the walls. Is there a particular aspect that stumps you?
Old 05-24-2013, 01:40 PM
bondslex's Avatar
Quoted: 13 Post(s)
I just wanted it to look like it was professionally done. I think with all of the builds I can do it. I just wish I didn't have the vaults.
bondslex is offline
Old 05-24-2013, 02:02 PM
jason4vu's Avatar
Quoted: 32 Post(s)
Liked: 100
dabsabre likes this.
Race to the finish home theater buildhttp://www.avsforum.com/forum/19-ded...ter-build.html
jason4vu is offline
Old 05-24-2013, 06:48 PM
bondslex's Avatar
Quoted: 13 Post(s)
Great pic Jason
bondslex is offline
Old 07-25-2013, 04:04 PM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
A Big Thanks to Big!!!
I just built my screen wall following your instructions! Turned out great. My local HD didn't have any FJ 5/4 over 8 feet long so I went with 1x4 Pine. They used to carry it. What else is weird is they have FJ in 8 foot lengths but it is no longer 5/4 - it is standard 1x4".
Anyway - I finished putting it up last night and now I need to paint it.
Here are some pics:
dabsabre and 4AlexF like this.
jimmyk36 is offline
Old 07-25-2013, 06:02 PM
ScAndal's Avatar
Liked: 27
ScAndal is offline
Old 07-25-2013, 06:15 PM - Thread Starter
Liked: 2839
Old 07-31-2013, 04:49 AM
MysticalJet's Avatar
Quoted: 81 Post(s)
Liked: 152
See my build thread in my signature below.
MysticalJet is offline
Old 07-31-2013, 03:38 PM
linkseo's Avatar
Liked: 25
Added 3 - 18 inch Zbar brackets.
I cant beleive i never though of french cleats to hang the screen. Ugh. so simple. confused.gif
linkseo is offline
Old 08-27-2013, 11:50 AM
RossoDiamante's Avatar
Am getting ready to put up my screen wall which is being inspired by Mr. Big's minimalist design.
But I'm wondering if I can go even more minimal.  Here is my proposed design:
PFU ScanSnap Manager #S1500
To secure the horizontal piece to the vertical piece, I have two Simpson plates that I can screw each piece into.  If needed, I cold repeat on the front as well, but I think a few 1" screws into 5/4 will be pretty secure.  This would allow a reduction of 2 pieces of 5/4.
For those local to DC, my local lumber yard had 5/4 a bit cheaper than Home Depot.  I think it was $1.25/linear ft.
Diamante Build in DC - Double Drywall, Green Glue, Drywall Furring Channel, Riser, Stage, Bass Trap, In-Wall Speakers, BG Radia, JTR Captivators, Seymour AV, Sony HW-50ES, Sherbourn, Panasonic, Middle Atlantic, Lutron Grafik Eye, Baffle Wall
RossoDiamante is offline
Old 08-27-2013, 12:47 PM
linkseo's Avatar
Liked: 25
exactly what type of simpson plate would you use to attach the vertical and horizontal pieces?
linkseo is offline
Old 08-27-2013, 04:53 PM
If I remember correctly, it is a Simpson HTP37 plate.   It is a 3" x 7" plate with a bunch of holes to put screws through.
http://www.homedepot.com/p/Simpson-Strong-Tie-R-Tie-Plate-TP37/100375215#.Uh07WhukpKI
Old 08-27-2013, 06:34 PM
BllDo's Avatar
Quoted: 588 Post(s)
Liked: 380
So you're putting up a screen wall in front of your baffle wall?
BllDo is offline
Old 08-27-2013, 06:37 PM
Yep.  Pretty much has to be that way given the in-wall speakers I'm using.  Just like the movie theater!
Old 08-27-2013, 06:41 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 142
Wouldn't it need to be an angle bracket or were you thinking of just slapping that plate across the front face (facing into the room)? I guess I was picturing something behind the horizontal piece.
Spaceman is offline
Old 08-27-2013, 06:50 PM
BllDo's Avatar
Quoted: 588 Post(s)
Liked: 380
Why not just secure blocking to your baffle wall and hang your screen on that?
Really?
BllDo is offline
Old 08-28-2013, 03:26 AM
Actually I was just planning on slapping that plate across the back face (facing the baffle wall), but same idea.  Worst case scenario, I could put an angled piece underneath the horizontal piece and brace it to the vertical piece.  But neither the screen nor the wood is that hefty.
Old 08-28-2013, 03:35 AM
Really?
Sort of like this from THX:
Or this setup:
The idea of a separate wall structure is to provide several inches between the speakers and the back of the screen per the screen manufacturer's recommendations.  Although the minimum seems to be a couple of inches, I've heard up to about 6" recommended.  Mine will fall somewhere in that range.  An interesting thought about securing directly to the baffle wall, however.  It might work if you had a square area to work with.  But my angled walls leave me with a narrower width on the baffle wall than the screen itself.
4AlexF likes this.
Old 08-29-2013, 02:21 PM
chriscmore's Avatar
Quoted: 126 Post(s)
Liked: 111
Or this setup:
The better, more acoustically transparent the screen, the less distance between the screen to speakers is needed. We can hang right over in-walls with about one inch effective clearance.
Cheers,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
